Tony Bunch
Post by Tony Bunch »
Hi Guys,
GTDEATH,
That's non-skid atop turret 3. Check your photos for non-skid placement. Oddly, there was none used on the steel foredeck area. The helo landing pad area was all non-skid too. Color for non-skid? Uusally darker than the surrounding deck grey I'd say.
Check your photos for helo pad markings too; variations through time. If you like the 1988 pic, you've got it made.
Good skill!
Tony
Anonymous
Missouri's signal flags identification.
Post by Anonymous »
Hi !
I've just completed a 1/350 USS Missouri, wearing measure 32 camo. Now I'd like to add signal flags to make the ship more colorful.
The pic I found in navsource looked interesting. The problem is I couldn't identiy all of them.
[img]http://i115.photobucket.com/albums/n306/na_nond/flags.jpg[/img]
The pic showed the flags on the portside. I can see 5 rows which I assume flying 5 flags each. Could anyone help identify all the flag she was flying at that time? Should I put the flags on both side? same set of flags? What is the meaning of the signal?
I am interested most the flag No.3 of the row 1., the 2 bottom flags in row 2,3,4,5 (there are alomost totally obscured) and the top flag in row 5.
Thank you for every helps and comments
Nanond N.
GTDEATH13
Post by GTDEATH13 »
NIKOS (NICK)
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Here are my two USS Iowa's in progress.........
1/700 Trumpeter -1984 and Skywave - 1984. (Identical kits.)
The first one that is the furthest along will be out-of-the-box with the addition of PE railings. (I have reference photo that the flag on the #1 turret was sometime during 1986.)
I'll have to snip off the very tip of the top foremast to fit it in the display case that I have. The next step with it is to paint the boot top and cover with a clear flat coat, or two. The small boats and davits will be next after that as well as other small parts. I'm thinking about donating it to the Council Bluffs, Iowa Navy recruiting station. They have a small colleciton of USS Iowa items including a ship's plaque and a huge picture of the Iowa firing off all nine 16" guns. I was the Recruiter In Charge (RINC) of that station back in 1993-94.
The second will be more accurate with the correct decking and colors on the aft section, and a better color for the tan wood decking, the right fighting top which I have started to scratch build, and upgrade parts from JAG and thanks to Tony Bunch for most of them. I intend to add hatches, fire hoses, and PE inclined laddders, etc., as well. I have the GMM New Jersey class PE set, too. And I think I'll make a full hull model.
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
guest
Post by guest »
I'm intrested in making my Tamiya Missouri into a mi-war New Jersey.( or perhaps an Iowa) I know the aa armament, anr the art-deco rounded bridge that the New Jersey had after launching, but I need more detail. Can anyone give me a few tips or point me towards a good reference. I have Friedman's US Battleships, and Sumrall's Iowa class Battleships, but they are not quite specific enough.
Tony Bunch
Hi Guys,
Carl,
Looking good!
Guest,
Just a couple of BigJ pics........
These pics are for you to compare differences.
They'll be of some value to you if you've not seen them before.
I was sitting there looking into my small display case at two finished 1/700 Modern Iowas, and I have just got to build another one!
Tony
First config
First config
second config
second config
guest
Post by guest »
Thanks Tony, that's an excellent view of the bridge.
drdoom1337
Post by drdoom1337 »
Is the round enclosed bridge on the New Jersey sold? I have been itching to convert a 1/350 Tamiya Missouri to a WWII New Jersey
Tony Bunch
Hi Guys,
Guest,
You're quite welcome.
Drdoom,
There is an Iowa bridge set from TMW that would work for the BigJ as commissioned, but no round bridge conversion that I know of. I have seen it done though.
I'll see if I have a pic or two....
Here is Sean F's Tamiya 1/350 BB62.........
Guns Free!
Tony
guest
Post by guest »
What is TMW ?
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
I think TMW is Tom's Modelworks.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
I'll be working on the railings, rigging, and small boats, this week.
Carl Musselman
Photobucket
YouTube Channel:
SeanF
Post by SeanF »
Tony Bunch wrote:Hi Guys,
Guest,
Drdoom,
Guns Free!
Tony
Actually, that *is* a New Jersey round bridge conversion from Tom's Model Works. (I also have the open bridge Iowa conversion set from the same manufacturer - though I haven't used it yet) I bought it a few years back; it may be a bit harder to come by these days, though.
It's actually pretty easy to use - mostly swap out complete parts (or easily removed portions thereof) of the original kit. My sets did have some thin spots in the casting, which I reinforced with a coating of superglue. I had to add the "ears" on the platform just below the forward rangefinder (the replacement for Tamiya part E18), which is just rectangular in the Tom's kit (good for original fit Iowa and NJ, but it needed the extra side tubs for the round bridge era.) The photoetched fret containing the bridge windows wasn't useful; they were too tall. Just use the ones from the GMM Missouri set and curve, splice, and trim them as needed to match the round bridge. I also had to make some modifications to the AA director tubs on the aft funnel... and one 20mm position gor two mounts instead of the Missouri's three... I also noticed that the foremast and yardarms were changed during the round bridge era... there are a lot of details that you need to study photos for, which are not included in the conversion kit instructions. The Classic Warships New Jersey book was very helpful for this, though I believe it's out of print (didn't seem to be around for very long. A shame.) The Tom's set does come with a cast metal OS2U Kingfisher to replace the base kit's SC-1 Seahawks, but I used White Ensign's. Nowadays there are the Trumpeter ones.
