Calling all Flower-class corvette fans
ESC? Electronic Speed Controller?
Reid
Post by Reid »
ya i need a new one!!!
Reid, PIO of the 48th Fleet
http://www.48thfleet.com
GTDEATH13
Re: Calling all Flower Class corvette fans
Post by GTDEATH13 »
Has anyone built the Revell kit at 1/72 scale???
Just saw it and I am thinking of acquiring one...
I have read the review of the kit but would really appreciate something more comprehensive about the kit...
Oh, and are there aftermarket parts available (if required)???
NIKOS (NICK)
les
Post by les »
Yes, it's been built by several people. Check out the gallery on this site. The kit is a product of the 70's and has all the technology of the time. If you wish to do an accurate model be prepared to do a lot of modifications. Also, have a wealth of information about the ship you wish to model as they were all rather individual with various modifications. There are several books about the class out, some you may have to go to sites that sell used books.
There are a lot of aftermarket parts. Check with distributors like Loyalhanna Dockyard. It all will depend on how much you wish to spend.
If you wish to model it as is, it will go together fairly well and give you a basic model of a flower. The kit instructions are clear and offer a couple of paint schemes depending on which kit (Revell or Matchbox, both made it) you purchase.
Hope this helps.
GTDEATH13
Post by GTDEATH13 »
les wrote:Yes, it's been built by several people. Check out the gallery on this site. The kit is a product of the 70's and has all the technology of the time. If you wish to do an accurate model be prepared to do a lot of modifications. Also, have a wealth of information about the ship you wish to model as they were all rather individual with various modifications. There are several books about the class out, some you may have to go to sites that sell used books.
Hope this helps.
Thanks a lot Captain...
Already bought it, could not resist... :heh: :heh:
When the time comes I will get into more details.... At the moment I have a fleet of 15 BBs to finish
:crazy: :crazy:
NIKOS (NICK)
GTDEATH13
Post by GTDEATH13 »
NIKOS (NICK)
Dave Stone
Location: as far south as you can get before you run out of planet
Post by Dave Stone »
Having got the Revell 1:72 kit just a small question on how those of you who have built a flower class for RC solved these problems:
1 - how to get to the RC gear inside once the ship is built
2 - how to make the deak water tight.
3 - size and length of prop sharft (also how did you seal it?)
Been scratching my head over this as I have just started my build and it is also my first go at converting and scratch building (what little I have to on the way) so any help here would be fantastic.
Thanx to Aiden I have been given a few links that are a great help so far but just can not find information on how to solve these problems. for sure I expect it will have been under my nose but I just cant seem to be able to find it lol.
Thanx
Dave
The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts.
Bertrand Russell
ARH
Post by ARH »
1 You can like I do take the deck from the breakwater to the engine room, as in last picture.
2 You can run a section of timber or plastic on either side of the ship just below deck level, then put some silicon sealer and screw down the deck with some very small screws.
3 you could use a 9 inch long shaft, take the shaft apart and seal it with some grease and re-assemble.
Simple but effective.
a67ems
Post by a67ems »
Looking for further info on a drawing (plans) for a Canadian Corvette. Drawn by a Philip Thiel in 1/8' to the foot. This is of a 160' long vessel. Info I've been able to find indicate that this is one of the early forerunners of the Flower class. Called at that time Patrol Vessel, Whaler Type. Any sources for photos?
Thanks, Dave Sandulli
va3fpt
Flower Class Corvette HMCS Alberni need plans
Post by va3fpt »
Hi there new as of today to this forum , my name is Serge from Hawkesbury Ontario , Canada and I would like to build a repica of RCN Alberni (K103) as a gift for my father-in-law because his uncle Joseph Germain Pilon died on her in august 1944 of the coast of Great Britain in Channel for info see website: http://www.piloninternational.ca/intern ... npilon.htm
would lile to build 1/72 scale or larger a good source of plans would be nice so I could at least start on research THKS and will be loging in as much as I can work permitting.
Serge Cauchon
Re: RCN Alberni
This was a Flower class corvette - Revell makes a kit of one in 1/72, but there are probably some differences that you'll have to research to make the kit fit the Alberni.
This thread will be merged with the Flower class thread a little ways down later.
Laurent
Re: Flower Class Corvette HMCS Alberni need plans
Post by Laurent »
If I good remember, the canadian built corvettes had a different "butt" than the UK built ones, the after bulwark was a little more vertical, it made them few feet shorter...
Laurent
Rory Smith
Post by Rory Smith »
Ron,
What glue would best hold together the hull of the 1/72nd Revell kit? I have worked with 1/350th ships and like the model masters liquid cement in the little black odd shaped bottle with the metal syringe nozzle, but I am wondering if it would fill the gaps and hold well. I like this cement because it melts the plastic on small parts and almost welds them creating a clean finish when sanded, plus it does not seem to crack when flexed a little. I think a gap flling super glue would fill better and give a stronger bond, but I had a 1/350th USS Yorktown that I used super glue to attach the upper and lower hull sections and the seams cracked during sanding. I have heard of others using the old school testors tube stuff also, but I have never used that stuff. I have not worked with anything this big before. What do you think? Also, what is the best way to assemle the 4 hull sections? I will probably leave that keel strip along the bottom just because it is more gluing surface to hold the hull together even though the real Corvettes did not have it.
" You can't dig a foxhole in a steel deck, but I damn sure tried." - History Channel
ARH
Post by ARH »
Rory, I always use the clear glue that weldes the plastic together, thick super glue should be O/K , takes slightly longer to set.
As for the hull, I would lay the two port sides on a level board and glue, and do the same for the starboard side, when set glue the two sections together, put tape on the bow, stern and about 4 places down the hull. :thumbs_up_1: :thumbs_up_1:
Rory Smith
Thanks Ron. Is the glue you normally use possibly Tenax 7R, Model Master or Plastruct Plastic Weld?
ottoirving
Post by ottoirving »
Kriegsmarine Flower class
Image 267 Flower class corvettes builded, many countries had it, but 4 in the german navy. i found an article very interesting, it is an inspiration to me, because my 1/350 corvette will be a kriegsmarine. Hope it helps. Greetings
Flower Class Corvettes
in Kriegsmarine Service
by Stephan Bock
The French Flowers:
When the German army overran France, they found a number of French Navy vessels either damaged in the ports or being under construction in the shipyards. Four of them were Flower Class corvettes, the French having received the specifications and design from the British. Those ships were being built in the "Chantiers de la Loire" shipyard in St. Nazaire-Penhoet and to be named ARQUEBUSE, HALLEBARDE, SABRE and POIGNARD.
None of the vessels were completed when France fell and all of them were to be built for the German navy, which took over the unfinished ships officially on . ..
Arquebuse 16th of October 1940 as PA 1
Hallebarde 27th of November 1940 as PA 2
Sabre 29th of November 1940 as PA 3
Poignard in 1941 (exact date not known) as PA 4
The designation "PA" stood for "Patroullienboot Ausland" or foreign (captured) patrol craft and was used only for the Flower Class corvettes.
Due to the large amount of work soon to be carried out by the shipyards - both building new ships and repairing damaged ones - and material shortages, it took a long time for the ships to be finished. They were to be taken over by the 15th Vorpostenflottille, stationed in Le Havre and running on channel convoy duty.
The 15th Vorpostenflottille:
The boats of this Flottille were former Whale Catcher / Trawler of German origin, at that time armed with a 3.7cm main gun (ex-anti-tank guns in naval mounts!) at the bow and several 2cm AA guns and machine guns. Some boats began to be equipped with a single 3.7cm AA gun aft. The main drawback of those boats were the fact that their main enemy at night were British MTB and MGB. In order to be able to set up a coordinated return fire, they had to be lightened by flare shells, which the small guns available could not provide. Therefore it was a long standing request to either upgrade the boats armament with 8.8cm guns or provide additional vessels with such guns. A role in which we will see the PAs...
