Tin Can (DD/DE) Group Build!
For posting your photos of the group build subjects.
Pieter
Re: Tin Can (DD/DE) Group Build!
Post by Pieter »
I'm doing the very first destroyer, HMS Havock. If it works out nicely I may be doing Hornet (half sister and the second destroyer) as a waterline version.
Some progress shots. 4hrs of work since the start of the project.
Hull planked in styrene strips:
Turtle deck built up and 6pdr shields fitted:
And a first attempt to build the bow torpedo tube:
Gordon Bjorklund wrote:
Pieter, You look to be off to a great start on your project. What ship are you doing? You posted that this is the first tin can.
What do you have planned for the second?
Mark McKinnis
Post by Mark McKinnis »
Hi Gordon :wave_1: ,
At a quick glance, the Coontz Kit appears to be the mid to late 80's. I am trying to wrap up the Hancock, Pittsburg, and the airwings for Ranger, Hancock, and Lexington.
It may be awhile before I get to the Coontz.
I am looking forward to seeing the DD's as they get built. There is a lot of proggress already.
Good work guys :thumbs_up_1: ,
MM
Bob Cicconi
Post by Bob Cicconi »
Count me in! I don't know which ship I'll build, but it'll be in 1/700 scale for sure. I have to finish the 1/350 Bouvet first! :thumbs_up_1: :wave_1:
Bob Cicconi
Cliffy B
Post by Cliffy B »
For those that asked, yes I am doing a Butler DE, a modified one though. I'm almost done with the design drawings. I'm drawing them to scale so I'll be able to easily transfer them to the kit and knock out the mods in no time. Anyone have a favorite member of the class they think I should depict? So far none of the names jump out at me. Any of them named for a particularly unique individual? I'll have to read up on their namesakes while I build and decide on a good candidate. Nice thing is the kit comes with a huge sheet of numbers so you can mix and match to get any ship you want! I'll post a scan later on tonight. Cutting of the plastic should start tomorrow.
Everyone's builds are looking great so far! Glad to see more people joining in the fun as well. I can tell the finished builds thread will be beyond awesome already :thumbs_up_1:
Edit: Alright I've found my ship! The USS Oswald A. Powers (DE-542), named for a ENS Powers, a member of VT-3 (CV-5) at Midway and one of the 10 planes that did not return; only TWO returned to The Yorktown, 4 to The Enterprise, and none to The Hornet. A very bad day indeed. The Powers was one of several DEs that were suspended following the end of the war and were subsequently scrapped incomplete. I'll remedy that and have her in commission as planned in 1945. To facilitate the modifications I'll have her get torpedoed during the battle for Iceland, limp back to the States, and get re-built as the lead ship of the modified Butler Class. The rest of the new class will be built from the keel up or modified on the slipways with the new mods. Several DEs ate a U-Boat torpedo and survived to be repaired so the events are more than plausible.
This project is coming together now :big_grin: Drawings soon.
Edit 2: Alright here's the drawing!
Mods:
-25' Hull plug inserted in between the funnel and bridge structure allowing for sufficient internal hull space for an emergency diesel generator and more fuel oil. Above decks the plug allows a deck house extension to be be added housing two fixed 21" torpedo tubes (staggered) for Mk-35 long range homing torpedoes with 2-3 reloads per tube, 6-8 total.
-Two fixed Hedgehogs mounted atop torpedo deck house (about 25-30 degrees off the center line) with reload lockers. Two reloads for each mount.
-Mk-56 director atop the bridge to control the 5"/38s.
-One quad and two twin 40mm Bofors installed in place of the triple torpedo tubes.
-Whaleboat re-located to port side of the funnel.
-Funnel 20mm mounts moved aft of whaleboat and reduced to two mounts.
-ECM mast added abaft the funnel with one TDY-1 jammer ala DD-445 Class.
-Radars upgraded to SC-2 and SG.
-Added supports to 20mm mounts that hang off the superstructure.
I goofed a few things in the drawing
-Forward 20mm mounts beside the bridge will be reduced to one per side.
-Starboard 20mm mount abaft the funnel will be moved forward abreast the funnel. Port mount was displaced aft due to whaleboat.
So there you have it, enjoy! I'll slice the hull in half tomorrow and start on the plug.
Any thoughts, ideas, comments, etc... are appreciated as always!
Phantom Bill
Post by Phantom Bill »
I'm in! 1:350 Yukikaze with the Lions Roar upgrade, I'll decide on a second DD later.
In the box
In the box
Phantom Bill
Phantoms Phorever!
1:350 IJN P.102 (1945)
1:350 IJN Akitsushima (1895)
1:350 IJN Fubuki class...TBD
Simon_Hwood
Post by Simon_Hwood »
Slow beginings on HMS Bentink. Decided to try and go all out, using Trumeter USS England + add ons as below.
have drilled out the fairleads around the hull edge and filled any unwanted holes the maindeck. Most RN Captain class had the 2 single 20mm on the quarterdeck removed and only carried 2 k guns on each side. Bentink was one of the first Buclkye's and did not have the 2 20mm fitted on B gundeck & only had one 20mm on each side abeam of the funnel.
Have also started work, with some success and some otherwise on the B gun deck / bridge structure. I am having a go at putting some 3 dimension feel into the steps up the side of the structure & the handrails, which are just moulded lines on the kit.
The handrails are working ok (cut down 1/700th 3 bar railings, the steps less so, (cut up vertical ladder) will strip off what i hade done & try to get it more even.
Si
Simon Heathwood
Avery Boyer
Post by Avery Boyer »
Ok, so I'll be scratchbuilding the USS Mahan (with a little help from the Midship "Models" kit...) in 1/700.
We've got some really cool projects going here, and with so many great builders it's all a little intimidating :big_grin: Keep it up guys! :thumbs_up_1:
drdoom1337
Post by drdoom1337 »
Everybodies kits are looking great thus far. Remember this group build is not only limited to gun destroyers. You can build modern missile ones as well. My own second build will be a sovremenny.
PS I want to post some photos of the Yukikaze, but my camera has been stolen by my sister :mad_2: :Mad_6:
taskforce48 wrote:I have made some progress on the Ward,
Looks nice. Is this the Gulfstream kit? I ask because I just picked the Ward (and the YMW Benham) up from a fellow modeler. How do you like the kit so far?
Bob Cicconi
I posted 2 responses on this site, but they evaporated! I'll be doing a 1/700 subject to be determined after I finish my current project which is the YS 1/350 Bouvet. :wave_1:
Bob Cicconi
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Bob Cicconi wrote:I posted 2 responses on this site, but they evaporated! I'll be doing a 1/700 subject to be determined after I finish my current project which is the YS 1/350 Bouvet. :wave_1:
Bob,
This happened to Cliffy B, too. And probably others.
Your post(s) is probably on different page of posts. So, Sort this thread by "1 Year" and "Descending" with the tool at the bottom of the thread page. Its a pain, but it works.
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
taskforce48
Post by taskforce48 »
Martin,
I like this kit very much! It is very well designed and executed for a resin kit of it's age, only think that I could say is lacking is the instructions. They have some wonderful illustrations, but they rely mostly on written instructions. For someone who knows this class inside and out, that might not be a problem considering the low piece count but it can get confusing. Now that my water base has dried, I will get back to working on the ship. Hope to post some pics this weekend of where I am at. To everyone else who has been posting, some really humbling work out there! You guys are doing awesome, keep it up :thumbs_up_1:
drdoom1337
Finally some photos of the Yukikaze
taskforce48
:thumbs_up_1: Keep it up! Glad to finally see you up and running.
David Griffith
Location: Waiting for HMS Glatton in resin. Not holding my breath!!
Post by David Griffith »
Dear All,
With a bit of luck, here are a few pikkies of the Dragon 1/700 USS Monssen, some of the main parts dry-fitted, and a sprue of the little bits. Please escuse the filler that I have not yet rubbed down, but this a work in progress, of course.
I must say that I'm very impressed with the level of detail that dragon have managed to cram in. I don't think there is a great deal that needs to be added. However, I shall be replacing masts, radars and Oerlikons. Railings and rigging go without saying.
Now let's see if this computer dum-dum can get this machine to play ball. Wish me luck!!
Kind regards,
David Griffith
"For scientific leadership, give me Scott. For swift and efficient travel give me Amundsen. But when you are in a hopeless situation, when you are seeing no way out, get down on your knees and pray for Shackleton."
Gordon Bjorklund
Post by Gordon Bjorklund »
Drdoom1337 and David G,
It's great to see the progress you have made on your respective builds.
This last week I got a lot done or started but didn't get very much finished. I finished the 5"guns , mounted the deck to the hull, added some details to the torpedo tubes, deck houses, started on the stacks, mast and the Mk 37 director and got the twin 40mm guns ordered. Gee, that sounds like a lot but the pictures don't look a lot different than the last ones I posted.
Well, until next time, keep up the great work and enjoy your time at the work bench.
Gordon
Thundergrunt
Post by Thundergrunt »
Well late post for me But im in for this GB and Co Host with the Good Doctor, Im in for a 1/700 Dragon Arleigh Burke USS. Higgins DDG-76 and Possibly DKM Zclass # 37 Pic to follow
In Port: Building
1/350 USS. Conway DD-507
1/350 USS. Jenkins DD-447. 50%
In the Yard: Planned
1/350 USS. Claxton DD-571
1/350 USS. Watts DD-567
Pieter
Post by Pieter »
I've started working on weapons and small fittings, which will be added later in the build. Guns and navigational aids are from a Kombrig kit. The guns will have extra parts and shields added.
On the deck I've added the funnels, conning tower and the large ventilators as well has the engine casings. As these vessels had hardly any superstructures almost everything happened on deck, which means will have to built much more detail. Conditions on board in heavy weather must have been awful.
Total time spent so far: about 10hrs.
Gordon Bjorklund
The USS Fletcher build continues, all of the major components are now done and it's the little things that need to be worked on now. I hope to get a coat of primer on her this weekend.
Gordon
Quincy
Post by Quincy »
Looking good Gordon! :thumbs_up_1: :thumbs_up_1:
Bob Pink.
Return to “Group Builds”