One last note: while the open bridge Iowa set instructons say it can also be used for the early 1943 NJ, it doesn't mention the significant AA differences; most notably the diampnd-shaped 20mm tub on the foredeck where a pair of quad 40s is usually seen and the lack of the trademark 20mm tub at the extreme bow. (Note that Iowa herself also started out with this arrangement, but served significantly longer with her open bridge and the classic AA fit; it appears that NJ's AA was revised about the same time as her bridge was enclosed.)
- Sean F.
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
More progress on my out-of-the box USS Iowa by Trumpeter. Main deck railings and helo deck nets are left, as well as a little more rigging and the small boats and the antennas.
Carl Musselman
Photobucket
YouTube Channel:
jgrease
Post by jgrease »
Do you mean "out of the box" as in no aftermarket parts aside from PE? Just wondering as I prepare for the Nats...
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
jgrease,
I'm still new at this and maybe I use the term OTB in error. What I mean, here, is that I haven't done any major modifcations to this Iowa kit. The figting top is all wrong on this model for what the real modernized USS Iowa really looked like, and I imagine that there are a lot of modelers that recognize this. The PE railings and helo pad nets won't be OTB and I'm adding rigging and antennas.
So, if I am using OTB incorrectly I sincerely would appreciate being educated on the term as used by everyone else. :newbie:
My next USS Iowa model won't be OTB, by my definition, for I plan to use JAG turrets and CIWS and GMM Modern New Jersey PE set. I have already started it and this one will be a full hull version from Skywave, which is an identical kit to the Trumpeter, except the Skywave comes with the full hull option.
Thanks for your queston, jgrease. I'm curious about how this affects your preparation for the Nationals. :thinking:
Carl Musselman
Photobucket
YouTube Channel:
jgrease
Post by jgrease »
Carl - it's not affecting my preparations. I'm new to IPMS stuff and their definition was different, and I thought maybe I had missed something. It's my understanding that "out of the box" refers to a kit built only with the parts included by the manufacturer, with the exception of paint and decals. Your build is great. No offense meant. Sorry to have said anything. :huh:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
jgrease wrote:Carl - it's not affecting my preparations. I'm new to IPMS stuff and their definition was different, and I thought maybe I had missed something. It's my understanding that "out of the box" refers to a kit built only with the parts included by the manufacturer, with the exception of paint and decals. Your build is great. No offense meant. Sorry to have said anything. :huh:
jgrease,
Oh, no. No offense, taken here. I've learned something. I won't be so lose with "OTB" in the future.
Have fun at the Nationals. I'd love to go, and I was planning to go, but I have manditory business meetings to attend in Cincinnati.
Carl Musselman
Photobucket
YouTube Channel:
jgrease
Post by jgrease »
Well, this is my first, and hopefully not my last, nationals. If it's half of what others have described it as, it should be quite a good time. Carl, how did you do the wiring on the forward antenna of NJ? I have this kit sitting in the garage, and I was not looking forward to dealing with that.
John
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
John,
I actually hesitated putting the wires on the bow antenna, too.
I did replace the middle vertical pole of the assembly with brass rod. The plastic one didn't seem sturdy enough to hold taught thread. I used "invisible thread" that I found at Wal Mart and then painted it with thinned acrylic Neutral Gray.
After glueing and aligning the upper and lower "wheels" I mounted the assembly in my alligator clip vise.
I found that I could tackle two wires at one time by tying the thread with half of a square knot near the bottom of the assembly, aligning the thread with one set of spokes on the wheels, and super glueing it in place with several inches of extra thread hanging out in both directions.
I then tack glued one side's thread to its spoke on the lower wheel and using insta-set to hold it. Then stretched that same thread up to its spoke on the upper wheel and tack glued it there (insta-set again) and clipped off the access. I did this same thing to the opposite side's thread and abbracadabra I had two out of eight wires done.
I tied the remaining three threads under the first thread's bottom knot, aligning each to its respective set of spokes, and did the same as above.
The only thing wrong with mine, and I noticed this detail in photos afterwards, is that the wires don't attach to the tips of the upper wheel spokes, but at the wheel's hub.
I haven't permanently attached the antenna assembly to my model, yet, and I have a second kit that I will be making which has the identical antenna in it. Since I will be making the second model using GMM Modernized New Jersey PE set which has PE wheels for this antenna, I will probably rebuild the first antenna assembly from this second kit's leftover parts.
The PE antenna wheels may be too, flimzy for adding the wires to it, but I'll give it a try.
Good luck with yours!
Carl Musselman
Photobucket
YouTube Channel:
