The top plate has now got the main switch and the LED's to indicate power has applied mounted.
The LED's will be connected with a resistor to the fuse and then to the - fuse so I can be absolutely sure whether a fuse is burned or not.
I dropped the - fuses for the groups, leaving the main fuse as only - fuse with it's Amps being lowered from 30A down to 7,5A since there shouldn't be any current at this fuse.
All fuses will be attached to the 12V supply, the lower voltages will be created a bit further down the line by voltage regulators which will be placed in the central computer.
This is the bottom of the plate as of now.
I had to cut a bit out of the plate so I could fix the main switch but now it's properly attached.
I also had to drill a larger hole from the under side of the plate for the LED's so they would have an edge near the top which they stick behind whilst they do raise above the top of the plate.
Tomorrow I will start wiring things up, after that the LED's will be properly attached as well so I can remove the tape afterwards.
Greetings Josse
