AuburnGrad93
Post by AuburnGrad93 »
Hello,
I am looking to build the Tamiya modern New Jersey. What I was wanting to know was there any kind of updated foredeck like the one L'Arsenal has for the MO? I know about the L'Arsenal twin bits and plan on getting those, but I really want to improve the look of the molded-in anchor chain and other details of the NJ. Also, has anyone here done the real wood deck on the modern NJ and can post some pictures of how they accomplished it?
Thanks in advance for any and all advice!
Darren
Tony Bunch
Post by Tony Bunch »
Hi Guys,
Darren,
The L'Arsenal fordeck set became available after I had permanently attached the forward deck section to the hull on 1/350 WWII Missouri, but I wanted to use it.
Here's what I had to do, and this would apply to the Modern New Jersey's foredeck as well. As a matter of fact, I used the New Jersey foredeck on my Missouri as Missouri was without the 3 x 20mm AA weapons on the maindeck abeam turret 2 in October 45. Rather than fill in these areas, I used the New Jersey foredeck. I had to make provisions elsewhere, but need not be discussed here.
I sanded away all of the surface detail on the foredeck. I then added on all of the details carefully removed from L'Arsenal's foredeck to the now naked foredeck.
The process was simple enough. I had to cut away the wildcat bases, and the anchor chain bolsters and sand the bottoms down to leave just the part needed.
Yep, you'll be destroying a single piece resin replacement foredeck, but that's the only way to use the corrected L'Arsenal details.
Here is an option. You could separate by cutting the steel deck section of the foredeck leaving yourself a little extra; which also gets rid of the nasty play fore and aft when all three deck pices are placed together into the hull. You will still have to remove the wildcat bases and remove material from the bottom till you have just a wildcat base; then glue to your modified kit foredeck. With this, you'll have the correct foredeck, and the correct wildcat bases for New Jersey. Other than that, you'll need to remove the molded on twin bits and the breakwater to allow installation of the L'Arsenal twin bits and the breakwater. Also, the L'Arsenal bucket vents and mushroom vents can replace the kit units.
I still had to do some scratch-building, as the kit provided capstans to the right and left of the wildcat heads were the wrong shape.
That's it in a nutshell.
Here are some pics of the mods done to 1/350 Tamiya Missouri.
Tamiya's New Jersey foredeck in place:
Here's the foredeck with the L'Arsenal twin bits and breakwater in place, (after carefully planing away the molded on ones):
Just remove the 20mm splinter shields and you've got a New Jersey foredeck:
I hope this helps.
Tony
navydavesof
Post by navydavesof »
I knew Tony would produce an awesome reply. He did not disappoint!
AuburnGrad93
Tony,
That helps tremendously. So does the L'Aresenal foredeck have the correct anchor riding chocks and hawspipe configuration as it looks different than what's on my NJ? Do you have a picture of the very bow of the ship showing the hawspipe details? And thank you again! Man, this is going to be an expensive little project by the time I purchase all the aftermarket upgrades for this thing? How much is the L'Arsenal foredeck and enough twin bits to do the entire ship?? I am already planning on the YMW replacement turrets and 5/38 guns, as well as the Eduard PE kit, and all the Veteran Model upgraded parts. That plus the planked wood Decks should make this an outstanding model! I just hope my rusty skills are up to the challenge!!!
Darren
Tony Bunch
Hi Guys,
Darren,
The L'Arsenal foredeck set includes 10 sets of the 20" twin bits; the ship needs more than that. I can't count how many right now; gotta go to work.
The foredeck config. is the same on all Iowa's.
I'll post a scale drawing later today.
Tony
Tony Bunch
Hi Guys,
Darren,
The L'Arsenal foredeck sells for $51, and the twin bits/chocks asst sells for $8. Please contact me off board for any further business correspondences. I'm a ship modeler first, and a businessman second.
