1/700 British sloop of the Cruizer class 1797-1820
- kennylibben
maxim
No, no. There will be no crew. I am not able to build such detailed models. I have not even the patience for this - and also not the skills.
Here some progress with the rig of the bowsprit and the shrouds. These are Saemann �tztechnik's shrouds/ratlines.
First the original part:
You see that it is not perfect at the top and much too big. Therefore I cut it to fit:
Here they are fixed to the Grasshopper:
The rig has still many imperfections.
- Avery Boyer
Stunning! Great job on a tiny model
- kennylibben
- kennylibben
- MichelB
Maxim, she looks gorgeous. Sorry, but I can't supply you with photo's of the Euralyus right now: my digicam has given up functioning. Let me say this: your guns look better then mine. Problem is that the skytrex range were made as wargaming units, not accurate models, so there is some degree of simplification and it being metal makes modification a tad difficult.
maxim
- Avery Boyer
Incredible build
- kennylibben
- MichelB
It's not difficult, depending on how much you want/need to modify.maxim wrote:@ MichelB: do you think, that it is difficult to make a good model using the Skytrax kit? What do you think about the etched ratlines, which are contained in the kit?]
The hull: Reasonable detailed, a tad less than a good resin cast. Looks decent. Can't comment on exact replication of details. Metal, so will require mechanized tools to modify.
The masts and yards: Masts are cast inregral deck to tip. Looks decent, may be a tad thick. Yards are definatly thicker than scale, should be replaces by (tapered) brass rod.
The PE ratlines: Decent. A generic set for all skytrex ships. Stiff material, not as easily workable as others PE material.
The PE Sails: Same thing. Not sure if its a generic set or not. Same stiff material, so its difficult to recreate any realism in the sails.
Hope this helps, I'm building this out of the box, as a scale reference.
maxim
The hull takes a lot of time. Therefore I am thinking about buying some of the Skytrax frigates. If the rig is not superb than it is the same as with scratch building - but it is not necessary to buy ratlines.MichelB wrote:The hull: Reasonable detailed, a tad less than a good resin cast. Looks decent.
Here some progress with the Grasshopper. I painted the yards black. I added some new parts of the rigging of the bowsprit and the bumkim:
- kennylibben
- kennylibben
