whaynes
Post by whaynes »
Does anyone know if Missouri had hull numbers at the aft quarter as well as the bow in Sept. 1945? Also, were the 20mm ready ammo lockers painted deck blue on their exposed upper surface at that time? Thanks.
Walt Haynes
whaynes
Post by whaynes »
Just answered my own question. There is a photo in Floating Drydocks Plan Book on page 241 clearly showing the aft hull numbers at that time.
Russ2146
Post by Russ2146 »
Looks like everything was wartime except the wood deck during the transit to NY
Russ
Tony Bunch
Post by Tony Bunch »
Hi Guys,
Hi Walt,
Yes and yes; even though pictures that I have make it extremely difficult to tell.
I'll keep hunting for a definite picture showing examples of one or both.
Check this out...
http://www.youtube.com/watch_popup?v=vc ... r_embedded
HTH, Tony
whaynes
Post by whaynes »
What are parts F5 on Tamiya 1/350 USS Missouri? Does anyone know where a photo of these might be? They are located about 3/4ths of the way back toward the stern near the side rail. Thanks.
Walt
Russ2146
Post by Russ2146 »
If you mean this
How about stowage of this
It is visible in my 11/3 post forward of the stbd catapult.
Russ
whaynes
Post by whaynes »
Yes, thanks so much. Walt
Terry
Post by Terry »
I'm looking for confirmation of the deck camber height from a second source. Floating Drydock's Plan Book for BB63 says and I quote: " The Iowa class ships had a camber of 5 feet in 53 feet 6 inches."
That equates to a rise of 1 in 10.7 . Taking a centreline to outer deck (not including gutter) dimension of 16306mm gives a total rise of 1523mm or near as exactly 5 feet. At 1/350 scale this represents an arch in the deck of 4.35mm high at frame 150. With some frustration the elevations of the main deck superstructure show no rise in the deck level between frames 137 and 151.
I'd appreciate a second opinion that backs this camber dimension up, because photo's of the quarterdeck don't appear to support this dimension. I'm prepared to accept eyecromiter calculations, but prefer dimensions from another plan source if anyone has some? :thumbs_up_1:
Kind regards,
Terry
Russ2146
Post by Russ2146 »
I know its a different class, but take a look at the USS Washington website page
http://www.usswashington.com/bdy_pln1.gif
And
http://www.usswashington.com/bdy_pln3.gif
The camber is not uniform over the width of the ship.
Russ
Tony Bunch
Hi Guys,
Furthermore, the upper deck levels probably have no camber.
I'd bet the camber is no more than 8 inches across the main deck.
I don't have any plan drawings, but I'd imagine someone will pipe in eventually.
If you have no luck, I can contact someone whom I know will know.
Tony
rtwpsom2
Post by rtwpsom2 »
To address Russ' comment that camber is not uniform, I would like to add that it is and it isn't. If you look at cross sections, camber takes the form of an arc that runs from one outer edge of the deck up though the centerline then back down to the other edge. Taken across the length of the ship, the cylindrical nature of the structure adds torsional strength to the "spine" of the ship. It keeps it from twisting but allows it to bend up and down slightly. The exact radius of the camber does not vary from cross section to cross section, it is constant from the front to the back of the ship. However the width of the ship means that that arc drops more as it gets further from the centerline. Thus the height of the camber, the vertical distance between the centerline and the outer edge of the deck, does increase as the ship gets wider in the middle, then decreases again as it narrows towards the stern.
Typically the only decks that have camber that would be modeled are the main deck and shelter deck. Third level decks and above tend to be flat inside the structure and sloped outward outside the structure. Lower level deck also have camber, this greatly increasing the structural integrity of the hull. Contrary to popular belief, camber is not built into a ship to drain water off of the deck. If you consider the fact that a ship is in constant rotational motion, what might be sloped down one minute could be sloped up the next. :D
Terry
Post by Terry »
Further to your comments Rob about the uniformity of the camber, something that is noticeable on the Iowa class (and the South Dakota Class is similar also) is the subtle "kick-up" toward the stern. The total rise to the stern at about frame 216 from frame 150 measures 1000mm (or 2.85mm at 1/350). Even if this deck height at frame 216 were to be a horizontal chord back to the superstructure, (and my suspicion is it is not) the photo's don't seem to support this.
Interesting point about the camber allowing some flex. From an architectural perspective (my point of view) the pre-camber of the deck structure would also assist in carrying greater load with less deflection than if it was flat.
Thanks for your input Tony. I'll keep in touch if nothing definitive arises from my query.
Terry
SeanF
Post by SeanF »
rtwpsom2 wrote:Typically the only decks that have camber that would be modeled are the main deck and shelter deck. Third level decks and above tend to be flat inside the structure and sloped outward outside the structure. Lower level deck also have camber, this greatly increasing the structural integrity of the hull. Contrary to popular belief, camber is not built into a ship to drain water off of the deck. If you consider the fact that a ship is in constant rotational motion, what might be sloped down one minute could be sloped up the next. :D
I must admit, it has always been my assumption that drainage was the only reason for the camber. However, I'm sure it's still a reason for it. The comment above about rotational motion is a bad argument; camber means that no matter how far a ship rolls (without capsizing, of course), there is always a downward slope to the immediate port and starboard of the point that is currently flat, thus guranteeing that water can not pool on the deck. Think of roofing: if a completely flat roof sags just a little, it collects water, the weight of which causes more sagging, thus collecting more water, etc. until collapse. If the roof has adequate built-in slope , a little bit of sag will still not result in a net depression that can catch water. Since a ship rolls, a fixed-angle slope can become purely horizontal at a certain angle of roll, but a correct camber should never catch and hold water at any angle of roll.
- Sean F.
rtwpsom2
Post by rtwpsom2 »
I prefer to think of it as a very beneficial side effect. Structurally, a ship the size of Iowa would twist apart at the seams without it. Granted it might take a few years.
Rob-UK
Post by Rob-UK »
I've got my 1:350 USS Missouri kit ready to start, but I'm considering doing a conversion to her Korean war appearance around 1950/1. The obvious alterations are the removal of catapults and many of the 20mm mounts, and the addition of a new main mast and new radar atennas. Are there any other major changes that should be considered which spring to mind? I would do a full study of the superstructure for changes to the kit, but all 5" and 40mm mounts appear unchanged.
USS Missouri in action off Chong Jin, October 1950
c/o wikipedia.com
USN_Matt
Post by USN_Matt »
Ok i do not know if this has been addressed yet or not, but on the Tamiya 1/700 Missouri, it says on the paint chart to use RAF Ocean Grey. I do not know if that is correct or not, so that is how i painted her hull. Was she painted with the RAF Ocean Grey or is that just a misprint? Some pictures i have seen apperently it is Ocean Gray 5-O . Idk every ones take on that so I am just pointing it out.
That's their closest match for 5-O Ocean Grey, since they don't make 5-O itself. Go with your 5-O :)
USN_Matt
Post by USN_Matt »
Thanks Timmy
I already built and painted the Missouri, but i royaly screwed the camo up so i have been repainting her. Didnt know if that was right or not, but i am gunna go with the 5-O as its more historically acurate
USN_Matt
Post by USN_Matt »
Ok i have a question. I am planning on building ALL of the ships in the Iowa class. I know what i would have to do to make the New Jersey and Wisconsin. But any one know what i would have to do to modify an iowa or missouri model to make the Illinois and Kentucky?
Sr. Gopher
Post by Sr. Gopher »
Well, Matt, you could check this build; made by Mr. Abram Joslin: http://www.modelshipgallery.com/gallery ... index.html
Current builds:
Planned builds:
3 more 1/700 AH submarines
