Calling all USS North Carolina BB-55 & USS Washington BB-56 fans
guest
Re: Calling all USS North Carolina & Washington fans
No one noticed the funnels are completely wrong but yet you're wondering about the scale diameter of the 16" rifles? None of you geniuses have calipers? Total :censored_2: in outline like most of Trumpeter's models. I've been on the real ship many times and viewed it from the other side of the Cape fear river and know this model looks WRONG.
- Model Monkey
Some good news! Accurately shaped, sized and detailed 3D-printed products for North Carolina class battleships are available in several popular scales:guest wrote:No one noticed the funnels are completely wrong but yet you're wondering about the scale diameter of the 16" rifles? None of you geniuses have calipers? Totalin outline like most of Trumpeter's models. I've been on the real ship many times and viewed it from the other side of the Cape fear river and know this model looks WRONG.
Here is a sample for 1/350 scale.
Funnels: http://shpws.me/O8YC
16"/45 cal. turret set (barrels are accurate, too): http://shpws.me/OBzG
5"/38 cal. twin-gun mount set with fixed trunnions: http://shpws.me/MCrd
5"/38 cal. twin-gun mount set with separate trunnions: http://shpws.me/MCrf
Mk.37 directors (angle-back): http://shpws.me/Obpc
Mk.38 directors: http://shpws.me/NW0D
Ready service ammunition lockers for 20mm Oerlikons: http://shpws.me/P98f
Most of these products are also available in 1/570 (for Revell) and 1/700.
If you are building USS North Carolina as she appeared after a fatal 1945 friendly fire accident destroyed the functionality of her port-side Mk.37 director, you'll need a single square-back director. The one damaged angle-back was replaced with a square-back (see photo below). 3D-printed "square-back" directors are available, too: http://shpws.me/JEkF
Please take advantage of Shapeways' FREE SHIPPING offer for sales of more than $25 on "Cyber Monday", November 27th.
- ArmchairAdmiral
In doing some BB research, I've run across a curious discrepancy. Depending on the source, NC is credited with either 12 or 15 WW2 battle stars. DANFS says 15, but several books, including Alan Pater's "United States Battleships," say 12.
I have not run into this discrepancy with any other BB, and I'm wondering if anyone knows the reason for the difference in numbers. Pater lists the 12 as follows:
1 star Guadalcanal/Tulagi landings, 7-9 Aug. 1942
1 star Battle of Eastern Solomons, 23-25 Aug. 1942
1 star Gilbert Islands operation, 19 Nov.-8 Dec. 1943
1 star Marshall Islands operation, 29 Jan.-8 Feb. 1944
1 star Asiatic-Pacific raids, 1944
1 star Western New Guinea operation, 21-24 Apr. 1944
1 star Marianas operation, June 1944
1 star Leyte operation, Nov.-Dec. 1944
1 star Luzon operation, Jan. 1945
1 star Iwo Jima operation, Feb.-Mar. 1945
1 star Okinawa Gunto operation, 17 Mar.-27 Apr. 1945
1 star 3rd Fleet operations against Japan, 10 Jul.-15 Aug. 1945
The NC website lists three more campaigns, but battle stars are not mentioned, although I assume these are the missing ones:
Capture and Defense of Guadalcanal August 16, 1942 � February 8, 1943
New Georgia Group Operations June 30 � August 31, 1943
Bismark Archipelago Operations December 25, 1943
- ArmchairAdmiral
- pascalemod
Actually it was 15 battle stars and she happens to be the most decorated US Battleship of WW2 to boot.DavidP wrote:North Carolina received 12 battle stars for World War II service.
http://www.hazegray.org/danfs/battlesh/bb55.htm
- pascalemod
Question regarding boot topping placement on Trumpeter 1/700. Do I put it above the hull break point or below or split it in between? Im building a full hull. I put it BELOW hull break and it looks off a bit. Help?
- pascalemod
Is there a schematic out there for Measure 12 Modified (splotches) camouflage that Washington wore in the Atlantic? I am talking the one with navy blue hull, ocean gray superstructures mixed with some haze gray tops. I assume the decks were already navy blue also.
