Calling all Nagato (長門) and Mutsu (陸奥) fans
Felix C
Re: Calling all IJN Nagato class fans
Regarding Fujimi 1/500 Nagato is the photo set #112763 the same one that comes in kit #610016?
- Atma
Yes Felix.
henk
Hi,
Quick question: what is the difference between aoshimas 1927 nagato and 1933?
Any reason for building both kits?
Thanks!
Henk
Thanks!
Henk
Catapult, AA guns, etc. Compare for yourself here:
1927: http://www.1999.co.jp/itbig17/10176601t2.jpg
1933: http://www.1999.co.jp/itbig16/10160947t2.jpg
- Haijun watcher
Is there any historical basis for the paint scheme for this Mutsu at this South Korean site below? And no, I don't speak Korean so I have no idea what the site description says.
IJN Mutsu: S.Korean builder's site
gmmk11
hi Haijun watcher
you linked my 700 mutsu.
that mutsu is what if version. if mutsu survived over 1943 she might be anchored at Kure naval port, with nagato.
To avoid US' bombardment, the green-grey camo scheme is used by IJN warships in Kure naval port at 1945
Haijun watcher wrote:Is there any historical basis for the paint scheme for this Mutsu at this South Korean site below? And no, I don't speak Korean so I have no idea what the site description says.
- Haijun watcher
Gmmk11,
Thank you for the quick response. Komsamida!
A very creative approach indeed for the Mutsu kit.
So which green did you use for this paint scheme?
gmmk11 wrote:hi Haijun watcher
gmmk11
it might be a reflective green in Vallejo acrylic.
I can't remember exactly but pretty sure.
ijnfleetadmiral
No historical base whatsoever...Mutsu never wore camouflage a day in her life. Interesting scheme, though.
frenchinamst
A question for specialist : is the version with serpentine shape funnel of Nagato/Mutsu -before 1930 ?- available at 350 scale ?
If not, is it possible to scratch it (enough visual and technical sources to built it ?).
Thanks for your help.
if you need translation from French instructions...
Unfortunately, there is no pre-modernized version in 1/350 scale. That would be pretty cool, though.
The plans probably exist in Japanese sources; I'm not aware of any that have been published by Western publishers.
Gaston
The Lion Roar 1/350 1944 set I am told has actually the exact same content as the "generic" Lion Roar Nagato set, this including the radars... I have the "generic" Lion Roar...
I have a 1941 1/350 Nagato box: What major things do I need to do to have a 1943 Nagato vs a 1941? Is there enough in the Lion Roar set to do a 1943-44 Nagato? Note that I have the 1941 Hasegawa wood deck: How big is the difference of a 1941 deck with say an early or late 1943 wood deck?
Is there some plastic parts missing in the 1941 Hasegawa kit that prevents doing a 1943?
Gaston
Gaston
- Carter
I am looking for Aoshima AOS00268 for 1/700 Aoshima 1927 Nagato.
As seen here:
http://www.hlj.com/product/AOS00268/
Thanks!
Carter
As seen here:
Thanks!
Carter
- Atma
Finishing my Fujimi 1/700 IJN Mutsu, and I want to have the float air plane crane in a collapse "mode".
Anyone has a clear picture or a drawing of how the crane looked in the collapse "mode" ?
Thanks in advance.
Thanks in advance.
- Atma
You can still order it from Hobby Link Japan, it will take actually less than 4weeks for the set to arrive at the shop and then ship it back to you.Carter wrote:I am looking for Aoshima AOS00268 for 1/700 Aoshima 1927 Nagato.
As seen here:
Thanks!
Carter
I'll look, though if I find one, it may be for another class BB. Have you the Model Art Super Illustrated Nagato volume? There's a simple illustration at the bottom of p.95.Anyone has a clear picture or a drawing of how the crane looked in the collapse "mode" ?
- peppe
they are some drawings and colour rendering in the polish books of AJpress on nagato class with folded airplane crane.
if you want i can scan this detail.
ciao peppe
ciao peppe
- Atma
Thanks Dan I will try and find the one picture you mentioned.
Peppe, that would be highly appreciate if you are able to scan the picture for me
Anyway thanks guys for your input.
Fuso and Yamashiro have nearly identical crane, boom , and sponson layouts, even if their sponsons were located at the stern. Checkout the AOTS volume on Fuso.
This is the only photo I came up with, cropped from an overhead of Mutsu, circa 1940-41. HTH.
- chuck
I believe it is the same crane as the ones that folds into a well in the flight deck on shakaku.
