Various 1/700 IJN 12.7cm HA gun accessory sets
Photo Etch, Resin, Metal, and Wood conversions or upgrade sets
Re: Various 1/700 IJN 12.7cm HA gun accessory sets
An excellent question.
A. Noneemus
Post by A. Noneemus »
Hi all. So this is my first time here :wave_1: , and I was wondering (while trying my hand at buying aftermarket parts for a kit, namely Tamiya's 1/700 Mikuma) if there were any 1/700 Type 89 12.7 cms with an anti-wave shield? Because, although Fine Molds and Veteran both have really good offerings, they aren't really accurate. Any suggestions would be greatly appreciated?
The Pit-Road NE03 set has the correct wave shields (Type A1) but, be advised, each set only comes with two, IIRC.
mopy
Post by mopy »
Not I. Forgot about that one.
A. Noneemus
Dan K wrote:The Pit-Road NE03 set has the correct wave shields (Type A1) but, be advised, each set only comes with two, IIRC.
Cool thanks, I'll have to look into that one. Too bad their so pricey for what you get.
Post by Guest »
Also, has anyone seen or does anyone have the Ocean Spirit HO96 set? I can't tell if it is just PE detail for other Type 89s, or if it is its own set. If so, it might be better than the Pit Road set based on price alone.
mopy
Post by mopy »
Guest wrote:Also, has anyone seen or does anyone have the Ocean Spirit HO96 set? I can't tell if it is just PE detail for other Type 89s, or if it is its own set. If so, it might be better than the Pit Road set based on price alone.
I can check on it when I get home, but I am almost 100% positive Ocean Spirit is a complete set - resin, PE and brass.
A. Noneemus
That's good, because they are WAAAYY cheaper than the Pit road set, and look just as good.
mopy
Post by mopy »
A. Noneemus wrote:That's good, because they are WAAAYY cheaper than the Pit road set, and look just as good.
Oups.
I completely forgot about my promise. :sorry:
Like I said, the set has resin, PE and brass parts:
https://goo.gl/photos/P9bjt6Sd2CKZDVrw7
A. Noneemus
Oups.
Nah don't worry about it.
saldy
Post by saldy »
guns by oceanspirit
IJN 1/700: DD Hamakaze, CL Oyodo, Sub I-400, HIJMS Mogami
Next: CVL Ryujo
drasticplastic
Post by drasticplastic »
3DModelParts make some serviceable weapons, and they are inexpensive, and best of all, made in US:
http://www.3dmodelparts.com/1-700-imper ... nese-navy/
:wave_1:
Return to “Aftermarket upgrades and Accessories”