I found only this one so far which Im not sure is accurate and only one sided...
Ian Roberts
I drew the color profile you've attached - it was drawn using photo references only, since (as far as I can tell) there are no decent schematics available that show the pattern, and the USN did not issue design patterns for Ms12mod as it did the Measure 31-32-33 patterns. There are several good photos available on Navsource that show the starboard side of BB-56 I used to get the pattern as correct as possible. The ship itself was plotted from Floating Drydock plans of BB-55 in 1942 and modified accordingly. I drew six versions of North Carolina throughout her wartime service life as well - all the class drawings I made are available here: http://shipbucket.com/drawings/search?c ... h+carolina I generally do not make portside profiles except in rare cases.
- pascalemod
Love your work man! Ok Can you specify - the tip top part of bow section is that haze grey or ocean grey?Colosseum wrote:I drew the color profile you've attached - it was drawn using photo references only, since (as far as I can tell) there are no decent schematics available that show the pattern, and the USN did not issue design patterns for Ms12mod as it did the Measure 31-32-33 patterns. There are several good photos available on Navsource that show the starboard side of BB-56 I used to get the pattern as correct as possible. The ship itself was plotted from Floating Drydock plans of BB-55 in 1942 and modified accordingly. I drew six versions of North Carolina throughout her wartime service life as well - all the class drawings I made are available here: http://shipbucket.com/drawings/search?c ... h+carolina I generally do not make portside profiles except in rare cases.
Hard to tell but your drawings imply haze gray and I foind it hard to believe they used haze grey.
Ian Roberts
Apparently in 2014 when I drew it, I made the judgment that the bow section was 5-H Haze Grey (though now I'd probably leave it as 5-O). From reading this forum, it seems like it wasn't unheard of for some ships to paint the Ms12mod pattern outside regulations (and this seems to have included carrying 5-H into areas that shouldn't have had it, etc).
From consulting photos again (especially this one), I think I need to go revisit that area of the drawing and change it from 5-H to 5-O. I'm not sure why I originally thought that area was lighter... maybe a comment in this thread somewhere? Either way - the tone of the bow panel matches the tone of the No.1 turret so I think it's definitely 5-O. Interesting to note is the way the 5-N on the hull seems to curve upwards between the two forward turrets.
- pascalemod
It all makes sense though, doesnt it? The camo is inspired by rough seas and gray sky. So you got some high waves on front somewhere. Really like this camo a lot more than MS22. Thanks for making that drawing, it helps me in my modelling, wish there was another side and turrets. Turrets should not be colored on top as deck blue btw.Colosseum wrote:Apparently in 2014 when I drew it, I made the judgment that the bow section was 5-H Haze Grey (though now I'd probably leave it as 5-O). From reading this forum, it seems like it wasn't unheard of for some ships to paint the Ms12mod pattern outside regulations (and this seems to have included carrying 5-H into areas that shouldn't have had it, etc).
aercastro82
Can anyone please inform me about BB-56 USS WASHINGTON fire control radars that were installed on the MK-38 Gun Directors in late 1942.
According to the following links,
the forward and the aft MK-38 directors carry the early MK-3 Mod.1 radar in August 1942
http://navsource.org/archives/01/056/015610.jpg
http://navsource.org/archives/01/056/015610a.jpg
https://www.navsource.org/archives/01/015626.jpg
Now in November, the forward MK-38 carries the MK-3 Mod.2 radar but what about the fire control radar on the aft MK-38?
It appears to be a MK-8 Mod.0 fire control radar? Is this correct?
Can anyone explain when MK-8 Mod.0 FC radars were installed on ships or on the BB-56?
http://navsource.org/archives/01/056/015673b.jpg
I appreciate for the response.
