Calling all HMS York and HMS Exeter (WWII) fans
- Brett Morrow
Re: Calling all HMS York class (HMS Exeter-WWII) fans
These may also assist you James provided the arrangement of a County was the same or similar for Exeter.
The outer shaft bracket of a Kent appears to have a slight bow in the struts, this may in part be an optical illusion? your call
Note that on a London class the outer shaft bracket had straight struts.
The inner shaft bracket had a change of angle in the lower strut giving it a slight upward angle into the hull, this was the same as the Kent.
EJFoeth
Doesn't appear to me that the struts have a twist. Don't know when the first fully flow aligned struts were introduced though.Brett Morrow wrote:The outer shaft bracket of a Kent appears to have a slight bow in the struts, this may in part be an optical illusion?
KevinD
Brett, does the original of this photo (below) you posted extend any further at the bottom of the print? If so could you please post it.
Has nothing to do with Exeter, but I would be very interested to see what the connection (to the prop) looks like at the other end of that length of shaft sans prop, as this is the length of shaft that pulled away (along with the prop) on HMS Prince of Wales when the port outer prop + length of shaft separated (at the flange I have now arrowed in your photo): but not before pulling a long length of an inboard shaft section out / 'backwards' with it, so that that inboard length now (or did before salvors had at her) hangs out-board (as in 3D image further below).
- Brett Morrow
Is this what you wanted to see Kevin ?
KevinD
Yes sir!Brett Morrow wrote:Is this what you wanted to see Kevin ?
That is certainly a long length of shaft. It and the outer port prop off PoW are laying somewhere on the seabed well away from the wreck, if a scavenger hasn't stumbled on them first that is.
KevinD
Thanks for your reply Chris.
Yes the Java Sea is warm, and nowadays completely shark free (fished out), back then probably not though. I didnt see one in eight years of diving there. Whereas in some locations you see them on almost every dive. Before all those ships sank and became 'artificial reefs' there was little there in the 'central' Java Sea in the way of reefs to attract the smaller fish the sharks feed on; except right next to some of the few islands there, which are mainly to the far north west, save for Bawean.Chris G wrote:Mr. Dunleavy the man who was on the crew of Exeter when sunk said the ocean was suprrisingly warm and they didnt see any sharks which was a blessing.
I think he would have had to been, as I don't recall any Exeter chaps surviving any other way, i.e. except from being picked up either that day or the next by the Japs.Chris G wrote:I am not sure how he got picked up, i dont think he was captured by the Japanese...dont remember that being the case.
Please don't think for one minute I am questioning your / his account, as I am not. He may certainly have been one of the lucky ones in the left hand gun crew by all means.Chris G wrote:.......could be wrong about what i remember he showed me as his action station it may have been on the other side of the ship. I am lucky I remember as much as I do for it was now 45 years ago.
Two detail questions - the first involving the above post (link to origiginal). Port and starboard outboard of the funnels we have a 36' pinnace (port) and a 35' motor pinnace (starboard). Micromaster has a 36' motor pinnace, a 36' sailing pinnace. Would it be safe to presume that the 36' pinnace in the plans is a "sailing" pinnace, lacking the "motor" in its title?KevinD wrote:EJ, below is a clearer version of the text for the boats. Biggest size image I could make / post given the 400kb file size for posting here.
Second, they recently released two rangefinder sets, a Barr & Stroud 9' F.Q.2 and a Barr & Stroud 12' F.Q.2. Both product pages state "used on most mid to large sized capital ships in WWI and WWII." but I note the 9' variant has "Leander class" in the URL. Research suggests these were too old for Exeter, but I haven't been able to find anything on what look like optical rangefinders that were on Exeter's bridge. Anyone have any info about the identity of these pieces of equipment?
KevinD
Can't thelp with your first question, but the below might help with your above. However, if you are after the actual manufacturers name of the RF's on bridge then..................it wont. (This excerpt is from same plan as in previous, i.e. 1930.)Tracy White wrote: Second, they recently released two rangefinder sets, a Barr & Stroud 9' F.Q.2 and a Barr & Stroud 12' F.Q.2. Both product pages state "used on most mid to large sized capital ships in WWI and WWII." but I note the 9' variant has "Leander class" in the URL. Research suggests these were too old for Exeter, but I haven't been able to find anything on what look like optical rangefinders that were on Exeter's bridge. Anyone have any info about the identity of these pieces of equipment?
At bottom is the coral encrusted RF on port side of Exeter's bridge (on wreck). Must say, although everything seems much smaller when swimming around them, I would never have thought they were 12ft (almost 4m) across, but..............I guess they were (unless of course replaced with smaller version during 1940 refit).
