Bismarck 1/100
AlainFR
Re: Bismarck 1/100
Post by AlainFR »
Hello Norbert :wave_1:
I agree with Dave, it's very interesting to see the differents steps of your work, it's very instructive! :thumbs_up_1: :thumbs_up_1:
Will be the guns and turrets functioning?
So long, good evening from France ! :smallsmile:
Alain
Capit�o Norbert
Re: Bismarck 1/100
Post by Capit�o Norbert »
Hi Alain thank you too.
yes i pretend make functionally and rotate and elevate.
i pretend but now i need make more of structure and start the hull finally.
the mechanisms i will thinking about.
i like your system to do with a servo.
how many channels have your radio transmiter? :wave_1:
Re: Bismarck 1/100
Post by 109 »
Good progres on the main battery! :-)
Capit�o Norbert
Re: Bismarck 1/100
Hi Bernd thank you too. :thumbs_up_1:
AlainFR
Re: Bismarck 1/100
Post by AlainFR »
Hi Norbert :wave_1:
I use motoreductor for the rotation and for the elevating of the barrels. Have you see the pictures of my turret on my Missouri?.
My radio has 7 channels :
1 for the direction
1 for the portside motor
1 for the starboard motor
1 for the centers motors
so, it's remain 3 channels for all the functions remaining. I will want to make a system that multiply the functions. It's in my mind but not for the moment on the paper!!! :big_grin:
Alain
Capit�o Norbert
Re: Bismarck 1/100
Hi Alain
thank you :thumbs_up_1:
yes i have seen some pics of your buildings. that's good.
humm so you have a 7 channel radio. my is 4 but i am thinking to purchase one more powerfull with more channels.
interesting you use one servo for each motor.
ok thanks by infos :wave_1:
Capit�o Norbert
Re: Bismarck 1/100
Hi fellow modellers
i am posting the rounded(with recess) platform of port side,
perforeted plate on parts of deck(i cut just only cause the stainless steel is very harder and the cutt is dangerous using the tool i have.
so some parts of casamate of main gun. :wave_1:
elements of platform cutted
element in assembly...
inclination braces added
Capit�o Norbert
Re: Bismarck 1/100
:wave_1:
adding more arms
adding more arms
positioning the exact place of  recessed door
upside down picture
upside down picture
Capit�o Norbert
Re: Bismarck 1/100
some more.... :smallsmile:
in place
in place
port side hangar being made
Capit�o Norbert
Re: Bismarck 1/100
:smallsmile:
cutting perforated part of rounded paltform<br />the cutt of S.Steel is very hard and dangerous. needs eye protection
using Dremel to do
using Dremel to do
Capit�o Norbert
Re: Bismarck 1/100
:wave_1:
main gun in casamate assembly in NETUNO'S Shipyard
opening to install periscope tube in the side plate
Capit�o Norbert
Re: Bismarck 1/100
:wave_1: :wave_1:
side view
side view
the place of perforated plates in the deck - until next - Bye
Re: Bismarck 1/100
Post by Dave Wooley »
Hi Norbert this is very precise workmanship . I do like your method for developing the gun turrets .
The 10.5cm are the tricky ones to make.
russclark
Re: Bismarck 1/100
Post by russclark »
great work norbert :thumbs_up_1: .i am curious why the use of stainless steel and not some softer metal,brass or copper.you are right when you say it is hard to cut.
Capit�o Norbert
Re: Bismarck 1/100
Dave Wooley wrote:Hi Norbert this is very precise workmanship . I do like your method for developing the gun turrets .
Thank you Dave
yes 10.5cm is very complicated but i have something in my head to solve it
thanks by the support :wave_1:
Capit�o Norbert
Re: Bismarck 1/100
russclark wrote:great work norbert :thumbs_up_1: .i am curious why the use of stainless steel and not some softer metal,brass or copper.you are right when you say it is hard to cut.
Hi Russ.
well these plate i am cutting is a harder material selled me as Stainless steel or a�o inox how we called here in my country
well i have making efforts to cut it but the machine i use to cut as you see the plate above the wood base is more easy cause you have one base but tho cut the curves is more complicated. sometimes the cutting disc broke in this cutting task. i don't have an special tool for cut it :huh:
i prefer brass but the vendor here tell me don't do in brass so i have no choice and i have to use inox.
thanks for ask :thumbs_up_1:
AlainFR
Re: Bismarck 1/100
Post by AlainFR »
hello Norbert :wave_1:
Allways a very good job ! It's clear and proper!
About the last picture, where you find these special "stamped plate" ?.
Good work again :thumbs_up_1: and ...... courage!!!!
Alain
PS : for your info ....... rotten weather : cold, rain and wind !!!! :mad_1:
Capit�o Norbert
Re: Bismarck 1/100
Hi Alain
h r u?
thanks by the words about.
well this plate called t�lle perfore� in french i found in on metalurgic site here in my country one year ago.
one plate about 20x20cm i pay about 35 dollars in the time i order.
:wave_1:
p.s the finish i use file and another things to polite" this harder :Mad_6: material
DrPR
Re: Bismarck 1/100
Post by DrPR »
Very fine perforated metal plates are used as "sifters" or "filters" for separating fine powders. Soemtimes you can get these from scientific supply companies. Since the hole sizes and total open area is critical, they usually give a very precise definition of the hole pattern, which is very helpful for modeling. Unfortunately, because the demand is low the cost may be relatively high. Smaller holes cost more.
McMaster-Carr lists perforated brass sheets with holes as small as 0.016" (24" wide for $40US per foot length) and micro-peforated sheets with 0.006" holes (18" x 21" sheet for $170US).
Re: Bismarck 1/100
Post by 109 »
Very nice progress! :thumbs_up_1:
:wave_1:
