Calling all Independence-class LCS fans
Bigdaddy Mark
Re: Calling All USS Independence LCS-2 Fans!
Post by Bigdaddy Mark »
When I painted mine I used a dark gray to zebra stripe the ship, then I used a haze gray with a touch of aluminum mixed in. After it dried I thought it was to bright, then after I put a coat of future on it I was seriously nervous. Once I put on the dull coat it looked much better, and then when I brushed on the pastels I was happy with the results. I used black, brown, and white. I used vertical streaks to make it look like weathered aluminum. This was the first time I used an airbrush, If I ever build another I'd mask fine horizontal lines and use black to zebra stripe it.
Here's what I ended up with.
Hope it helps.
~ Chester W. Nimitz ~
mongo580
Post by mongo580 »
So will these ships get the same Camo Scheme as to be applied to USS FREEDOM?
Too early to tell, but probably not - as mentioned above, there is some suspicion that the new scheme is merely meant to hide the exhaust stains on the Freedom hulls, which are not present on the Independence class.
maxim
Post by maxim »
Are any helicopters assigned to Independence? It is realistic to use the MH-53E Sea Dragon?
I have read that the MH-60S cannot pull the available mine sweeping sleds, therefore there is currently no mine sweeping module available (as there is no anti submarine module?).
Maxim, you may wish to read the posts starting from here for more details on the limits and status of current LCS modules.
EJM
Post by EJM »
I'm going to be starting work soon on the 1/350 Trumpeter USS Independence LCS. But there's one major problem I'm having: Where's the waterline mark? I can't tell how high or low the red bottom should be as well as the placement of the black boot stripe. When other people were painting their ships, how did you figure out how to paint the bottom hull? What methods did you use?
The Navy posted this image today - but is it enough to out-turn a torpedo?
http://www.navy.mil/management/photodb/ ... 74-218.JPG
Looks like they're doing donuts on someone's lawn....
More like a blueberry cinnamon bun*.
*I have never encountered such a thing before.
It could make for a fun sea setting for my 1/700th kit.....
I bet someone out there somewhere makes a blueberry cinnamon bun...
EJM
Post by EJM »
Would a ship such as the LCS's benefit from having the SPY-1F Aegis radar on it? The SPY-1F is a small version at about 8 feet in diameter (1/4 of an inch in diameter in 1/350 scale) designed to fit Frigates and other smaller vessels.
http://www.globalsecurity.org/military/ ... riants.jpg
Or should I not put any SPY-1 radar panels on at all? The only other pic I found was this concept sketch here:
http://www.austal.com/Resources/Promoti ... 1-wide.jpg
Here's what I was possibly thinking of doing to my model:
http://img.photobucket.com/albums/v216/ ... C03920.jpg
maxim
Post by maxim »
I would add it - the real LCSs lack good radar.
EJM
Post by EJM »
For anybody that wants to follow along, I started a thread here:
http://www.whatifmodelers.com/index.php ... 350.0.html
Since there is no LCS Multi-mission Combatant ship.......either in real life or model kit form, I started to build my own What If model. I'm taking a lot of liberties with some things, but it's all for fun. :big_grin:
veliko_pile
Post by veliko_pile »
Anyone have the layout of the hangar? Even a basic one, walls, doors etc?
Oh duh, total fail on my part :censored_2:
There have not been a lot of photos of Independence posted on the Navy.mil site (last new one was July of last year that I can see) and I never came across any elsewhere that I saved. I typically trawl the Navy photo sites once every 2-4 weeks, which is why I had those Freedom pics so fast for you.
A nice high-rez photo of LCS 2 and 4 sailing together:
http://www.navy.mil/management/photodb/ ... 64-014.JPG
Differences: anchor hawse, no "bump" at deck level of superstructure face, and no bridge wing on LCS 4 (or rather, LCS 2 gained the bridge wing, but not sure if that's a permanent improvement that'll be retrofitted to the newer LCSs).
AyalaBotto
Post by AyalaBotto »
Hi,
Another difference: on LCS-4 the 30mm Bushmaster Gun is clearly visible.
Ayala Botto
"Ayala Botto Model Ships"
Facebook: https://www.facebook.com/AyalaBottoModelShips
The 30mm is part of the Surface Warfare module, and is thus temporary - I wouldn't count it as a difference within the class.
