Calling all HMS Repulse & HMS Renown fans
73north
Re: Calling all HMS Repulse & Renown fans
Post by 73north »
Thank you !
Yeah , I spotted a few reviews - on the Repulse especially the faults ( open tunnel ) on the rear superstructure -
and the non-existent gun tubs on the rear turret top that Trumpeter decided to fit on to X Gun Turret
the one I can't get over is the single bracket support for each propeller shaft , when each shaft had two supports
JCRAY
Post by JCRAY »
Check out Andrew F build in the gallery when the kit first came out he points out must of the faults. Well worth a look if you haven't seen it.
hth jc
JCRAY wrote:Check out Andrew F build in the gallery when the kit first came out he points out must of the faults. Well worth a look if you haven't seen it.
hth jc
You can find a link on the first page (2nd post) in this topic.
73north
Post by 73north »
Thank you very much , much appreciated
just an update to say I ended up buying the ArtWox Wooden Deck set ( and also as you get a free anchor chain )
RNfanDan
Post by RNfanDan »
JCRAY wrote:I like the Woodhunter deck because it has planking on B gun deck. I haven't used it yet. I bought the Admiralty Modelworks rear deckhouse correction set. The kit is not well moulded (fit) wise.
hth jc
Note to modelers: HMS Repulse had NO WOOD PLANKING fitted to the shelter level abaft main turret B. If a veneer is included in a wooden deck set for this area, and the cost is increased because of this, use your own discretion. I have no stake in the matter of deck veneers whatsoever, so I am completely unfamiliar with their brand variables. I only step in here, to alert those buying a particular veneer set, simply because of its inclusion of that particular component.
FWIW,
--Dan
73north
Post by 73north »
Hi
Can I ask some advice for modelling help ??
I plan to use these 1/350 NEW Shapeways 15 inch Turrets for the Trumpeter HMS Repulse Kit ( made by Micro Master ) - and have a query ?
( 1 ) I plan to use to replace the plastic 15 inch Metal Gun Barrels with metal barrels by Master of Poland -
and use the Trumpeter kit attachments from the old Trumpeter underside of the Turret ( see red arrows - in the photo ) to attach to the Shapeways Turret underside
What is the best way of getting the kit plastic gun barrels ( with Metal Gun Barrels attached at the end ) to be elevated ?
would I be best using the Trumpeter Turret ' Bottom ' front part ( minus the area to the right of the green area marked on the bottom photo )
to keep the Gun Barrels from moving ? - or do I not need them with the Kit Barbette being underneath ??
is there any tips or tricks I need to be aware of ?
for the record - I am VERY impressed with these new Turrets , the extra work to make them fit to the existing Kit Barbettes
will be well worth it , and apologies if the photos are HUGE , its the new photo host , imgur , I am still getting used to it !
kind regards
David
73north
Post by 73north »
I planned on them being able to be manually elevated or be able to be fixed at a flat , horizontal angle .
I definitely don't want to glue them to the Turret
73north
Post by 73north »
I thought I would share a potentially different idea for using the existing Trumpeter Display Base Stand -
I got the Trumpeter ' Dry Dock ' Display Stand coverted to accept 2 Silver Ship Pedestals for the 1/350 HMS Repulse Model
- the Plastic Kit Display Stand was strengthened underneath with 2 Aluminium Supports to transfer the weight of the completed Model to the ground -
rather than the Kit display stand plastic - and 2 proper steel screws and washers to fix the Model to the stand
maybe of some interest ??
note - Imagevenue ( beware - spam Advertising is you click on the links )
note - the Engineer that did the work on the Pedestals was Calum from Anderson and Wilson of Galashiels , Scotland
https://www.engineerscout.org/company-a ... iels-20802
https://www.ebay.co.uk/itm/Model-Ship-D ... 3446606152?
These are the ones that I bought on Ebay , from the same seller , but there are others on ebay as well ( search 1/350 Pedestals Ship )
73north
Post by 73north »
note - imagevenue hosting used - when you click on image , it is much larger ( sorry for adult advertising on imagevenue - out of my hands )
I tried using imgur , but the image sizes are too small , to really be workable
Very Impressed with the Micro Master - Shapeways Turrets for HMS Repulse -
they really are far nicer and more detailed ( and accurate ) than the Kit Turrets
The Master Model Aftermarket Gun Barrels were used - which needed work done with a slight lip removed at the area
where the barrel is attached to the remaining kit plastic gun barrel
The etch is from the FLYHAWK etch Super-Detail set
RNfanDan
Post by RNfanDan »
73north wrote:Image
note - imagevenue hosting used - when you click on image , it is much larger ( sorry for advertising on imagevenue - out of my hands )
WOW! Those look spectacular!
