Calling all Essex-class (Cold War configuration) fans
Hank McCoy
Re: Calling all Cold War Essex-class Fans!
Post by Hank McCoy »
Thanks for the info. Kind of amazing that these angles seem so hard to find documented. Would think that would be a rather obvious detail. I'm working on producing replacement decks for the 1/500 and 1/540 kits. Currently working from the Gallery 1/350 kit and it looks like a 10.25 degree angle. Can anyone offer a source for 48" x 90" sheets .010 or .015 styrene ?
Hank McCoy
I have been successful with .020 but expected that it would be considered overly thich for laminating onto the kit's deck. Also, it would be easier to cut the deck from the sheet.
Hank McCoy
Just posted a lament on the Forrestal / Kitty Hawk site. Again, here. Why no Viet Nam era a/c sets, conversions, accessories ? Thought the Intrepid would be the greatest new ship kit on the market but not even a/c sets ? I've always suspected that modeller's interests would be lower than expected but this is really surprising.
Navy2000
Post by Navy2000 »
Has any on ever found cross sections or hull lines for an Essex with the blisters on them. I would love to get a set so that I can make the corrections to a 1/96 scale model.
Duane
George W. Bush CVN 77, Makin Island LHD 8,
Port Royal CG 72, Cole DDG 67, The Sullivans DDG 68
Chicago CG 11
Post by ModelMonkey »
Calling all you Intrepid experts out there!
Seeking confirmation of admiral's bridge window orientation and numbers on CV-11 Intrepid. Anyone with great knowledge of the ship, please chime in.
I am presently designing replacement bridge parts for Merit's 1/350 CV-11 with open windows, and later, offer alternative parts to build other Essexes. But a design conundrum of sorts has surfaced.
The Merit kit's parts J32 and J37 have a frame dead center forward, but this may be incorrect. The real ship may have a window dead center forward, not a frame, and if so, I can make the design to reflect that.
Photos of sisterships indicate that the bridge window number and orientation varies from ship-to-ship. Lexington, Yorktown and Hornet photos indicate that those ships have a window dead center forward. There are also differences between the ships' navigation bridge above. Yorktown has more windows, for example.
The NavSource photos, while very good, because of camera angle and the shallow angle between the "faceted" bridge windows, are inconclusive.
A whole modernized island is presently in development for other scales. I'd like to start with Intrepid and move on to other sisters from there, if there is sufficient demand.
Photo: Don Gras.
Photo: Don Gras.
Photo: NavSource
Photo: NavSource
ShangHist
Post by ShangHist »
ModelMonkey wrote:Calling all you Intrepid experts out there!
Steve,
I sent your question to one of our crewmen who works on INTREPID. Will advise when I get a response.
Bob
Admhawk
Post by Admhawk »
Steve,
Going through my references, these 10 ships appear to have the center window facing forward.
ESSEX
YORKTOWN
INTREPID
HORNET
LEXINGTON
WASP
HANCOCK
KEARSARGE
ORISKANY
SHANGRI -LA
I couldn't find good enough photos of the other ships.
However, What I did notice was that the bridge is not centered on the island foundation. The window that faces forward is offset towards the center of the ship, while the bridge itself is wider on the outboard side. This causes the bridge to have a bit of a lopsided curve and the forward window doesn't line up with the bridge or island center.
See the photo link provided,
Intrepid window alignment small.gif (50.07 KiB) Viewed 3143 times
Large Picture here,
http://www.resinshipyard.com/pictures/I ... gnment.jpg
Darren (Admiral Hawk)
That's a big help, thanks!
MAJOR-B
Post by MAJOR-B »
Does anyone know if anyone makes a 1/350 PE Set for Korean War Radars? Looking to build the BON HOMME RICHARD in 1951-52. Also not sure which wooden deck to use the nautlius for the franklin late war or their for Bon Homm Richard in 51. Lastly Does anyone make PUP Helo in 1/350?
Major B :thumbs_up_1:
Mark McKinnis
Post by Mark McKinnis »
Iron Shipwright did the H03S Helo for their Korean War Essex and you used to be able to get spare aircraft. Not sure if you still can. I think that they discontinued the kit. It might be possible to get one from Shapeways 3d printing designers. It would be worth asking both.
I would look at the deck of Franklin and see if it works for a Korean War non SCB-27A ship. Otherwise go with the Nautilus deck. I am not really sure if there is a difference. I have never seen a PE set with the Korean War Radars either. Iron Shipwright had a PE set with all of those for Essex as well.
