1/144 Kiev by Dave Wooley
Re: Dave's Kiev
Post by Dave Wooley »
Hi Martin Thanks for your kind words . Long way to go but the painting is one of the jobs ready to do and there's plenty of that. I am going to give WEM a ring as I know they will supply the right shades for the Kiev in the time period 1985. At the moment I'm working on the elevator shaft , problem is the information is very sketchy so some guess work will be the order of the day.
Neptune
Re: 1/144 Kiev by Dave Wooley
Post by Neptune »
Hiya Dave,
I've finally succeeded in finding a video of the Trap Door radar. Unfortunately it was only shown in a video and I can't take screenshots of that.
From what I saw, hold your desk tight now, the lid has a Front Door guidance radar (as the one mounted on the Slava class main mast forward) underneath it. Practically it comes up after the launch of the Sandbox missile, with the radar sitting on a support that is connected to the door.
Now that you know it, will you make it???? :heh: I'll try to get that video or part of it to you.
The merchant shipyard
kalkurap
Re: Kiev by Dave Wooley
Post by kalkurap »
Dave,
You have got me confused about the scale. For all these months I thought this is a 1/144 scale build. But it is 1/96 per the title of the thread. Which one is correct?
-Prasanna.
INS Veer: 1/100 scale, under construction!
ARH
Post by ARH »
Dave said this at the beginning,
If there is a genuine interest out there and there seems to be. I'll crank up the build to commence some time either late Feburary to early March . As I need to conclude a number of pressing projects , one of which is a book due at the publishers at end of April for publication in the fall of 06. Plus of course order in the running gear, props, motor and stock up on building materials for such a large project . Even though KIEV is only 1:144 it is still a monster model. Now you have got me going !
Simple but effective.
GTDEATH13
Post by GTDEATH13 »
Will the Kiev have an airwing???
Great job and thank you for sharing the details of the proccess.. Really inspiring work.... :wave_1: :wave_1:
NIKOS (NICK)
Hi Nikos My apologies for not replying sooner . Regarding your question about the airwing . I hope to be displaying 8 Yak 38s and 4 KA25s . More up dates to follow shortly. Also thanks Neptune for the info on the Trap Door.
Dave Wooley :thumbs_up_1:
At last we on the move again
The Boat recess and davits
As mentioned before the boat recess or bay is aft , both port and
starboard and was formed with the GRP hull. Trick is �How to install
all the equipment and detail in a space surrounded on three sides�
Simple make a removable recess.. This is how it was done.
The clean recess in the GRP hull
Next stage was to select the material for this job
The internal space is measures and using 1 mm styrene the inner walls
are cut to size. This takes into account the sloping ends and dividing wall
The recess is divided into two bays , each housing a different type of boat.
With all the section bonded together the inner lining { Boat recess]
can be easily removed.
Lifting the shape of the Davit from the drawing . The next stage was to
cut to size each davit. There are 2 pairs of davits per recess. Each
davit is made up of a left and right hand side.
Taking the strip of 2.5mmx1mm styrene , sections are cut to size that
conform to the shape of the davit , these separate the two sides and
as in the real davit form part of the slide for the boat.
Each of the davits are temporarily set in to place with in the recess.
To help in giving a better seating for each set of davits a strip is placed
on the base .
Four sets of Davits in place and they fit!
Now for fitting out the interior.
ARH
Post by ARH »
Another nice up date Dave, good to see how you do it. :wave_1: :wave_1: :thumbs_up_1: :thumbs_up_1:
Thanks Ron more to catch up on .
bismarck builder
Post by bismarck builder »
hi david
you make it look so easey
i picked up your book from a second hand book shop in plymouth while on holiday
gary
Re: 1/96 Kiev by Dave Wooley
Hi gary I turst you will enjoy the book. Have you seen the Bismarck build pictures?.makes your mouth water?
Tom-Tom
Post by Tom-Tom »
Very impressive work. I'm amazed how styren sheets become such a beautiful ship !
Moving on to the interior detail .
The centre separating bulkhead wall is fitted each side with vertical
strengthening strips and the first of a number of platform walkways .
More of the walkways are added to the rear bulkhead
One of the platform walkways being made up from 1mm thick styrene sheet.
An outer rail support is added using 2mm by .50mm Evergreen strip
PE four bar rails are added to the platform walkway
PE three bar rail is added to the rear bulkhead platform walkway .
The boat bay is placed into position three views
The next stage is to fit the remainder of the detail. Which consists of piping ,
vents, boxes which can only be undertaken as originally intended outside the
boat recess .
The davits are placed in position
The boat bay is once again offered into position .
The boat recess takes form .
With the advantage of a removable boat bay, rigging the davits and
fitting the motor boats to the davits will be a whole lot eaisier. There is
more detail to be added but the focus for next time will be Kiev's
motor boats
J. Soca
Post by J. Soca »
Outstanding job Dave !! :thumbs_up_1: :thumbs_up_1:
Jose
desron48
Post by desron48 »
this gents........is model building at it's best...... :thumbs_up_1: .....joe
GTDEATH13
Post by GTDEATH13 »
Dave Wooley wrote:Hi Nikos My apologies for not replying sooner . Regarding your question about the airwing . I hope to be displaying 8 Yak 38s and 4 KA25s . More up dates to follow shortly. Also thanks Neptune for the info on the Trap Door.
No apologies are needed... :wave_1: :wave_1:
I found the russian navsource and thought I should post a link so that the rest of us see the gracefulness of your build. There are 3 pages of photos just click the links at the bottom of the page... In case you do not copy russian the links are :(??????????, ????? 2. ??????????, ????? 3.)
http://www.navsource.narod.ru/photos/02/161/index.html
I think I will get me some kirovs, a kiev, a kuznetsov and build a soviet battlegroup... After I finish the 11 ships and 5 planes I am currently building... :crazy: :crazy: :crazy: :thinking: :flamed:
NIKOS (NICK)
Kiwimedic
Post by Kiwimedic »
Hi Dave
Realy - Realy - nice.
All those little details you are putting in..
Little boxes on the bulkheads (Probably electrical boxes.)
Strengthening gussets. Handrails that are clean and crisp.
Lovely watertight doors.
Not always easy to see but they are there.
These are the things that put a model right up there, above all others.
A great thing you also do is to show us all how to do it with your very informative (How To) photographs.
Far North
Philip
Thanks Phil always happy to oblige if it helps .
Laurent
Post by Laurent »
Hi Dave ,
wonderful details you've put in there :thumbs_up_1:
Regards ,
Laurent
Thank you laurent . Hope to post more material in the next few days. :thumbs_up_1:
