Name plates were removed for security reasons. CV-6 is odd in that she did not have a 6 on her hull fore and aft as her sisters both displayed hull numbers. My guess is PHNY painted her. Norfolk painted both CV-5 and CV-8. The ring is a DF Loop antenna. The little platform rings at base of the boat crane were added to CV-5 and 6 prewar. CV- 8 seems never to have had them added.Charybdis wrote:Fascinating. Thanks for the info.
A couple of interesting points; I notice no number 6 or a name plate across the stern. Censored perhaps or was CV-6 different from her two sisters in this respect? Do you know what the small ring is just forward the aft 20mm on the stb side? There also seems to be a small overhang around the base of the crane on the main deck. I'm sure this wasn't as built.
Thanks again.
- Michael Vorrasi
Mike
- TOMLABEL
The letters of the name of each of the Yorktown class were welded to the hull (as are the names of the battleships). They were painted over when hostilities broke out. The Yorktown's name (letters) are still visible in the Ballard photographs of CV5 taken during his expedition and the stern section of the Enterprise's name were salvaged and put on display in New Jersey. The "E" of the Enterprise is visible in the drydock photo showing the stern damage port side from the Solomon's campaign.Charybdis wrote:A couple of interesting points; I notice no number 6 or a name plate across the stern.
And they are visible in the photo of CV6 that you posted as well.
Kelley
- CV6 NameCutOut.jpg (44.91 KiB) Viewed 6431 times
- Bama 100_1418.jpg (20.4 KiB) Viewed 6431 times
- Michael Vorrasi
Kelley, quite correct. The embossed metal letters on the stern were not removed, but painted over in the base hull color. In fact, the photo we are discussing shows the embossed letters clearly under the degaussing cables in a better lower contrast copy of that shot I have saved on the HD. The OP mentioned name plates. i was thinking of the name plate Hornet displayed on her forecastle while finishing up at Newport News. See here, look at it in at least medium size:TOMLABEL wrote:The letters of the name of each of the Yorktown class were welded to the hull (as are the names of the battleships). They were painted over when hostilities broke out. The Yorktown's name (letters) are still visible in the Ballard photographs of CV5 taken during his expedition and the stern section of the Enterprise's name were salvaged and put on display in New Jersey. The "E" of the Enterprise is visible in the drydock photo showing the stern damage port side from the Solomon's campaign.Charybdis wrote:A couple of interesting points; I notice no number 6 or a name plate across the stern.
Kelley
http://www.history.navy.mil/our-collect ... 26371.html
Mike
- TOMLABEL
Wow!!! Nice pic! I see the nameplate that you referenced. I might have mistaken the OP original question (I've never seen that pic) but yes, all visible identifying information on ships were removed/painted over as Mike said for security/operational reasons to elude and confuse both friend and foe.Michael Vorrasi wrote:The OP mentioned name plates. i was thinking of the name plate Hornet displayed on her forecastle while finishing up at Newport News. See here, look at it in at least medium size:http://www.history.navy.mil/our-collections/photography/numerical-list-of-images/nhhc-series/nh-series/19-N-26000/19-N-26371.html
Mike, nice information on another example of the differences between PHNY and Norfolk's practices!!! I always wondered why CV6's numbers weren't visible and CV5/8's were. Given the different shapes/structures of the AA tubs/etc and now identification numbers, it seems like there was a mild disconnect or preference (or orders) between the two.
Thanks Mike!!!!
Kelley
- John W.
I have never figured out how painting over the ship's name, while displaying a number - the actual hull number no less - in a contrasting color and larger in height than the ship's name was, how that provided any OPSEC. Really?TOMLABEL wrote:Wow!!! Nice pic! I see the nameplate that you referenced. I might have mistaken the OP original question (I've never seen that pic) but yes, all visible identifying information on ships were removed/painted over as Mike said for security/operational reasons to elude and confuse both friend and foe.Michael Vorrasi wrote:The OP mentioned name plates. i was thinking of the name plate Hornet displayed on her forecastle while finishing up at Newport News. See here, look at it in at least medium size:http://www.history.navy.mil/our-collections/photography/numerical-list-of-images/nhhc-series/nh-series/19-N-26000/19-N-26371.html
Thanks Mike!!!!![]()
Kelley
I remember during the Cold War, the Soviets used false pendant numbers on the side of the hull - that made some sense to do that. I even saw an instance or two where they had painted different pendant numbers on different sides of the same ship. Of course, if an aircraft "rigged" the ship, it would make at least one pass down each side of it so the jig was up pretty quickly.
- TOMLABEL
Re-posting, just in case it was missed last week.
Kelley
Kelley
TOMLABEL wrote:Hey guys!
Does anyone know (or have a good idea) what the canvas looking structure/container is mounted to the side of #2 1.1mm gun tub? At first I thought that it may be for expended shells, but the tub shields have cutouts in them where they could be kicked out of the tub when necessary. I'm at a loss on this one.
Also, curious if the Yorktown class carriers had green tinted glass in the skyward pointing windows of the Pri-Fly and fighting top like the modernized Essex's had. It doesn't look like it in photos, but its not absolutely conclusive. Does anyone know about this or have a good guess?
Thanks.
Kelley
- TOMLABEL
I received my Infini-models Yorktown set for the Merit kit as well as the flight deck set today and have to say that I am beyond impressed to the extreme!!!
Actually, I'm pretty overwhelmed by how many areas are covered in such great detail that aren't even shown in the photos posted by Infini-models in the Manufacturer's section of the forum. I can really see that a lot of time went into researching this set and I hope my modeling skills are on par to even do this set justice!!!
I'd like to call out Tracy White (as he is referenced in the EXCELLENT color instruction guide) for providing what must have been tons of research materials and thank him for this and all the time he must have spent with Infini-models to make sure all was done to a very high standard I thought not possible or feasible!!!
I've waited a very long time for a great 1/350 scale kit of the Yorktown class to finally be done and Tracy and Infini-models have just added the very sweet icing on the cake!!!
A BIG THANKS!!!
Kelley
A BIG THANKS!!!
Kelley
- robertmelvin
Kelley, I'm glad to hear what you have to say. I just ordered mine today. No doubt there will be a follow on Enterprise set so there goes another $300.00 or so.
Bob M.
Bob M.
CyberGolem
My guess is that the paint has been worn down by numerous landings. At the risk of sounding snarky, but that's where the pilots hoped to make contactjabarry wrote:I always wondered if she got a new coat of deck stain, and/or maybe just markings during the repairs as the markings on the rear of the flight deck look different between the two photos below. The first is at Coral Sea and the second at Midway. It could be the color, angle, lighting... etc that makes the narrower center dashes seem absent in the Coral Sea photo. They were in such a rush during the emergency repairs I don't think they would have bothered. But if there is plenty of manpower around - who knows.
CyberGolem
Great point and in addition; paint gets really slippery when wet�stain maintains the texture of the wood and is also far less prone to other typical weathering as well due to the aforementioned penetration feature.Michael Vorrasi wrote:Key words "EXCEPT ON SUBMARINES AND CARRIERS" all decks were PAINTED. Instructions for staining carrier decks were in separate documents, and that passage has caused confusion for many years. All decks were painted with deck blue as opposed to stained. Only carrier decks used blue stain. From fall of 1941 through 1942, carrier decks, including Yorktown's, used Norfolk 250N blue stain. Reason for stain is penetration. Carrier decks took a beating and stain penetrated into the wood, so the color ran deep enough that scuffs and scrapes would not expose raw wood easily, as a painted deck might. Also, their flight deck wood was rougher than the typical holy-stoned teak on a battleship or cruiser. Those dense wood decks would take paint much better, whereas stain might just fail to penetrate and just rub off such a hard dense wood.DavidK wrote:If the Tamiya instructions call for Navy Blue, then they're incorrect. Yorktown was so busy in 1942 that she never had time to repaint from her original Measure 12 into the updated Ms 12 with 5-N Navy Blue or the blotchy Measure 12 Modified (like Hornet). So, you actually need 5-S Sea Blue and 5-O Ocean Gray with a touch of 5-H Haze Gray.
