Calling all Nimitz-class CVN fans
- bmkerr
Re: Calling all Nimitz CVN-68 class Fans!
I'm not sure if this has been asked but I want to make a 1/700 USS Harry Thurman model dated during her Gulf deployment in 2005 as my wife was on HMAS Darwin at the time and I've seen a few photos with Darwin in the background.
Can I use the Italeri kit of the USS Nimitz and what changes do I need to make to bring it up to 2005 deployment.
Thank you in advance.
regards,
Brian
"starter of many, finisher of none"
Brian
No, theItaleri Nimitzis basically as-built back in 1970s, with only one sponson for the Sea Sparrow at the starboard bow and none of the Phalanx CIWS mounts or their sponsons. If you want to stick with Italeri kits, it looks like their 1999 Carl Vinson has most of the extra parts you need.
- Mark McKinnis
I have done a bit of research on this and the closest match for a "Truman" is the 1/700 Trumpeter USS John C Stennis kit. That kit is modeled in the mid 2000's so you wold not need much tweaking if any at all. The Italeri kit would require all of the sponsons and SAT Domes to update her to a Truman. There is a Stennis kit on eBay now for less than $50 delivered so the difference in price is not too bad and the level of detail the Trumpeter kit brings is very good. Also, Italeri is 1/720 scale, the Trumpeter kits are 1/700. The vast majority of aircraft are 1/700 scale. They look "not quite right" on a 1/720 scale carrier.
Good luck,
Mark
Good luck,
Mark
- bmkerr
I went a bought the carl vinsion kitTimmy C wrote:No, theItaleri Nimitzis basically as-built back in 1970s, with only one sponson for the Sea Sparrow at the starboard bow and none of the Phalanx CIWS mounts or their sponsons. If you want to stick with Italeri kits, it looks like their 1999 Carl Vinson has most of the extra parts you need.
regards,
Brian
Brian
rundrewrun
Hey guys! Looking for more information on the systems that the Nimitz had aboard during the late 70's, particularly on her 1979 deployment to the Indian Ocean. Any help is much appreciated!
~Dude
~Dude
rundrewrun
Specifying my request...with images!!! If anyone knows or can point me to someone/somewhere that does, all help is welcome! Some things that I marked have already been identified. Pics are circa 1976
- sgtryan13
I am not at home with access to all my references, but I can tell you that in the top pic, #1 is a "TACAN" radar, and#5 are just floodlights to illuminate the flight deck if need be.
- Admhawk
A little newer, but it gives an idea.
Darren (Admiral Hawk)
rundrewrun
Thank you so much for the help!
- cam
Doing some research for building CVN-72 down the track. Does anyone know what the average number of deck equipment carried on a Nimitz class carrier (2000 onwards). Can work out a few quite easily by looking at photos, but not always accurate. I know it is a case of less is more for creating the model, but curious on what is actually carried.
Flight Deck
Tilley Crane x 1
Large Forklift x 1 (is it usually on the flight deck or below)
P25 Fire Engine x 2 (are any spares stored in hanger deck?)
Tow tractors x ?? (are these usually below deck as well?)
Oxygen Cart x ??
Nitrogen Cart x ??
Hanger Deck
Forklifts x ??
Spotting Dollies x ??
Hydraulic carts x ??
Static Frequency Converters x ??
Oxygen Cart x ??
Nitrogen Cart x ??
Small Crane x 1
Also is there a specific spot where they are stored normally in the hanger deck? Photos I have seen suggest forward in hanger bay 1, but would assume some are scattered all over the place during the cruise.
Carl
Flight Deck
Tilley Crane x 1
Oxygen Cart x ??
Nitrogen Cart x ??
Hanger Deck
Forklifts x ??
Oxygen Cart x ??
Nitrogen Cart x ??
Small Crane x 1
Carl
On the Workbench:
1/350 USS New York (LPD-21)
In the Shipyard:
1/350 - USS Iwo Jima (LHD-7 2010)
1/350 - USS Abraham Lincoln (2003)
On the Drawing Board:
1/350 - USS JFK (1991)
1/350 - USS Hancock (1965)
1/350 - USS Valley Forge (1951)
In the Shipyard:
- Mark McKinnis
So, mostly from memory back 25 years, but:
When the equipment is not in use then most would probably get parked in Hanger bay one up front like you said. On the flight deck, it would probably end up in the "junk yard" which is the area behind the Island in front of L-3. The E-2 Hawkeye's get parked in there as well so leave a hole for them. That is why it is called the Hummer Hole. F-14's and E-2 Hawkeyes did not/and still don't have(E-2C or E-2D) APU's (Can't remember if Prowlers had them) for engine start. They need an electric cart and a huffer to do an engine start. By then they both had cross bleed start so the cart would be on one side. The E-2s normally start the right engine first. Tractors would be parked where you intended to pull aircraft so there were generally a couple on the bow between and just forward of the CAT #1 and CAT#2 JBD's. All aircraft had a tow bar either attached to the nose wheel or near it so if there was a fire, you didn't have to hunt one down to move aircraft in a hurry. So if you are looking to portrait a start and a launch, park the appropriate equipment next to aircraft getting ready to start. For the hanger bay, equipment would be parked next to aircraft getting work. Fork lifts were more for moving supplies and heavy parts. You would find some of them in Hanger Bay #3 aft since AIMD and the Jet Shop were aft of the hanger bay. There would also be trash dumpsters back there along with the ships boats.