The YMW main gun turrets are okay, as the ladders are off and the blast bags are separate. BTW, be sure to check period-photos to determine which turrets had how-many ladders; they differed. I hate to say it, but the YMW cast white metal barrels are sub-standard unless they have improved this set. You may wish to contact BMK, B&B or Master Barrel for replacement barrels. I have the YMW replacement turrets and I will only use the Main turrets. L'Arsenal just came out with A BRAND NEW set of 5"38 twin mounts that beat anything before it; including L'Arsenal's earlier 5"38 twin mounts. It should be noted that L'Arsenal's first set of 5"38 twin mounts were not correct for Iowa Class; but for the Essex Class carriers. The new set AC350-79 is for the Iowa's specifically. Shameless plug for L'Arsenal. God, please save my soul.
See link to New Jersey below. NOTE: the paravane windlass is still there, but the paravane chain and the rollers for it have been removed.
http://www.navsource.org/archives/01/016283.jpg
http://www.navsource.org/archives/01/016216.jpg
HTH, Tony
AuburnGrad93
Tony,
Those pictures were most helpful and I sent you an email about the parts. So I will be ready to get started soon. When you built your MO, did you follow the the steps in the instructions or build any steps out of order? Like I said earlier, I am planning on planking the wood decks with the 1x3 real wood planking, and was wondering how I should proceed with the painting to best facilitate the decking? Any hints or suggestions would be appreciated! I really like the way the deck came out on this build by Warren Jones.
http://www.steelnavy.com/NewJerseyWJ.htm
Darren
navydavesof
Tony Bunch wrote:NOTE: the paravane windlass is still there, but the paravane chain and the rollers for it have been removed.
HTH, Tony
As a note to those who are interested, the USS New Jersey is the only one of the four to have her paravane capabilities removed. Long Beach removed the paravane eye and its chain pipe that ran all the way from the deck to the eye in 1987, because of corrosion problems. Almost immediately after New Jersey left dry dock, the Mine Warfare Group asked if New Jersey could still employ paravanes, because the Iranians were laying mines in the Persian Gulf, and she might need to sweep them during her upcoming deployment. Oops.
So, the smooth bottom of the tear-drop shaped bow Tamiya modeled for New Jersey is accidentally correct. If you're making any of the other three, on the other hand, you need to add a little eye down there for accuracy.
Tony Bunch
Hi Guys,
I came to work today armed with Stillwell's New Jersey book.
I must have subconscientiously known why!
Different ship, there will be differences; As evidenced by NavyDave.
Tony
jdeshl
Calling all USS Missouri fans
Post by jdeshl »
I'm getting ready to build the USS Missouri during the Surrender of Japan ceremony. In researching the painting at that date I found some conflict in my online search. One site lists measure 22 (Navy Blue 5-N, Haze Gray, 5-H and Deck Blue 20-B.) another site #7 Navy Gray has been substituted for Navy Blue retaining the same designation (5-N),Deck Gray (20) has been substituted for Deck Blue (20-B). A directive # C-S19-7(631) of 26 February, 1945.) was sited. Can anyone tell me which would be correct? I also see that there is quite a lot of pe items for her, sure going to be a lot of research for which is better.
Any help would be greatly appreciated.
Happy Days
Jim
Sr. Gopher
Post by Sr. Gopher »
jdeshl wrote:I'm getting ready to build the USS Missouri during the Surrender of Japan ceremony. In researching the painting at that date I found some conflict in my online search. One site lists measure 22 (Navy Blue 5-N, Haze Gray, 5-H and Deck Blue 20-B.) another site #7 Navy Gray has been substituted for Navy Blue retaining the same designation (5-N),Deck Gray (20) has been substituted for Deck Blue (20-B). A directive # C-S19-7(631) of 26 February, 1945.) was sited. Can anyone tell me which would be correct? I also see that there is quite a lot of pe items for her, sure going to be a lot of research for which is better.
Happy Days
Jim
If you're gonna do it in 1/350, I think Eduard has a PE set dedicated to the subject, complete with figures and all of the platforms added for the crew.
Current builds:
Planned builds:
3 more 1/700 AH submarines
Tony Bunch
Hi Guys,
Jim,
Being that Mo was abroad when that paint ordered was issued, it is questionable as to whether the, "Neutrals", had already been applied. Mo had a yard period through Jan, 45. If you look closely at Missouri in Tokyo bay, it's in baaaaaaaad shape. My guess is old, "Blues".
