Tony Bunch
Post by Tony Bunch »
Hi Guys,
Greg,
Are you planning to do some scratch building?
FYI, In 1/700 scale, JAG makes a Modern Iowa detail up set including: ABL's, CIWS, 5"38 twin mounts.
Quite nice.
Tony
Greg W
Post by Greg W »
I'm rebuilding a sterling Missouri into a NJ in 1/192 scale. I'm using a revell NJ model in 1/350 scale and plans from http://s181686668.onlinehome.us/phpBB3/index.php .The superstructure has been reworked and the hull corrected. I'm trying not to buy details as I like the challenge of making them. Greg
Felix C
Post by Felix C »
Thanks Tony.
I will borrow those two books and note the changes. Have two New Jersey kits. Both are 1980s fit and wondering how difficult to retro to 1968 era.
Wondering if there is any before and after.
I found I have a Weyers Warships of the World 1969 book which has good broadside and top-down view of the NJ. Wondering how accurate it is.
Cliffy B
Post by Cliffy B »
Felix,
The Nerw Jersey during her Vietnam re-fit looked more like her WWII fit only with more electronics and radars and absolutley no guns besides her 16" and 5" turrets. The amidships 40mm tower was filled with chaff rockets and antennae. It'd be easier to start a model from the WWII version and get some aftermarket radars and scatch the masts.
IIRC NJ retained the 40mm gun tubs abreast the bridge, had them sealed and painted the interiors "blue" to be used as swimming pools. It was only for that cruise but an important detail none the less. Could be a neat to include in a dio; "Swim Call on Yankee (or Dixie) Station"
Tony Bunch
Hi Guys,
To add to what CliffyB was saying.
In 1968, the midships area, (formerly for a 6-pak of quad 40's), had chaff launchers and a pair of Mk56 directors. Of course, the cats had been landed long ago. The crane was still there. I'm just not 100% positive it was the very same crane. One might assume.....
The biggest change was to the radar and antenna array. I can't recite specifics from memory though. The GMM 1/700 p/e set for Modern Iowas does include the 1968 radar/antennae. I also think GMM's 1/350 p/e set includes the same. These could be quite useful for scaling up to 1/192 and a nice neat scratchbuild effort. A snap shot of the radar array shows SPS-10 and SPS-6.
Good skill, Tony
Felix C
Post by Felix C »
Thanks Again.
I have two NJs and so not feasible to obtain a WWII Mo.
I can cast new 5" turrets to complete the outfit.
Paint scheme the same Haze Grey for Vietnam?
Cliffy B
Post by Cliffy B »
Paint scheme = standard Ms. 13 Haze Gray and Deck Gray.
John Brolin
Tamiya 1:350 USS Missouri dimenstios
Post by John Brolin »
Hi Everyone. This is my first post on the board. I am not new to modeling but am absolutely green when it comes to ships. I am building the Mighty Mo and have about, oh, a million questions. I do try to find out info. on my own but I am sure I will be asking for help every now and then. A shout out to Tony Bunch who has already helped me out.
And now for the question. I would like to order a case for the Mighty Mo and need to know the height of the built model. The case I am looking at is 9" tall. Will I be o.k.? Thanks for any help. I am really looking forward to getting started on this. I will try to keep you posted on my progress.
John
dbmoens
1:350 Missouri dimensions
Post by dbmoens »
John,
My Tamiya Missouri is just under 7 inches from the bottom of the hull to the top of the radar. This is without any kind of base at all. Still, 9 inches should leave you plenty of room.
Dave
The Flight I Burkes have black "caps", don't they?
http://www.navsource.org/archives/05/05015943.jpg
navydavesof
Post by navydavesof »
Timmy C wrote:The Flight I Burkes have black "caps", don't they?
That's a good point Timmy, but the Ticonderogas have a combination of grey caps with back tops, the Burkes with black caps, the Spruances were all haze or dark grey, and the LHDs and LHAs for the most part have haze and dark grey caps and masts.