PA 2 was was the first of the class to be put into active service sometime at the beginning of September 1943 with the 15th Vorpostenflottille. The date given at Gr�ner is incorrect, since the first recorded action of PA 2 was in the night from 26th to 27th of September 1943. PA 2 at that time was on convoy duty, escorting the freighter MALADI together with the minesweeper M82 and M84, VON DER GROEBEN, JUNGINGEN and V1507 of the 15th Vorpostenflottille. The convoy was attacked by MTB of the Dutch navy together with British MGBs. Result of the action: JUNGINGEN damaged and MALADI sunk by torpedos.
PA 3 was the next to be put in active duty on 16th of November 1943. Her first action has not been recorded, her KTB (Kriegstagebuch - war diary) like all the others missing from the archives. One convoy duty that was recorded was that of the blockade runner M�NSTERLAND (which had made his way from Japan) from Boulogne to Calais on 20th of January 1944. The other escorts were V1506, V1507, V1509, V1511, V1512 of the 15th Vorpostenflottille and R43, R46, R47, R48, R49, R50, R51, R115, R126, R128 of the 4th R�umbootflottille. M�NSTERLAND was sunk by the radar guided heavy Dover batteries since the ship had given his cargo offboard and wasn't able to manoeuvre fast enough to avoid the hits. All in all Dover batteries fired 46 salvos. (Note: it was standing order at that time to make a zig or zag when the batteries fired. Because of the time it took the shells to reach the target, it could try and get out of his former course - SB).
Recorded as the first joint action of both PA 2 and PA 3 is the escort duty for the tanker RECKUM from Cherbourg to Le Havre on 26th of February 1944. Besides PA 2 and PA 3 the convoy was escorted by V1506, V1507 and V1509. The convoy was attacked by several waves of MTB / MGB and PA 2 and PA 3 are recorded to have fired 344 10.5cm flare shells during the run. Without this support, enabling the escorts to set up an effective return fire on the attackers, the RECKUM wouldn't have made it to Le Havre. One MTB was sunk. The tanker was later sunk by the Dover guns.
PA 1 was the last one to be commissioned to active duty on 15th of April 1944. PA 4 was never put into active duty, it was finally sunk unfinished as a blockship in La Telindiere / Nantes after the invasion.
Lifetime was short for the PAs. Before, and especially following the invasion, the allied air superiority increased steadily and the MGB / MTB attacks increased too, now being supported by destroyers.
PA 2 was sunk during the heavy bombing run of 325 Lancaster bombers on Le Havre at the night of 14th to 15th June 1944, together with six other boats of the flotilla. PA 3 seems to have survived the bombing, but obviously was not deemed worthy of repairs and was therefore decommissioned on 17th of June.
The final fate of PA 1 has not been clarified up to now, it too seems to have survived the bombing. Gr�ner states that it was decommissioned at 24th of August 1944. This could mean that it had been damaged and 15th Vorpostenflottille was not be able to make it seaworthy fast enough for the leave.
The 15th Vorpostenflottille left Le Havre at 28th of August 1944 as one of the last German units before it became "fortress Le Havre". The role originally intended to be fulfilled by the Flowers was being taken over by V 716, the former French trawler ALFRED II, which had a 10.5cm main gun and seven AA guns, mostly twins and quads of 2 and 3.7cm. It was nicknamed "Karstadt Dampfer" after the then new German Karstadt-shopping-centres, since the ship had an exceptional high bridge structure of several levels.
Armament and changes in Appearance of the early Flower class design:
The basic appearance of the French Flower class corvettes shows no real differences towards the British short focsle design. Since the armament when taken over by the German navy was much heavier, the structure was modified accordingly. The pic shows PA 4 when taken over by the German navy, showing the basic design at that point.
The ships had a German 10.5cm C/xx naval gun as their main armament, mounted directly to the deck or in a zareba akin to that fitted to the V&W class destroyers.
- At the end of the focsle, on each side, a single 2cm AA gun was set up in a circular bandstand. It can not be said at this point if the guns mounted were regular 2cm Flak 30 or Oerlikons.
- On top of the fully enclosed bridge a 2cm quad AA gun with gunshield is mounted in a circular gun tub.
