Alright I've found my ship! The USS Oswald A. Powers (DE-542), named for a ENS Powers, a member of VT-3 (CV-5) at Midway and one of the 10 planes that did not return; only TWO returned to The
Yorktown, 4 to The
Enterprise, and none to The
Hornet. A very bad day indeed. The
Powers was one of several DEs that were suspended following the end of the war and were subsequently scrapped incomplete. I'll remedy that and have her in commission as planned in 1945. To facilitate the modifications I'll have her get torpedoed during the battle for Iceland, limp back to the States, and get re-built as the lead ship of the modified Butler Class. The rest of the new class will be built from the keel up or modified on the slipways with the new mods. Several DEs ate a U-Boat torpedo and survived to be repaired so the events are more than plausible.
This project is coming together now
Here's the drawing!
Mods:
-25' Hull plug inserted in between the funnel and bridge structure allowing for sufficient internal hull space for an emergency diesel generator and more fuel oil. Above decks the plug allows a deck house extension to be be added housing two fixed 21" torpedo tubes (staggered) for Mk-35 long range homing torpedoes with 2-3 reloads per tube, 6-8 total.
-Two fixed Hedgehogs mounted atop torpedo deck house (about 25-30 degrees off the center line) with reload lockers. Two reloads for each mount.
-Mk-56 director atop the bridge to control the 5"/38s.
-One quad and two twin 40mm Bofors installed in place of the triple torpedo tubes.
-Whaleboat re-located to port side of the funnel.
-Funnel 20mm mounts moved aft of whaleboat and reduced to two mounts.
-ECM mast added abaft the funnel with one TDY-1 jammer ala DD-445 Class.
-Radars upgraded to SC-2 and SG.
-Added supports to 20mm mounts that hang off the superstructure.
I goofed a few things in the drawing
-Forward 20mm mounts beside the bridge will be reduced to one per side.
-Starboard 20mm mount abaft the funnel will be moved forward abreast the funnel. Port mount was displaced aft due to whaleboat.
-Might cut the 20mm battery smaller again and leave only 2 below the bridge and the 2 on the stern. The 20mms lost their effectiveness by 1945 and beyond anyway.
So there you have it, enjoy! Thanks to all for their comments.
Any thoughts, ideas, comments, etc... are appreciated as always!
PS, I found out some info on the post-war
Dealeys. They were designed in an attempt to build an emergency mobilization asset that could be constructed in a very short time and as cheap as possible. Hence the 3"/50s and a single engine/single screw engineering arrangement. Apparently they weren't totally successful at least according to Friedman...