I guess it is up to my preference?
I say it's up to you ;) I think black will be a nice highlight.
John Brolin
Re: 1:350 Missouri dimensions
dbmoens wrote:John,
Dave
Thanks for the info. Dave! I feel better about shelling out the money for the display case now.
smoke
20mm Oerlikon on Missouri
Post by smoke »
Greetings from Germany,
I also started to build Big Mo. Therefore I bought the 2 GMM PE sets plus the one from Eduard. And now comes the question:
The Eduard Set contains 60 tripod mountings for the oerlikons. Pictures on navsource revealed solid type mountings in the stern area. Have the tripods been used somewhere on the ship.
Thanks for your help.
smoke
DBlack
Post by DBlack »
I apologize right up front for the picture quality here--I don't have a scanner, so all I could do was to take a photo of the photo (you can see the flash in the center :sorry: ). But I really wanted to share it, so I did the best I could.
This is the Massachusetts being towed past the Iowa (and Forrestal, where the guys in hardhats are standing) at Coddington Cove, RI, on Nov. 4, 1998, on her way to drydock in Boston. This moment, and her return passage 4 months later, are interesting because they were very likely the last 2 times you'll ever see 2 US battleships together. I'm just glad that I was there for it (both times), and realized the historical significance as it was happening.
Unfortunately, the one thing I'll never forgive myself for is that I was so determined to get as many shots of the two ships together as possible in those few seconds that I rushed, and all the rest came out slightly blurry. :doh_1: I did better the second time around, in March of the following year, but the Navy had closed this section of the base off by then, and the only vantage point I could get was from directly behind the Iowa, up on the hill overlooking the piers...
Tony Bunch
Hi Guys,
smoke,
Here's a shameless plug for L'Arsenal. L'Arsenal offers single 20mm Oerlikon's with cast resin cone-shaped bases. Each package comes with 20 single 20mm weapons, (including the bases).
DBlack,
Awesome! 2 BB's in the same picture; and in 1998.
Thanks for sharing that.
I had a similar experience back in 1991. I watched Missouri leave San Diego from a waterside viewpoint across from NASNI. At the time, I was working for Lockheed at NASNI. As we left the, "island", I hauled axx across the bay bridge to find a vantage point on the other side. I finished off a 6 pack of beer while watching Mo pass by so silently. It's weird watching something so big moving by and not making a sound. Usually anything moving under its' own power makes some noise. This was an experience I'll never forget!
Tony
Greg W
Post by Greg W »
Hi All, can anyone direct me to info about the drone aircraft and their retrieval gear used on the NJ? Thanks, Greg W
Tony Bunch
Hi Guys,
Greg,
This website has proven most useful over the years:
http://www.dodmedia.osd.mil/
I typed in rpv in the search window and got some good hits.
After reading the captions, this RPV was called, "Pioneer 1".
NOTE:
After studying the rpv images when shown on the different BB's, one can determine a different amount of wood decking between Iowa and Wisconsin aft of turret 3.
John,
That's one fine model you got there! Your model has been a standard of comparison between myself and probably many more modeler's own BB63 projects.
How much did you fade the 20B for your decks?
Unfortunately for me, my wife won't allow a 1/96 Iowa BB in our apartment.
A 1/96 Adams DDG is passable at half the length and 1/10 the scale displacement.
Tony
TogoTommy
Post by TogoTommy »
Ya know, we still miss those ships up here in WA state.. They were a fixture on the Bummertown waterfront for decades.. All 4 of them sat together, as you drove toward the main gate to the navy yard, right next to the roadway.. Along side a whole row of Essex class carriers, Midway and Coral sea, and many other notable ships were there as well... Always used to stop, visit, or just take in the view, on my way to the VA...
Damn shame their gone now!!!
Tom
"Well, Cmdr Eddington, Looks like we have ourselves a war!"
"Yeah, a gut bustin, mother lovin, NAVY war!!!"
Greg W
Post by Greg W »
Thanks Tony, that was just what I needed. Greg