MagisterMan
Post by MagisterMan »
Hi everyone!
A friend of mine is currently building Trumpeter's HMS Repulse for 1941, battle of Malaya.
We've encountered serious problems trying to define the exact number and types of AA weapons as our sources cotradict each other. Can anyone help please?
Also does anyone have information of Vickers 4-barreled machine guns on a platform of the main mast of the ship? Were they fitted there, and if yes, does anyone have photos? IWM did not help, unfortunately
73north
Post by 73north »
Image Image Image
Image Image
These photos show the information
The ship had 3 x Octuple 2pdr Pom-Pom mountings , 4 x Quadruple 0.5 inch Vickers AA guns , 8 x single 20mm Oerlikons
( RN Fan Dan says it could be only 6 sets , but the Historical record and British Battleships by Raven and Roberts of 1976 states she had 8 )
I recommend Big Blue Boy for the Pom-Pom sets , Tetra for the 0.5 inch AA guns and Infini for the Oerlikons
I don't have photos - but the artwork is accurate that I provide ( you need to extend the mainmast platform as seen here on the kit )
also tell you friend - NO GUN TUBS on the After ( rear ) Main Gun Turret
regards
David
tjstoneman
Post by tjstoneman »
The locations of the 8 (or 6?) single 20mm Oerlikons have been the subject of debate.
There are clear photos showing two on "Y" turret; as David says they were not in "tubs", but stood on circular stepped platforms. The well-known photo of her leaving Singapore shows two abaft the deckhouses abreast the mainmast* - these were in circular splinter shields. Various drawings show another pair for'd of these deckhouses, and aft of the catapult, but I'm not aware of any photographic evidence that these were in fact fitted. Another pair were forward; some references state that these were on the Conning Tower Deck level abreast the conning tower; others say they were at Foc'sle Deck level or at Shelter Deck level! The aforesaid Singapore photo shows an object at Shelter Deck level there; the copy I have is blurred, and it's difficult to make out what it is, but it looks like another circular splinter shield with an Oerlikon shield above it.
A report by a survivor (http://www.navweaps.com/index_inro/INRO_Repulse.php) lists only six Oerlikons; the author was in the after HA.DCT during the action, and states "...men who had started to congregate near No.5 Oerlikon, having come on deck through the door leading into the Captain's lobby ...", which implies that this gun was one of the ones abaft the deckhouses abreast the mainmast (probably to starboard). As on officer involved in her gunnery system, one assumes he would have known the number of guns fitted.
As David's illustration shows, the second pair of quadruple 0.5" Vickers mountings were on the extended platform partway up the mainmast, either side of the 4" LA.DCT.
* Note that these deckhouses were asymmetric, replacing the original deckhouses for the now-removed twin 4" BD mountings; atop these new deckhouses were single 4" HA guns.
RNfanDan
Post by RNfanDan »
At this time, I can confidently place the number of 20mm Oerlikon mountings the ship carried aboard on December 10, 1941, at SIX. Indisputably, four have been photographed and/or otherwise reliably documented; these were all located aft of the aircraft hangar & catapult, two of them being mounted atop turret "Y".
Less well-documented, but evident in at least one photograph taken of the ship on December 8, 1941 (as Mr. Stoneman explained previously), was another pair of Oerlikon mountings, located on the shelter deck abaft turret "B". I strongly believe these forward weapons were fitted, not only by the evidence seen in the Johore Strait image, but from other visual evidence I have been privileged to view, during my many years of study and research on this ship. There is little doubt that Repulse was intended to receive a total of eight such weapons, but I am equally certain she never received all 8 of them before she was sunk off Malaya.
I can also state --definitively--that not all photographs taken of Repulse throughout 1941, have been published. A number of privately-held images have been found (I have been privileged to view these, myself) have only been brought forth, fairly recently. At least one of these images reveals an important detail: The absence of any Oerlikon mounting adjacent to the armored conning tower, "stuffed" between the tower and its adjacent bulwark/blast deflector--as incorporated into at least one current, popular plastic model assembly kit. In any event, even if all 8 Oerlikons had been fitted, there were NONE to be seen at the forward end of the conning tower deck.
