1/700 Amagi diorama
dafi
Re: 1/700 Amagi diorama
Post by dafi »
Where can one buy those nice big fingers for the pictures ?
XXXDAn
To Victory and beyond ...
I'm up to "astounding". The rust effect especially so.
marijn van gils
Post by marijn van gils »
Many thanks guys! :)
dafi wrote:Where can one buy those nice big fingers for the pictures ?
I'm not sure... I grew this one myself. Organic is always the best! :)
Marijn
zs180
Post by zs180 »
Mightily impressive work, just what I expected from you!
Strategos Augustus
Post by Strategos Augustus »
I have stickied your thread Marijn for future reference.
I feel a wholesale, blatant borrowing of ideas is in the pipeline.
I wish I could see this in person, it looks like you may have hit a very happy aggregate surface finish. Very plausible for an outdoor lump of wrecked metal.
The dark drybrushing in particular looks like a real success.
I am curious as to what inspired you to do the shadow effect after the other weathering? I have always implemented this type of effect very early in the process where the lack of control with an enamel pinwash is not a problem.
EJFoeth
Post by EJFoeth »
The interesting part about lining in shadows (and adding highlights) by brush, is that you have much more control than a pin wash; the colour is more concentrated and there's little (or no) risk for flooding adjacent parts. When you make an error you can correct it very easily with a wet brush, or remove a bit of the wash if the effect is too strong. It takes more time but in the end the effect is much better. If you add the shadows first, then subsequent washes that are also present fade out the effect a bit, especially lighter washes.
I tried applying Marijn's painting technique with shadows and highlights and I encourage everyone to try it. I'm not expecting to get the same level of quality (because this takes some practice :smallsmile: ), but I did get much better results than with pinwashes. Adding highlights works much better than drybrushing; if you're not careful you can add that 'faded' , sun-bleached look that is very difficult to undo.
Bangor lad
Post by Bangor lad »
Outstanding!
Dave
Currently on the workbench: Tamiya USS Enterprise; Airfix 1/1200 Ark Royal
Fantastic work! Your attention to detail is astounding!
marijn van gils
Strategos Augustus wrote:I am curious as to what inspired you to do the shadow effect after the other weathering? I have always implemented this type of effect very early in the process where the lack of control with an enamel pinwash is not a problem.
Evert-Jan already wrote the most important part:
EJFoeth wrote:If you add the shadows first, then subsequent washes that are also present fade out the effect a bit, especially lighter washes.
I do apply the shading as early as possible, as it is an important defining aspect in my painting style and gives a good bases to continue work on.
But I always apply filters before shading, as the colours of the thinned paints also run into the corners and details like a wash, obliterating the shading in places. I can apply some extra dusty or rusty filters or washes after the shading, but the more general main work is done before.
With Amagi, an important weathering effect is the flaked and rusted areas. As the chipped effect was mostly done with hairspray technique, it was part of the airbrushing process and therefore had to precede shading too. Because of the dusty and rusty effects, the filters also provide a lot of 'effect'. Therefore it may look like I did the shading very late in the weathering process, but in fact it is not.
Other effects follow after the shading: highlighting, reverse drybrushing, dark and rusty streaks and spots, local paint chipping, plate effect, ... while in fact only the filters precede it.
The island didn't receive some of the above effects (simulation of plate seams, paint chipping, rusty streaks) or only very little (dark streaks), so I could finish it more quickly than the rest of the model.
Evert-Jan is also correct about the nature of the control I mean, which is more about the result than about the process: to get the shadows painted exactly where I want them to be, as finely as possible, while having as much contrast as possible.
But there is nothing wrong with a pinwash when done properly, and it does take a lot less time. Lining the shadows with more opaque paint just enables one to go that last 5% further in finesse and contrast, but the time it requires is certainly not for everyone.