Hope that helps a little.
Mark
Mark
- cam
Mark that is some great information. Helps form part of the picture and even given some new ideas had not thought of.Mark McKinnis wrote:So, mostly from memory back 25 years, but:
Mark
Are there any other helpful people who could give indicative numbers on actual deck equipment carried on a cruise?
On the Workbench:
In the Shipyard:
In the Shipyard:
Thomas E. Johnson
What 1/700 Nimitz kits are out there now? I�m wanting to get into this scale, and want a Nimitz as she was in 1980 during �The Final Countdown� period, and would like to build a more modern version also with a modern air wing.
- Mark McKinnis
Hi Thomas,
The 1/700 Trumpeter Nimitz (Not Nimitz 2005 kit) is what you are looking for. It represents Nimitz as commissioned until the mid 80's.
https://modelingmadness.com/scott/misc/ ... /5714p.htm
Starfighter Decals does a really nice set for a 1/700 CVW-8 1980.
https://www.starfighter-decals.com/7002 ... uss-n.html
Good Luck!
Mark
Good Luck!
Mark
Tinner7
Hello, first time posting but I have been lurking around for awhile during my Bismarck build. For Christmas this year I think the wife is getting me the 1/350 Nimitz, mainly because that's all I have asked for and a box showed up that had that "big model feel".
Anyway, I am looking to build the Nimitz as it was from 1984-1991. Looking ahead I wanted to get decals for it but only see StarFighters set for 75-83. Can anyone point me to a option for the era I am looking for?
- Mark McKinnis
Hello Tinner7,
I cruised Nimitz 1991 and I am building that version of Nimitz now. Baconfist Models has done a set of the sponsons and the Island CIWIS Station for Nimitz '84-'91.
https://www.shapeways.com/product/HMAY7 ... d=61378594
He used to do a set of bulkheads for the hanger bay walls. You might be able to drop him a note and see if he can set you up with those as well. There are no decal sets that I am aware of. I did mine on the computer using MS Paint. You can get a set of the updated MK-29 Sea Sparrow Launchers here:
https://freetimehobbies.com/1-350-veter ... uncher-x4/
The good news is that the Island/Mast do not need re-work for that era. It is a relatively straight forward conversion.
Good Luck,
Mark
Good Luck,
Mark
Tinner7
Thanks Mark for the reply. I already have those sponsons on order! I will look into the others stuff you say he used to make. Sucks about the decals. Is there a huge difference that you know between the StarFigher's 75-83 set and what I would need? I am looking forward to this project in the coming months because I am already learning more and more about these ships.
I have tried looking into the Nimitz dvd from Floating Drydock but their website seems dated and I am not sure if they are even around anymore. I sent them a email and still waiting for a response.
Thanks again. I am sure I'll be back with plenty of questions and progress pics.
- Mark McKinnis
The Starfighter Decals is CVW-8. I think that they would work for the 1986 East Coast Cruise. CVW-9 was the wing on the west coast. Here is a web site with the carrier airwing lineup.
http://www.gonavy.jp/CV-CVN68f.html
There were some differences between CVW-8 through the 80's but the Starfighter Decals might work for most of the Air Wing.
Good luck,
MM
Good luck,
MM
Tinner7
Hey Mark,
Question for you. Looking over at Baconfist�s Shapeway site I see he has two different hanger walls. One is marked early and the other late. What one would be for the 84-91 era of Nimitz? I assume at 3� long, you would need more to complete the hanger.
https://www.shapeways.com/product/9XFCZ ... d=60150502
https://www.shapeways.com/product/9MC6V ... arketplace
Appreciate any and all help.
- Mark McKinnis
Use the early one for the era you want to do for Nimitz. Bacon Fist used to do the whole Hanger Deck Walls. He pulled them down to modify them to fit better. Hopefully he will put them back out for sale soon.