Strangely enough, only sparse information about the ship's forward AA weapons seems to have survived Repulse's loss. Although she had boarded a significant foreign press crew for at least part of Repulse's voyage in the far east, I don't believe any photographs they captured of the ship's forward areas have survived or been recovered. My best recollection found to date, albeit very brief and of little value to my research, was by (IIRC?) her senior forward air-defense officer. This was available on the internet some years ago, but the accounting was of little value in addressing the matter. Perhaps it may still be found, for those so interested? As another "aside", I did listen to an IWM interview with a Repulse survivor, in which he reported a number of Lewis guns had been present on the forward ADP (the uppermost platform on her foretop). Again however, not of any value to the Oerlikon mountings question.
For these reasons alone, the presence of all 8 scheduled Oerlikons listed on Admiralty armament returns for Repulse actually being aboard-ship, are doubtful. Perhaps soon, new evidence will surface that will put the question to rest (six-- or eight?), one way or the other, and establish the exact positions of the #1 and #2 Oerlikons.
Cheers, modelers!
Dan
RNfanDan
Post by RNfanDan »
JH
Post by JH »
Morning!
Been offered a good price for the Trumpy 1/350 Repulse, (�45) is the kit itself a decent foundation to work from?
Not against scratchbuiding!
Jens
Be not simply good, be good for something
Henry David Thoreau
Vlad
Post by Vlad »
JH wrote:Morning!
Jens
Yes, the kit is a good starting point. Biggest issues in my opinion, not an exhaustive list:
- the angled plated up section below the bridge has a curved line; this should be straight, can be fixed with careful sanding.
- the hull shape is OK but the location of the waterline is plain wrong. Ignore Trumpeter's instructions, paint the boot stripe high and wide, basically from the kit waterline split to the top of the main armoured belt/torpedo bulge
- aft deckhouse under single 4" mounts is the wrong shape for Dec 1941. The shape is correct for a 1936-39 fit with the twin mounts; easy scratchbuilt fix.
Vlad
73north
Post by 73north »
JH wrote:Morning!
Not against scratchbuiding! Cheers Jens
I would say � 45 is a superb cheap price for that kit , note -
the main errors Trumpeter made with the kit are listed in this build log - viewtopic.php?f=60&t=44007
These are mainly , only 1 support strut for the Propellor shaft brackets ( should be 2 ) - easy fix
Aft Hawse pipe hole in stern is too high , it should be lower ( see build log quoted above )
ditch the 20mm Oerlikons - from kit , they are garbage ( Infini do a great set )
as stated - the aft deckhouses were made by the Model Company are from 1936 Refit , and were altered in 1939 -
see my earlier post with the photos showing this -
I also point out that the Flyhawk set is wonderful , but contains too many Oerlikon Tubs ( only 8 needed ) -
The Plastic Gun Tubs on the Aft Turret - and the Stern - were never there - remove them -
you only have only have 2 round , flat platforms for the Oerlikons on the Rear Turret
hope that helps
tjstoneman
73north stated that only 8 Oerlikon tubs are needed - I beg to differ. I believe that she only ever carried 4 20mm in tubs (abreast the mainmast and abreast the conning tower), plus 2 without tubs on "Y" turret. See posts by myself and RNFanDan dated 5 and 8 April in this thread.
RNfanDan
Post by RNfanDan »
tjstoneman wrote:73north stated that only 8 Oerlikon tubs are needed - I beg to differ. I believe that she only ever carried 4 20mm in tubs (abreast the mainmast and abreast the conning tower), plus 2 without tubs on "Y" turret. See posts by myself and RNFanDan dated 5 and 8 April in this thread.
I will add to Mr. Stoneman's post, this important point:
* There were NO Oerlikons present above and abaft "B" main armament 15" turret, as provided for in the kit parts. These are depicted as small outcroppings or sponsons, one each, to starboard and port of the main armored conning tower (supporting the main gunnery director). Recent photographic evidnce disproves their existence (which was speculative, at best). The outcropped bulwarks can be trimmed away and replaced with plasticard or other suitable strip material, to establish their proper contours.
--DJB