Marijn
GewoonWouter
Post by GewoonWouter »
Amazing work again Marijn, and the before and after photos clearly show the effectiveness of the methods used. This is just godsmackingly good I must say. I will try to incorporate some of those techniques on my Yamato once I find the time again to continue.
Needless to say I'm looking forward to see your next update :thumbs_up_1:
Aop Aur
Post by Aop Aur »
...........(no words).... :faint: :faint:
SilverGhost
Post by SilverGhost »
Great job!
Respect!
marijn van gils
Marijn
LE BOSCO
Post by LE BOSCO »
HI Marijn
at each progress, I take a big slap in the face :big_eyes: just sublim ...your are the "Werner" of our hobby :thumbs_up_1:
bravo maitre :worship_1:
cheers
Nicolas
marijn van gils
Merci beaucoup Nicolas! :)
Again some time since the last update� I have been busy though! But the painting effect was pretty time-consuming�
I finished the dirty tidal lines all around the ship, as clearly seen here:
But I followed the (darker) colours of the video, as I used the video as the main reference for the rest of the colours too:
I started by painting a thin line at the top. With a simple homemade device to keep the exact level, I painted tiny faint dots. Then, I connected these dots to a line, eyeballing to get it strait and checking with the device. The edges of the line were blended for soft transitions.
The lower line was painted by eye, using the top line as a visual reference. Next, more lines were painted in between, and the remaining space darkened to varying levels.
The dark lines finished. Note that the intensity is varied a bit, so the effect doesn�t become too uniform. All of this was hand painted around the entire model. That was very time-consuming (about 25 hours I think?), but the only way I could achieve my desired level of control and finesse.
Next, more dirt was painted below the dark lines. I didn�t take step-by-step photo�s of this, as I had to mess around to find what works.
But I will try to summarize:
- Paint a more or less transparent brownish grey zone below dark lines, often overlapping the dark lines too. Blend downwards. Locally paint some transparent ochre and flesh over it to break uniformity.
- Locally paint some base colour (anti-fouling red for example) in irregular line and splodges below the grey zone. Blend downwards, but leave sharp transition to the grey.
- Paint green growth and dirt to the bottom edge, but only here and there. Blend the edges a bit.
Close-up with only the dark lines:
And with the dirt below.
Towards the starboard bow, the photos show some heavier wear, where the paint seems to have been worn away completely. This was painted with light grey paint, with several filters over it (flesh, ochre, brown) to vary the tones. Very dark brown (the same as the dark lines) was used for the dirty �transition� to the grey zone.
Note I also added the dirty waterline stain, from when the ship was still floating upright (compare with historical photos below). Now the sun-bleached anti-fouling red above this line makes more visual sense.
Working around these kind of details while keeping level lines was especially time-consuming:
The decks are only tacked in place with Blu-Tack, necessary to get the levels correct for both flight deck and hangar deck.
The rusted areas didn�t receive a grey zone below the dark lines, but rather a light rusty zone:
Everything was done with Humbrol enamels by the way.
In between, I also finished the stacks.
On the photographs, their interior looks rusted while there is some black soot around the outside edge. I have no idea why it is like that, but I painted accordingly.
First some rust inside with Humbrol enamels:
And soot with black enamel and some black pigment powders:
Cheers!
Marijn
Goodwood
Post by Goodwood »
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
Vladi
Post by Vladi »
Really hard to find the right word... absolutely wonderfull!
At works: USS Astoria CA-34
pascalemod
Post by pascalemod »
Will you mount it on water? Kinda feel like it deserves some perfect water base...
EJFoeth
Post by EJFoeth »
Nice progress! Is the dust applied per brush and left there? Does it need fixation?
And 25 hours on the lines? :big_grin:
Koppalakki
Post by Koppalakki »
Oh yes, this gets me going!
These are those small things that separate you from the rest (putting 25h into painting some black lines :heh: )!
Not many realize how long such small things take if you really want to pull them off!
Damn :big_grin:
Return to “Completed Models”
