1:200 Iowa (BB61) 1943 + Pontos
Scott56
Re: 1:200 Iowa (BB61) 1943 + Pontos
Ran into an issue of installing the anchors (Thanks Trumpeter!) It seems when the created the mold, they increased the depth of the hull plating by around 3/16 of an inch. Needless to say I did not dry fit the anchors prior to installing the deck. Here is a picture of the hawse hole.
Since I wanted to show the anchor stowed, the hawse hole in its current form I had a big problem as it was too late to modify. That left me with modifying the anchor. Unfortunately, the picture I took of the anchor after it was modified was trash. In short I had to cut the shank a tad shorter than the flukes. I would then attach to the material that should not be there.
Yes, I noticed the glue glob and have rectified the problem. In the end, while I would have rather had the shank at the top of the hawse hole. Comparing the picture of the Iowa during construction and my result, I am satisfied with the outcome. Hopefully, this will help others who are building the Iowa or Missouri to solve the hawse issue before the deck is installed.
Scott
Salisbury, NC
USS Iowa BB61 1943 post refit
1:200 Trumpeter w/ Pontos detail up with deck
USS Missouri BB63 1945 1:350
In planning T2-SE-A2 tanker AO-82
Salisbury, NC
- BB62vet
Scott,
As you & I have been emailing re. the anchors - the photos look good. I'm glad you brought this issue up with me - at least I am in the position on my build to change/alter as needed.
Once again, I guess that "test fitting" parts is NOT part of Trumpeter's punch list for producing model kits.