- Maarten Sch�nfeld
Here's an extensive overview of all Barr & Stroud rangefinders, including drawings. Maybe you may find the exact type. I note the sizes are in metres, so maybe you have to convert feet to metres.http://www.dreadnoughtproject.org/tfs/i ... ers#F.G._4KevinD wrote:Can't thelp with your first question, but the below might help with your above. However, if you are after the actual manufacturers name of the RF's on bridge then..................it wont. (This excerpt is from same plan as in previous, i.e. 1930.)Tracy White wrote: Second, they recently released two rangefinder sets, a Barr & Stroud 9' F.Q.2 and a Barr & Stroud 12' F.Q.2. Both product pages state "used on most mid to large sized capital ships in WWI and WWII." but I note the 9' variant has "Leander class" in the URL. Research suggests these were too old for Exeter, but I haven't been able to find anything on what look like optical rangefinders that were on Exeter's bridge. Anyone have any info about the identity of these pieces of equipment?
Roger Whittaker +9/13/2023
KevinD
Thanks for that link Maarten. While I'll leave it to others to ID the rangefinder type, the one historical photo there works well for illustrating 'something' on Exeter's bridge (on wreck). Or did before the wreck 'disappeared'. Photo shows collapsed remains of a voice pipe and Pelorus stand.
KevinD
Does anyone have a close up photo (or schematic / drawing) that they could post of the type of High-Angle Control Tower that was fitted to Exeter just aft of her 8" gun director during her 1940 refit? It doesn't have to be 'from / of' Exeter, but just the same type as on Exeter.
If so. much appreciated.
KevinD
And today the 79th anniversary of HMS's Exeter and Encounter and USS Pope's sinking (and 'last' night USS Houston and HMAS Perth). RIP those lost.
Marco
While painting the hull and starting to paint deck details on my HMS Exeter (Trumpeter 1/350), I realized that, apart from the planks below the chains being Dark Gray (Which Trumpeter instructions got right), the chains are LIGHT Gray??? Seems like a peace time thing, but I guess that they were still Light gray when the Battle of the River Plate happened a few months later than this picture was taken. The Dark Gray plank gives me all the impression of it being raised above the deck level, like a carpet or something, not really worth representing in 1/350 but interesting.
Marco
Marco
- DrPR
The surface beneath the chain was probably steel. The chains would grind into wood pretty quickly.
Can't tell from the photo, but was the ship at anchor or at sea?
If the ship was at anchor they would have run the chain out almost to the end. In the US Navy (and perhaps the Royal Navy) the very end of the chain was painted red, and before that it was yellow. The yellow links were a warning or signal that the chain had been payed out far enough. If the chain could not be stopped and the red links came on deck it was a warning to clear the area. If the chain ripped loose from it's attachment in the chain locker, when the end came on deck it would flail wildly and anyone or anything struck by it could be sliced in half.
Telling tonality from black and white photography requires hints such as sky value from which we may attempt to deduce filtration or even if it's a panchromatic film. Given that photo is from above and outboard the main deck, one would guess at dock or in a raft of ships. Red filtration is commonly used to accentuate the sky and clouds, and a red painted chain. Sometimes in such period photos a hull red will look almost white.
Tom
Tom
KevinD
The ship was docked in Philadelphia late 1938 (Edit - WRONG: was 'early' 1939). Am not at my computer (but am now) but can post the full photo later, or I think it 'may' already have been posted somewhere in this thread.DrPR wrote:Can't tell from the photo, but was the ship at anchor or at sea?
The below is on the back of the hard copy I have.
- Iceman 29
To complete Phil's message, the wheel that is operated is the windlass brake :DrPR wrote:The surface beneath the chain was probably steel. The chains would grind into wood pretty quickly.
https://youtu.be/b7pRfix_sNg
Pascal
OK, so which BF "appears" to have failed to shackle the end of the cable to the deck clench? Someone had blundered. More to the point why was the ship running the cable out to a "clench" anyway?
Marco
Thanks for your comments. I have the impression that during peace time, the chains were painted light gray, as it shows in several pictures, like this one at the entrance of the Panama Canal, 1934. Shallow waters.
I found one picture, though, showing black (or dark) colored chains, Panama canal as well, and I had the same date for both pictures, evidently wrong date (either that, or the British were bloody fast changing anchor chains!!!).
Marco
Marco
KevinD
Don't you think that the different 'colour' is just the dramaticaly different tone / contrast within the two photographs? That is, the deck, etc, looks almost white in the overhead (and the water black), whereas in the smaller photo the whole image is just various shades of grey from light to dark.
