Calling all HMS York and HMS Exeter (WWII) fans
- Brett Morrow
Re: Calling all HMS York class (HMS Exeter-WWII) fans
Whether 8" or 6" calibre I would expect the loading angle to be much the same, perhaps this film may give some idea to your enquiry Kevin.
https://www.awm.gov.au/collection/C189083
KevinD
Thanks for that link Brett. Very interesting / helpful.Brett Morrow wrote:Whether 8" or 6" calibre I would expect the loading angle to be much the same, perhaps this film may give some idea to your enquiry Kevin.https://www.awm.gov.au/collection/C189083
Cag
Hi All
Hi KevinD, off the top of my head you're answer would be in the 8 inch handbook where the complete loading sequence is given, including times for reload and shell / cordite re supply, as far as my jotted down references I think its Adm 234/190 National Archives Kew.
They are fairly large books so it would be a visit I'm afraid.
Have Navweaps not got info on loading angle?
Best wishes
Cag.
Best wishes
Cag.
Cag
Hi All,
Hi KevinD, just checked on Navweaps and the Mk1 and 1* have a reload angle of 10�, but the Mk2 and 2* which I think was on Exeter is given as 6�.
Hope that helps
Best wishes
Cag.
Hope that helps
Best wishes
Cag.
KevinD
Thanks for doing the work for me Sean.Cag wrote:Hi All,
Hope that helps
Best wishes
Cag.
I don't know why I didn't go look there in the first place.
- Mike W
tjstoneman wrote:According to a post on this thread (admittedly 11 years ago - 5 January 2010!), the 20mm were never fitted in the tubs on "B" and Y" turrets, with mountings for single machine guns instead. Not sure if any weapons were ever fitted in the tubs abreast the mainmast.
The single 2 pounder pompoms had been replaced by quadruple Vickers 0.5" machine guns some years before the war. The four single 4" HA guns had been replaced by 8 4" guns in four twin mountings, and two octuple 2 pounder pompom mountings added, during her 1940 repairs.
Did she retain her quad vickers 50's after her refit?
thanks
Mike
tjstoneman
The quadruple 0.5" mountings remained in place abreast the bridge after her repairs in 1940 - see, for example, http://steelnavy.com/images/OkretySwiat ... Exeter.JPG, where the four drum magazines of the starboard mounting can be seen reflecting light just above S1 twin 4" mounting.
- Mike W
thanks!tjstoneman wrote:The quadruple 0.5" mountings remained in place abreast the bridge after her repairs in 1940 - see, for example, http://steelnavy.com/images/OkretySwiat ... Exeter.JPG, where the four drum magazines of the starboard mounting can be seen reflecting light just above S1 twin 4" mounting.
- hj1985
Hi guys,
a quick question in regard to Aoshima's 1/700 Exeter.
Should the square structure right behind the catapults be removed? From the 1930's photo, there should be a scaffold-type structure aft of each catapult.
KevinD
There is still a structure there just aft of the cats post refit, but it does not appear enclosed as on the model.
- hj1985
Could this be the same scaffold type structure, but viewed from a different angle?KevinD wrote:There is still a structure there just aft of the cats post refit, but it does not appear enclosed as on the model.
- Maarten Sch�nfeld
It seems the table with the heavy legs is intended to represent the flimsy scaffold. Only a PE representation would do it justice. So discard the thing from the kit and build the scaffold yourself I suggest.hj1985 wrote:Could this be the same scaffold type structure, but viewed from a different angle?KevinD wrote:There is still a structure there just aft of the cats post refit, but it does not appear enclosed as on the model.
Roger Whittaker +9/13/2023
- hj1985
Thank you Maarten. It seems the DIY is the only option here.Maarten Sch�nfeld wrote: It seems the table with the heavy legs is intended to represent the flimsy scaffold. Only a PE representation would do it justice. So discard the thing from the kit and build the scaffold yourself I suggest.
- Kazec
Were the porthole covers of the lower level of Exeter were still barely visible after the 1940/41 refit? Many cruisers still had the covers somehow visible after wartime refit, e.g. HMS Kent, but it seems those of the Exeter were completely flattened.
Hong Kong Naval Model Association
https://www.facebook.com/groups/659559407492511/
KevinD
To answer your initial question; no they were not visible. The attached photos seem to confirm that all but about 10 of the lower scuttles were completely plated over with 'sheets' of hull platting, not just 'patched' over individually so to speak.Kazec wrote:Were the porthole covers of the lower level of Exeter were still barely visible after the 1940/41 refit? Many cruisers still had the covers somehow visible after wartime refit, e.g. HMS Kent, but it seems those of the Exeter were completely flattened.
EDIT: Rewrote my first sentence to clarify my response.
- Kazec
Thank you. The images are clear enough.KevinD wrote:To answer your initial question; no they were not visible. The attached photos seem to confirm that all but about 10 of the lower scuttles were completely plated over with 'sheets' of hull platting, not just 'patched' over individually so to speak.Kazec wrote:Were the porthole covers of the lower level of Exeter were still barely visible after the 1940/41 refit? Many cruisers still had the covers somehow visible after wartime refit, e.g. HMS Kent, but it seems those of the Exeter were completely flattened.
Marco
I am restarting work on my HMS Exeter (Trumpeter 1/350), and well, took not long until I found something I need more information about. I am working on the pipes in front of the main funnel, and it seems like Trumpeter completely forgot about a set of 2 pipes departing the funnel forward, hidden by the structures between the funnel and the forward upper deck. Are there clear pictures of what happens to these pipes entering the forward superstructure? Oh man, I can�t remember anymore how to upload pictures... let�s see... Got it! This is what I was referring to. It seems like the pipes cross horizontally to the front upper deck, and then?
And my second question, the area in front of the forward funnel, I don�t get what is there. In modern times, I would have said that they store the helicopter pontoons there, but... Have seen representations of that part being wooden deck (which I doubt, maybe a canvas cover). Grateful for any clue.
Marco
Marco
KevinD
Is your build pre refit (as in the photos you loaded) or post refit?
Marco
Pre-refit, as it was right before the Battle of the River Plate.
Marco
Marco
KevinD
Marco, I can't really answer your questions re pipes, but here are photos of what was between the forward superstructure and forefunnel in 1939 / 40 (the photos you posted are taken in 1934).
It appears to be a hard sided / hard topped box like structure to me, but I'll leave that for others to interpret. But what it contained, well who knows?
