WIP: Gallery 1/350 USS Iwo Jima LHD-7
Re: WIP: Gallery 1/350 USS Iwo Jima LHD-7
Adding details to the sides of the hull continues...
Getting very close to the step where the flight deck will be attached. Before I do that, I want to mask off the lower hull and touch up the hull with another airbrushed coat of Modern Haze Grey.
Sylvain Auger
Post by Sylvain Auger »
This is looking very good Martin! :thumbs_up_1: I'm not a carrier guy but this looks like a very fun model to build
Sylvain :wave_1:
Ventis Secundis
ex-navy
Post by ex-navy »
looking good... now,, I have to justify getting this version.. I have the wasp and was planning on converting her to the IWO.. keep the great work up....
Thanks guys! Here are shots from last week, right after I was last able to work on her:
Hull freshly repainted
Flight deck and elevators are not permanently secured
Still need to add some decals to the ramp and the stern.
Some photos of her on display at JerseyCon2:
With MRC promotional material
MRC promotional material.  Love the box art - too bad mine was a plain white box!
More photos or her on display at JerseyCon2 by Bob W are here.
Next steps: paint the flight deck and the elevator decks, then secure those to the hull.
Now that I'm somewhat recovered from JerseyCon2, it's back to work. I've skipped around slightly in the instructions, as I need to paint the deck of the elevators and the flight deck. So I passed by installing the elevators, and installed these support that run from the flight deck down to the catwalks from bow to stern on both sides of the hull. These are somewhat fragile, and care has to be taken removing them from the tree and while removing the nubs from the attachment points.
I've also found that these have the most flash of any of the parts I've encountered so far. So much so that I took a night just to run a sharp hobby blade all around each support to try and remove as much flash and as many mold lines as possible. Additionally, one part on the starboard side was warped - the last four columns in the support were bent inwards. It appears that was done in the mold process. But, being that this is a pre-production model, minor issues like this are bound to crop up.
Here is where we are as of earlier tonight:
The support columns just above the large, forward most pocket are the ones that are bent - and just the bottom havles at that.
Flight deck dry fitted, with partially assembled island dry fitted on top of flight deck
nick
Post by nick »
Looking very good Martin! Makes me wish I had one of those beasts!
:thumbs_up_1: :thumbs_up_1:
Nick
:big_grin:
Nichol Caballero
Bigdaddy Mark
Post by Bigdaddy Mark »
Wow is that looking good!!! I'm glad to be able to see one of these monsters in progress, and down the road I may have a few questions for you.
Once I get off my aviation kick I'm going to be picking up the Iwo Jima and doing the minor adjustments to turn it into my son's ship the Bataan. He is deployed right now, and I'm waiting for him to get home so he can point out any and all adjustments to make her right.
Thanks for shooting me the link.
~ Chester W. Nimitz ~
Bigdaddy Mark wrote:He is deployed right now, and I'm waiting for him to get home so he can point out any and all adjustments to make her right.
I'm sure that's not the only reason you are waiting for him to get home! Thank him for this service - hope he gets home safe soon!
Bigdaddy Mark
Thanks.
I am looking forward to seeing him again, and I'll tell him you said thanks.
Started working on the island...
Post by Guest »
how much different is the island of this kit versus the wasp... I know they moved some stuff around.. how much re-work will be involved if you use the wasp for the IWO...
Guest wrote:how much different is the island of this kit versus the wasp... I know they moved some stuff around.. how much re-work will be involved if you use the wasp for the IWO...
Not an expert on the class, but they included entirely new sprues for the island.
sneak
Post by sneak »
Hey Martin, any progress on the build? I'm following with great interest as I'm building the Revell kit for 3 weeks now.
Hey Sneak,
This is my first post in over a month....in fact it's the first time I've logged on in over a month, so sorry for the delayed response.
Due to a round of illness that swept through the house, a six-day business trip to Orlando FL, and a host of new responsibilities (2 additional departments) at work, I have hardly touched the Iwo Jima since early November. I did find a few minutes to fill and sand the joints between the flight deck and the supports sitting on the catwalks. I also washed the entire model when I was done, to remove any grit, etc. from the sanding process.
Here is a photo from about 4 weeks ago - which shows the last (and current) state of the model:
On top of the aforementioned stuff that kept me away from the bench, I've been having major airbrush issues, which I've been trying to work out. All in all, not very conducive to model building.
I am hoping to get some time at the workbench this weekend (he says, fingers crossed).
My apologies to MRC, as I thought that I'd have this project completed (or nearly so) by now.
IJ has risen from the grave.................
Dan K wrote:IJ has risen from the grave.................
Grave? You couldn't have said "slumber"? :heh:
oneslim
Post by oneslim »
Wow, that is nice!!!
Bob W
Okay, I'm back in the saddle again. Unfortunately, due to the aforementioned additional responsibilities at work, I don't have the time to access the message board during the day, and I'm usually too beat at night. So, while I've been getting some work done, I haven't had time to post - until now.
Work continued on the island, adding platforms and platform supports. Overall, the parts are nicely done, albeit with a bit of flash. A few of the support posts/braces weren't fully formed, but considering this is a pre-production kit, not unexpected.
This goes on the back of the island facing aft - not the flash!
I would say that the island has the most fit problems in this kit to this point. Nothing awful, but just take your time, remove flash, test fit repeatedly, etc...
The fit of the two funnels to the island were the areas that gave me the most trouble. Just a heads up for those of you building the kit.
Next step was to start working on the forward mast. The "lattice" work on the masts is replicated quite nicely. IMO, you will not need to replace this with photo-etch, if any after marketers supply it. Again, there were some issues with some parts not being fully formed. The two main lattice braces for the port and starboard side of the mast were missing 3 out of the 4 attachment points required to secure it to the mast itself.
Here are the two lattice brace parts laid out....
I was able to glue the port side lattice brace using it's one attachment to the pole, and notch in the lower platform on the mast. I also skipped ahead in the instructions and added the upper platform, to have another attachment point available.
When that was dry, I added the back lattice brace for additional strength before trying to add the starboard lattice brace, which had no attachment points molded on to it.
Once these parts were added, I set the mast in the locator holes on the island and let it dry...
Welcome back. Looking good. Happy New Year!
Return to “Completed Models”