Good Luck!
Mark
pete wenman
Post by pete wenman »
Guys hi - I hope this is the correct place to post his.
I'm an aviation artist, who likes to work on Nav Air subjects whenever possible (having been an avid modeller before switching to paint on canvas) who still uses models of varying degrees of quality when painting. I now want to have a go at a Korean War era Essex Class (pre any SCB-27 refit). I'm not too bothered about which, but I'm thinking 1952 or so, and "brown" deck would please my artistic eye.
I plan to use one of the Trumpeter 1/350 long hull kits ( I assume there is very little differnce between the two kits) and the Pontos late detail set.
My main question is what changes will be need to be made to the kit to represent a Korean era Essex.
I'm thinking the following
Reduction in 20mm guns
Understanding of which 40mm Quad stations were retained
Any changes to the arresting wires and barricades
Any changes to the mast and antenna configurations
My reading to date suggests there were no major changes, but I've been wrong before.
Any help appreciated. In the meantime I'm slowly reading through this thread and the WWII one.
P
PS If interested my art can be found here
http://www.navairart.com
Mark McKinnis
Hi Pete,
There are a couple of Dragon 1/700 scale Korean War Essex Class ship kits ( non-SCB-27A/C). The Bon Homme Richard and Princeton can be found on Ebay but they are a little pricey.
Iron Shipwrights is still doing their 1/700 Essex SCB-27A kit.
http://ironshipwrights.com/pages/Essex700.html
If you are going with a 1/350 scale ship, I think that the Franklin would work for a "Bon Homme Richard" and either Ticonderoga or Hancock for the long hull Korean War ships. In addition to what you have already listed, there is work to be done on the bridge structure on the island and the radars are different.
Good Luck,
Mark
MAJOR-B
Post by MAJOR-B »
Good day,
Does anyone have a template for making the new stack and single mast? I have the Intrepid which is being saved for a Hancock build. I have two WWII (one short and long hull) Kits that I would like to make into two korean war CV'S any help would be most welcomed.
Major-B :thumbs_up_1:
pete wenman
Mark - thanks for the info - my intention is to go with 1/350 as I find 1/700 to fiddly and hard work on the old eyes.
The Philippine Sea looks a good option as I've found some good photo reference and she had a non blue wooden deck.
I've annotated this NARA image to collect my thoughts and have checked against other photos where possible. I'm pretty comfortable with the configuration so far, but I suspect there were more than 7 arresting wires. I hope to do something similar for the mast and radars so I can establish what I need.
Thoughts
P
MAJOR-B
Post by MAJOR-B »
Peter:
Thank you,.,.Thank you..., Thank you...
You are a mind reader she is one subject I would love to build.
Thank You again.
scratchshipbuilder
Post by scratchshipbuilder »
Been awhile since I read this whole thread so hopefully I won't dupe. Anyone have an opinion on the MT Miniatures 1/700 Intrepid other than price? I keep getting more and more tempted.
pete wenman
and here is my estimation of the main radar antennas - interesting that the SK-2 disappears and is replaced by what I assume is a SPS-6 on either of her trips back to San Diego in late 51 or late 52.
Anything I'm missing here ?
Major B - glad to be of service.
P
MAJOR-B
Post by MAJOR-B »
Here is a great shot of the Philippine Seas date unknown. If you look on Starboard Side the ship has tiny 47 on the bow and large 47 on the starboard side not the stack. So If I was to guess when modeling in 1/350 you would have to use 1/700 for the bow numbers and 1/350 for Port side of the stack and starboard side. What was the purpose of this form of identifying a ship?
William Smallshaw
Post by William Smallshaw »
I have the MT Miniature kit. It appears to be a good starting point, the bow will need some clean up, but rest looks good. The hull does seem to scale out to 1/720 rather than 1/700. But set next the the Italeri modern carriers she will be a correct size. Also give the Skyware Clevelands and Baltimores seem closer to 1/720 I already have a bit of scale ,I already have a bit of manufacturer induced scale mix already. Only constraint would be displaying the kit with other Essex builds in different time frames.
Bill
scratchshipbuilder
I want one. I have a ton of Fujimi Skyraiders and crusaders. I guess I'd need three or four of that west wing set that has the four hump back skyhawks in each. Even though it looks a little primitive in review I'm sure starfighter decals and a good airwing would make a great ship. Angle deck Essex need packed flight decks to me.
Return to “Aircraft Carriers”