- An oval raised bandstand over the full wide of the deck, build upon a central pole and containing a centrally mounted AA gun. Guessing from the photo it could be a 3.7cm AA gun without gunshield.
- A circular bandstand on a central pole, slightly lower then the above mentioned, aft of the
engine room skylight. It is armed with a 2cm quad AA gun with gun shield.
- A twin 3.7cm AA gun centrally mounted at the very end of the engine room casing, the half circle bandstand extruding over the end of the engine room. It seems a gunshield was fitted.
- Two depth charge throwers on each side, mounted on the deck at the end of the engine room casing
- Minesweeping gear mounted behind the engine room fitting. The main gun is installed already, but the AA guns are missing. The photo shows the modified bridge structures fitted.
- Minesweeping gear mounted behind the engine room casing, obviously with a "Toni" device for acoustic mines.
- The ship carried an external mounted MES (Mineneigenschutz) cable against magnetic mines.
To allow both the depth charge thrower and the minesweeping gear to work, the gun wale was cut down to deck level, beginning slightly in front of the end of the engine room casing.
The above description is based on the photo of PA 2 below, the only known existing photo showing a German Flower with its armament. The second photo shows PA 2 while outfitting. The main gun is installed already, but the AA guns are missing. The photo shows the modified bridge structure.
It is relatively safe to assume that the modifications on PA 1 and PA 3 were at least almost identical, since they were carried out at approximately the same time by the same shipyard.
The ships seem to have carried a medium grey paint over all, no different paint can be recognised on the superstructure, nor can a multi-colour pattern be recognised. The ships, despite their short life, look battered, and weld patches over hull damages are quite evident.
The shown photos are the only ones known up to now and are courtesy of Dr. Dieter Jung.
References:
deutschen Kriegsschiffe 1815 - 1945, Bd. 8/2
Erich Groener, Dieter Jung, Martin Maass
Bernhard & Graefe Verlag
ISBN 3-7637-4807-5
Seekrieg Im �rmelkanal
Gunther Naims / Lothar Friedrich
E.S. Mittler & Sohn Verlag
ISBN 3-8132-0810-9
The information provided is based upon the above mentioned references as well as the correspondence I had with Mr. Georg Prager, the lecturer of the book 'Seekrieg im �rmelkanal". My thanks go to him as well as to Dr. Jung for providing the photos and allowing us to publish them
(C) Stephan Bock 2003.
Conjectural profile of one of the German Flower Class Corvettes PA1-4. The basic image is modified from a small drawing in a book by Dr. Jung, the colours from the Snyder & Short Kriegsmarine chips (just eyeballed to match), and the pattern is based on Sperbrecher 13 (but not identical). The guns and other details await a photo to show exact arrangement.
1:700 Rules!
Building:
1/700 IJN Ise. (Hasegawa)
1/700 Crucero Baleares. (HP Models)
1/700 IJN Shinano. (Tamiya)
Next
1/700 DKM Graf Spee.
Rory Smith
I am not up on the HMCS Snowberry's changes over time, but would the photo in the attached link be of the Snowberry as the Revell kit is trying to represent? Looks like the forward main gun housing is two colors and there are a few other color differences from others' models I have seen posted of Snowberry. It almost looks like the number K166 has been photoshopped or something in this photo. Also, was the lower hull red or black? It appears black in this photo.
http://www.navy.gc.ca/project_pride/pho ... um=MC-2968
les
Post by les »
There are five pictures of Snowberry leaving Charlston after her refit. If you get the Warship Perspectives book, you'll find them in there. About the only pictures I could find for my build. Also Fine Scale Modeler ran an article on a Snowberry build by a guy who acturally talked to one of the crew. Don't remember which issue, but I'll check and see if I've got the article. My Snowberry now resides in the the Victoria BC Maritime Museum.
les
Post by les »
Also pom pom bandstand was located at the aft edge of the deckhouse. The skylight for the engine room was also longer. You might try John Lambert Plans. He may have done Alberni or at least one of the Canadian ships. Also, go to Flower Class Corvette website. There are some models and part of a build article there.