Frank Fowler
I think the photo you reference last is much later than November 1942. The Navsource caption for the photo only states it is after the November 13 battle, but not how much after. There are two other things in the photo to look at that would indicate a much later date. First she now has quad 40 mm guns in place of the 1.1 inch AA guns and second the demarcation line for the 5N paint on the lower hull curves down so that it runs below the anchor. From August 1942 to after the November battle the 5N line ran through the anchor and she was armed with 1.1 inch mounts and not 40 mm. I think the radar she had in August 1942 was still the same in November 1942.
- pascalemod
Is there a good info on radars that Washington carried in its North Atlantic mid 1942 fit? BEFORE moving to Pacific basically. What difference was vs Guadalcanal, in other way of asking. Trumpeter kit 1/700 is all over the place - its clearly pre Guadalcanal hull but not sure about radar setup.
It had the rather nice patchy camouflage, MS12 Modified.
Daytona675R
The mid-1942 radar package included (see the picture below): - One CXAM-1 air search radar on a top of the foremastpascalemod wrote:Is there a good info on radars that Washington carried in its North Atlantic mid 1942 fit? BEFORE moving to Pacific basically. What difference was vs Guadalcanal, in other way of asking.
- Two Mark 3 Mod. 1 fire control radars on a top of both Mark 38 directors
- Three Mark 4 fire control radars on a top of the forward, port and starboard Mark 37 directors
The following modifications were done in 8/1942, before BB-56 sailed to the the Pacific:
- One SG surface search radar was installed on a front side of the superstructure tower
- The fourth Mark 4 FCR was placed on a top of the aft Mark 37 director
The next alternations were done in 7/1943 and are depicted on this picture:
- The CXAM-1 was replaced by the SK air search radar
- The SG radar was moved on a top of the foremast
- The forward Mark 3 Mod. 1 FCR was replaced by the Mod. 0 variant
- The aft Mark 3 Mod. 1 FCR was replaced by the Mark 8 FCR
During the spring-1944 repairs following the collision with USS Indiana, the radar package was modified again:
- The forward Mark 3 Mod. 0 FCR was replaced by the Mark 8 FCR
- The second SG surface search radar was placed on a top of the mainmast
- The Mark 27 FCR was placed just above a top of the conning tower
Before the end of the 1944, the Mark 4 FCRs were switched to the Mark 12/22s
The final alterations were done between 6/1945 and 9/1945 and can be seen here:
- The forward Mark 8 FCR was replaced by the Mark 13 FCR
- The SR air search radar was placed on a top of the mainmast
- David
- pascalemod
holy cow, I did come to the exactly the same conclusions you posted, but through a ton of research. Wish this was there. This should go to front page of this thread or something. Thank you.Daytona675R wrote:The mid-1942 radar package included (see the picture below): - One CXAM-1 air search radar on a top of the foremastpascalemod wrote:Is there a good info on radars that Washington carried in its North Atlantic mid 1942 fit? BEFORE moving to Pacific basically. What difference was vs Guadalcanal, in other way of asking.
- pascalemod
Question time: the masts on Washington, before the Pacific tour, so early 1942.
How did the rear mast look like? Just straight up with yardarms across? What shape of yardamrs? rounded or square edged?
Same goes for front mast yardarms - square edged, triangular shaped or they are rounded?
Cant see any good photos of that time and rear mast was remodelled for Pacific so Im really confused about that one. Appreciate all the help if anyone has good photos.
- Captain Morgan
?? But if you on the site you list go to the history of USS North Carolina (III) you get thisArmchairAdmiral wrote:According to this version of DANFS, it's 15.
https://web.archive.org/web/20091011033 ... na-iii.htm
It shows 12 battle stars, battle stars are different from unit citations and campaign honors, and it sort of becomes apples and oranges if you know what I mean.
Oh
Oh
Earlier it was mentioned using photographs to substantiate mast arrangement, radars etc. Do note that photographs of such ship portions were often retouched to make less information available about possible electronic installations.
Cheers: T
Cheers: T
- pascalemod
Which page here has the rigging diagrams for USS Washington? Whats a good source? I want the early war Washington, not late war, so pre Pacific, ideally.
