Gentlemen, Need your help on painting the MIS-BB-63. Only second ship model. I would like to paint the deck to look like its a wood deck. Am I creating a problem for myself? Have any of you tried to do this? Could I just spray the deck all brown and then go back and paint over the sections that shoudn't be brown with steel gray?
Or mask sections that aren't deck and then spray the brown? Or is that too much work which I would expect it to be.
What color brown would be best bet?
When you build the separate parts of the ship: turrets, bridges is it best to paint them individually? Plus other parts as well.
What's your best advice? Thanks, CharlesC
I've seen people use both methods. Some modelers paint the deck first, mask that and the spray the vertical structures. Others mask the vertical elements and paint the deck last. If possible, you might find it best if you can break things down to sub-assemblies based on color so that you have nice clean lines of demarcation.
Check out Dave Hill's latest build article (link below) and it will give you a sense of what I'm describing. viewtopic.php?f=60&t=37034
Fans of the USS Missouri 1/350 Battleship:
Gentlemen, I need your expert opinions on my venture of painting the deck of Missouri. Mask everything on the deck and spray paint or brush paint the deck? What color brown?
Has any one of you attempted this? If not brown to look like a wood deck, What color would you suggest looks best? Appreciate your feedback. Thank You. CharlesC
In September of 1945, the Missouri entered and left Pearl Harbour after the surrender ceremonies wearing a camouflage scheme similar to MS22, but with the top of the 5-N line ending at the main deck, rather than following a straight line horizontal to the waterline. Was there an official Measure for this scheme, or post-war liberty?
I gotta admit, That style looks MUCH better than standard MS22 sheer-line cut on the look, it gives it a cleaner, trimmer appearance. I'd consider doing my Rhode Island (when I get to her) like that.
Does anybody know if parg e13 on Tamiya's 1/350 Missouri is accurate for a 1944 NJ? I don't see any photos that clearly show this platform on the tower.
Part E13 is the RDF and 40' whip antenna outrigger platform and there is no evidence of the platform on several photos I have. The attached image is a snapshot from an image off http://www.navsource.org/archives/01/016245.jpg March 1945 (prior to her April 1945 refit) and no platform is visible. Other than the wartime censor meddling with every public domain image, it's probably safe to assume it's not there.
hello
im thinking of buying the tamiya 700 new jersey and also GMM's PE set. on the GMM website it says the set is for the PitRoad/Skywave kit but it doesnt say if its compatible with the tamiya version (although it looks like it could.) i just wanted to see if anyone here has tried this and if it is compatible with the Tamiya version
Hey guys, I was looking through the Navy News Stand photos of Missouri's recent trip to the yard for some repairs and came across this interesting closeup of one of her bow numbers. Look closely at the top of the "6".
Hi Guys,
Felix,
What specifically do you want to know?
Summrall's Iowa class book illustrates the changes to NJ for 1968 refit, as does Stillwell's book, "Battleship New Jersey, an illustrated history". I can help you with this.
I've seen some effective looking hull plating done by Jim Russell on his 1/350 Iowa using what I bnelieve to be a masking tape and dry-brushing technique.
Keith bender would just plate the whole darn thing!
Me? I'm in between plating and painting; that is whenever I get around to finishing my 1/350 Mo.
Rock on boys!
Yesterday, I met a former Wisconsin 16" gunners' mate. He is younger than I am!
Still the most graceful and powerful warships ever built!
Tony
Hi Guys,
I guess I'll play, Tracy.
Here's the million dollar question.
What good is a carrier w'out any a/c?
If it's a/c that you adore, then comparing an a/c to a BB is like comparing an apple to an orange. N'est ce pas?
Of course, your argument could be, "well what good is a BB if it has no ammo, and would'nt that be the same as comparing a CV with no a/c..?"
Good point Tracy!
".....well hello Joey, you ever been in the cockpit before..?"
Tony
Greg, they were standard Mk. 141 Quad Canister launchers used on all USN ships. What scale are you building? There are resin launchers by Veteran Models in 1/350 and PE by Flyhawk in 1/700 (PE is for the supports, styrene rod is used for the missile tubes).