Could someone help with this quote from the Measure 12 description as it pertains to the Yorktown flight deck:
"Wood decks except on submarines and carriers shall be darkened to the color Deck Blue. Deck Blue paint shall be used in lieu of stain for this purpose."
Does this mean Yorktown's flight deck was not Deck Blue?
Dave
CyberGolem
Just curious; why wouldn't the island conversion work for the Merit 1:200 kit?Michael Vorrasi wrote:Tracy White wrote:Well, for one, if the Manufacturers section prunes, I'd say pop the stuff in here directly so that future readers don't wonder what the post was all about.
As far as I know, the only real thing we got grossly wrong with the CV-5 island was the angled cut for the aft crane. What are you trying to fix aside from the width issue?
Tracy, I think Steve is working on 1/200 CV-5 and 6 islands to convert the Trumpy 1/200 Hornet, not for the Merit kit, which I agree, is basically fine save a little filing for the crane notch on the aft corner for the CV-5 kit, and maybe a piece of Evergreen strip here and there to tweak it (Basic Modelling Skills, Kelley!) The Merit CV-6 island notch was corrected. If Steve is doing 1/487 islands for Revell and 1/719 for Tamiya that is good too.
- Model Monkey
A 1/200 Enterprise CV-6 island is available for the Merit 1/200 Hornet CV-8.CyberGolem wrote:Just curious; why wouldn't the island conversion work for the Merit 1:200 kit?
Link: http://www.shapeways.com/shops/Model_Monkey
CyberGolem
ModelMonkey wrote:A 1/200 Enterprise CV-6 island is available for the Merit 1/200 Hornet CV-8.CyberGolem wrote:Just curious; why wouldn't the island conversion work for the Merit 1:200 kit?![]()
Thanks Steve. I got all excited and misread that this is for an Enterprise conversion, wrote a response that I immediately deleted �after a closer looks at your offerings�oops. BTW, mighty fine stuff you're offering
Anyway, I'm 'wanting' to convert the Merit 1:200 Hornet to her namesake. From what I'm gathering, this might not be a reasonable pursuit ... then again, what hobby is?
Photo of Yorktown which I've never seen before. Supposedly taken during the Battle of Midway.
- Michael Vorrasi
Something is telling me I have seen this photo before, but where is not popping into my head at the moment. Too bad the photo is a little fuzzy. A sharp copy of that shot would be super. Oh, the vagaries of 1942 photography... One of my favorite day dreams is to be able to zap back in a time machine with my modern professional DSLR, a handful of 64 GB memory cards and a set of killer long lenses and really go nuts!MartinJQuinn wrote:Photo of Yorktown which I've never seen before. Supposedly taken during the Battle of Midway.
PS, anybody have their copy of Cressman's That Gallant Ship handy? I think that photo is in the book.
Last edited by Michael Vorrasi on Thu May 26, 2016 10:47 am, edited 1 time in total.
Mike
- Devin
Looks as if she may be spotting a strike. Looks to be F4Fs parked forward and TBDs aft. First strike of the day?
- Michael Vorrasi
Quite possibly. The TBD's aft are a sure indicator. The F4F's forward may be a recently recovered CAP that was being recycled prior to the TBD's being brought up from below, or else moved forward out of the way to get the bombers spotted. Can you make out what is just aft of the island? SBD's maybe?Devin wrote:Looks as if she may be spotting a strike. Looks to be F4Fs parked forward and TBDs aft. First strike of the day?
Mike
Here's another of her in her pre-war glory:
- Devin
I can't make those out at all. From that angle one of those aircraft could be sitting on the elevator in the process of coming up.Michael Vorrasi wrote:Can you make out what is just aft of the island? SBD's maybe?
I'm traveling so don't have my references, and I can't remember exactly what Yorktown's first strike spot consisted of. I believe TBDs and the CAP, but I'm not certain.
Charybdis
Fantastic photos! I have never seen the first one posted. I wonder if there are any more that have yet to see the light of day...
I've been unsure of the location of the SA radar on the funnel. The only picture i have is the one at Pearl. It seems from this picture to be at the forward end of the funnel by the horn.
For that second picture, it seems as though the deck of the island is painted a dark color Possibly all horizontal surfaces?. Would that also be mahogany?