Now; when she had a stopover in Pearl two weeks later, her entire hull was painted in 5N.........or was it 5N Neutral??
Also, on her way home from Tokyo via Pearl via Panama to Hudson River, her decks were holy-stoned to their un-painted teak color. The question still remains; while in Pearl, was the deck color re-painted, and if so; was other than 20B used?
Some pics taken, "on her way home", show some serious steel painted deck color wear; re-painted? Some folks think not.
For your consternation, Tony
jdeshl
Post by jdeshl »
Thanks for your info guys.
Jim
Rob-UK
Post by Rob-UK »
Perhaps looking at some colour photos will help to answer this:
http://www.navsource.org/archives/01/016346c.jpg
In Tokyo Bay, Sep 1945, photo c/o NavSource.com
http://i196.photobucket.com/albums/aa11 ... thur21.jpg
In Tokyo Bay, Sep 1945, photo c/o ww2db.com
http://www.navsource.org/archives/01/016326c.jpg
On her way back to the US, one month later, decks holy stoned but turret tops unchanged and worn looking, photo c/o NavSource.com
The shade on the deck looks to have quite a blue element to me. There don't seem too be any colour images of a side view so we can only presume that the 5-N on the hull was the earlier navy blue shade of grey?
Reason: Navsource doesn't allow direct hotlinking of their pics - img tags removed
AuburnGrad93
Hey Guys!!
My wife had an Interview this week in Newport News, VA and while we were there, guess what I remembered was in Norfolk? The USS Wisconsin!! So after her interview was over, I drug her over to Norfolk and we toured the Whisky! I am sorry I didn't have time beforehand to ask if anyone needed a specific picture or anything, but I did take my Nikon D90 and I took well over a hundred pictures of her!! You're welcome guys!! Anyway, please go to our Fotki page to see ALL the pictures. Below each picture, it says see original uploaded picture, and there you can see the HUGE picture as was taken from my D90. Hope this helps someone else here.
Tony, how close does the Whisky resemble the New Jersey??
Best Regards,
Darren
http://public.fotki.com/nursekja/uss-wisconsin-bb-64/
Tony Bunch
Hi Guys,
Darren,
Short, "knee jerk", answer.
The amount of wood deck planking differed between all four sisters. The paint differed too. Some of the sister's used the deck grey color on all horizontal surfaces, and in other cases the haze grey was used. The helo pads differed per ship / per period. Later, the ships carried the RPV for scouting fall of shot. Funny!
Look for the domes facing forward on the fwd fire control towers and on the aft stacks.
I have quite a few pics of WI saved on my PC.
To approach building the WI in 1/350 from Tamiya's Modern New Jersey:
Other than the decking, you'd best be served using all of your recent photos to make changes to Tamiya's NJ kit. The more you stare, the more you'll see.
It's really that simple. Now of course you know, you'll have to scratch up the fwd fire control tower. I have drawings I've used before at the back of Stillwell's Missouri book that helped a great deal. You have to pick a timeframe that works for you, and then go from there. The physical, "steel", differences between the Missouri and WI other than the amount of wood decking is still a mystery to me.
I have not ventured into a WI build................yet!
Tony
drdoom1337
Post by drdoom1337 »
Is anybody else curious as to what a Modernized NJ would look like if it still had the round bridge?
I really never understood why the bridge was squared off on the NJ, I mean it was already enclosed and looked a lot more functional round than it does square.
rtwpsom2
Post by rtwpsom2 »
Fog of war. If all the ships looked the same, the enemy would have a more difficult time identifying them. Also just for the sake of supply. If they all have the exact same equipment, it is easier to keep them in powder and paint, so to speak.
Cliffy B
Post by Cliffy B »
I believe the squaring off of the bridges also enlarged the walkways some.
navydavesof
drdoom1337 wrote:Is anybody else curious as to what a Modernized NJ would look like if it still had the round bridge?
No, but that's interesting. I bet she would have looked the same...just with a round bridge. Everything inside the bridge is terribly cramped with the squared bridge. The round one would have kept everything significantly more cramped.
