Hasegawa 1/700 IJN Haguro - building from Myoko - COMPLETE
SilverGhost
Re: Hasegawa 1/700 IJN Haguro - building from Myoko
Post by SilverGhost »
Make 127mm AA-gun turrets using Flyhawk PE and a little scratchbuild (ladders, breechs of guns)
Barrels from Master
And I don't cut through the back of the AA-turrets
Maybe it's mistake
SilverGhost
Complete 127mm AA-gun platforms using Flyhawk PE and Hasegawa details
Aft pair of guns were at the wrong place and I correct them
make some details: doors, portholes, ventilators, ladders, grilles, lamps
SilverGhost
Assemble aft searchlight platform using Flyhawk PE
Make new portholes and doors
Really nice work so far. Great progress.
Joe Simon
Post by Joe Simon »
That looks great!
Angeliccypher
Post by Angeliccypher »
In a word: wow
Gabriel
SilverGhost
Thanks to all!
3 nights I spent on the assembly of funnels:
- remove plastic grilles (replace by Flyhawk PE)
- scratchbuild details inside funnels using Evergreen plastic 0.15mm
- scratchbuild pipes from wire
- fixing rings on pipes from Rainbow PE
- drill 0.1 mm holes on the funnels
- over grilles and details from Flyhawk PE
- remove 1 pipe from each side of forward funnel (Haguro had only 1 pipe on each side of funnel, Nachi - 2)
Total number of details at funnes (without PE railings) - 70
PE Railings on funnels will be install after painting.
Andrew
SilverGhost
Yesterday, I bought North Star Models resin crew
"Japanese Navy Parade" and ... "Imperial Russian Navy in working position" :heh:
It's not a joke
North Star doesn't make Japanese Navy in working position in this scale, and I needed a way out
So I bought Russians :big_grin:
In 1/700 scale nobody will be able to distinguish the Japanese from Russian
Because they have similar uniform
Unfortunately japanese uniform isn't for tropics...
The height of figures equal to 2.5-2.7 mm
I have headlight magnifier, super thin brush size 10/0 and much experience (when I paint in January 143 resin crewmens in 1/350 for battleship Sevastopol)
warspite63
Post by warspite63 »
Your incredible attention to detail will result in a truly magnificent model. Well done and keep up hte amazing work!
SilverGhost
warspite63 wrote:Your incredible attention to detail will result in a truly magnificent model. Well done and keep up hte amazing work!
Thank you!
In detailing funnels I use Takao schemes (Nachi-class funnels had similar construction)
Pipes on funnels were made using these photos of Haguro
Nachi had similar pipes (1 pipe on each sidewall of first funnel)
Myoko and Ashigata had 2 pipes on each sidewall of first funnel
Myoko
Ashigara
SilverGhost
Aft 25mm AA-guns platforms
Standard Flyhawk PE, new portholes, additional doors
Nose 25mm AA-guns platform
Standard Flyhawk PE, additional fenders first shots
Additional wiring on first funnel
marijn van gils
Post by marijn van gils »
Those funnels and AA platforms look great! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Marijn
ArizonaBB39
Post by ArizonaBB39 »
Amazing work!
SilverGhost
ArizonaBB39, marijn van gils
Abram, Marjin, thank you guys!
some differences "Before-After"
Nose searchlight platform
Flyhawk PE, copper rod/wire, additional ladders, scratchbuild davits from steel wire, Rainbow 0.3 fixing rings
SilverGhost
Complete aft superstructure
New portholes, doors, ladders and Flyhawk PE
Next will be crane for Haguro from Rainbow PE
Aik
Post by Aik »
:thumbs_up_1:
Best regards, Ievgen Timonin.
My models on this website
Top notch work here. Looks great!
Aphres
Post by Aphres »
:thumbs_up_1:
great work?
ArizonaBB39
Stunning work Andrew, thank you for sharing.
Goodwood
Post by Goodwood »
Really excellent PE work in such a tiny scale, but...they aren't going to make you sling multicolored paint at this thing for some sort of ARP ship promotional stunt, are they Andrew? :p
(Yes, I know the Haguro is one of the new anime ships WG will be offering soon.)
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
Return to “Completed Models”
