Calling all King George V-class (WWII) fans
Ivan
Re: Calling all HMS King George V class (WWII) fans
Post by Ivan »
Good afternoon. As this photo refers to the fall of a 42-year we assume that, have not had time to finish painting the deck....=)...And so like I do in my 43rd year, I think the right will be painted with gray deck paint.At the moment, I am more interested in the question with the portholes of the hull ...were there visors or not?..and looked like the portholes in the bow of the ship (as they were closed?) and the plugs of the lower tier .....so as I have no idea about the appearance of the square stern Windows..for 1943..I would be very grateful if you could help me with these questions .Thanks. With respect Ivan
In Work:
HMS "King George V"-1942 1/350 Tamiya-Pontos-Eduard as well as
hands and head:
viewtopic.php?f=59&t=191026
Martocticvs
Post by Martocticvs »
Re portholes: depends on the year you're depicting her? Presumably by the fact you're using the Prince of Wales kit you're doing her pre-refit? The answer then would be, with some caution, almost all with the 'visors'. Later, many of those not plated over had rings instead.
And no corticene on the KGVs, as far as I'm aware. Probably just the primer coat showing through worn top coat, as already suggested.
As for the stern deadlights - this is my interpretation based on the material I have been able to gather: http://www.prdobson.com/wp-content/uplo ... GV_099.jpg
Ivan
Post by Ivan »
..Thanks..I'm doing to repair...to Italy in 1943.This photo is all I have where I can see the type of porthole that was repaired in connection with the collision and before the reconstruction for the Pacific Ocean..Can anyone share a better image for the given period.Thanks
PS these two pictures visible differences in the caps of the Windows ....me and interested in what the right for KGV on 43-nd
I would be grateful for any photos for this period ... :worship_1:
In Work:
hands and head:
Maarten Sch�nfeld
Post by Maarten Sch�nfeld »
The KGV, as first and only ship in her class, had the square windows with hatches in her stern for the Admiral's quarters. These were similar to those in Rodney and Nelson. These remained there as far as I know for the rest of her life.
hmskinggeorgevmpl521 1946.jpg (20.86 KiB) Viewed 2972 times
Only in Nelson these were replaced by round scuttles (portholes) during the war, also Rodney kept the square windows her entire life. Only some of the windows were plated over, temporarily or permanent.
So for any model of the KGV you should replace the round scuttles with square windows and hatches, either closed or open. All other four ships in the class had round portholes for their entire life.
Roger Whittaker +9/13/2023
EJFoeth
Post by EJFoeth »
If you look at HMS Prince of Wales closely you'll find she used to have square openings in the hull as well:
Maarten Sch�nfeld
EJFoeth wrote:If you look at HMS Prince of Wales closely you'll find she used to have square openings in the hull as well:
Aha! but did PoW these square windows on completion, or were these already replaced by scuttles as shown in this very detailed picture? When did the changeover take place?
EJFoeth
Post by EJFoeth »
When she was launched some type of cover present not the round scuttles seen later... most pics are of the bow so it's difficult to make out what exactly was present. Also, when KGV was launched the square scuttles are not visible at all. The pic above is HMS PoW during fitting out, so very very early career.
Ivan
Post by Ivan »
good afternoon...and could you tell me 1943 year on King George portholes had visors or not
In Work:
hands and head:
Maarten Sch�nfeld
Ivan wrote:good afternoon...and could you tell me 1943 year on King George portholes had visors or not
King George V had the square hatches or shutters (do you call them visors? why?) for her entire life, so also in 1943.
Ivan
Post by Ivan »
Good afternoon. ..I asked about the round portholes...there are no visors on the photos of the 45th year...and I was wondering if they were in ' 43.
Prince of Wales 26 (1).jpg (44.51 KiB) Viewed 2704 times
In Work:
hands and head:
Maarten Sch�nfeld
Ivan, that picture is of the Prince of Wales!!! not the King George Vth
And what you call 'visors' are in fact 'raingutters' or often called 'eyebrows' by us modellers. They have nothing to do with visors on a helmet!
Yes, these were applied at any time and both over the circular portholes (more correct: scuttles) as over the square ones.
Ivan, where are you from? It seems much of this conversation is about using the correct words to indicate what you mean, so a language issue. It helps if you explain your background! And marine terminology can be quite tricky across languages.
Ivan
Post by Ivan »
so-as with portholes worked out ...help to understand with the oerlikon on the stern...kagero on drawings gives 5 in nests and 4 on the sides from them...but the pictures I found the extra barrel
In Work:
hands and head:
Martocticvs
As I mentioned earlier, for the 'visors' - rain gutters / 'eyebrows' / rigols - it depends on the year. From launching, KGV had the eyebrows on ALL scuttles. However, starting around 1943, when they started plating over some scuttles, there appears a mixture of scuttles with eyebrows, and also some with complete rings, as can be seen in this photo from late 1945 (immediately post-war)...
Allan C. Green 1878 - 1954 - State Library of Victoria - via Wikipedia
Maarten Sch�nfeld
Ivan wrote:so-as with portholes worked out ...help to understand with the oerlikon on the stern...kagero on drawings gives 5 in nests and 4 on the sides from them...but the pictures I found the extra barrel
Good research Ivan! Sharp eyes... :thumbs_up_1:
Martocticvs
That photo is from 1943, whilst she was in the Med (according to the IWM caption). That does appear to be an additional 20mm barrel there, on the centreline. The structure abaft it appears much the same as the shield around the UP launcher that was positioned there originally - the box inside it however is not the UP launcher, so presumably a radar kit. There's no evidence in that photo that I can see to suggest that 10th oerlikon is inside a nest, so presumably it is an additional open pedestal mount. Many were added to the ship at this time - including in the waist, either side of the catapult.
Maarten Sch�nfeld
Here a picture of the semi-circular shield that used to be there for the UP launcher, in 1941:
Btw: note the square windows with shutters of the admiral quarters below.
Ivan
Post by Ivan »
Good afternoon and thank you....if the photo is the tenth gun took the place of the rocket launcher ....but then there is almost no room for a booth with an antenna ....With portholes figured out and installed on the model..=)..
In Work:
hands and head:
EJFoeth
Post by EJFoeth »
larger version:
Unhelpfully vague shot
Maarten Sch�nfeld
Ivan wrote:Good afternoon and thank you....if the photo is the tenth gun took the place of the rocket launcher ....but then there is almost no room for a booth with an antenna ....With portholes figured out and installed on the model..=)..
Excellent pictures, EJ! Thanks.
As you see, the booth is behind the former UP gun emplacement. Yes, it's all a bit cramped, but the 20mm guns were very much needed then!
Another interesting notion: the degaussing coil is still installed in this picture!
Martocticvs
I think the coil was removed (well, made internal anyway) sometime in '43... must have been later in the year. Although saying that, the RMG research guide (https://www.rmg.co.uk/discover/research ... g-george-v) suggests to me that the coil must have been removed during the Feb-July '44 refit.
The larger photo plus the slightly blurry one seem to make it fairly clear that the extra 20mm is indeed mounted where the UP launcher used to be, and the radar box is in whatever space was left over behind it. Looks like just barely enough room to squeeze between the aft corners and guardrails to get at the ensign staff. At least for that particular operation, the Kagero plan is wrong to show the rafts in that position. (Kagero plans are nice, but shouldn't be relied on for accuracy!)
The 'box' is clearly the same one still present there in '45 following the big refit, onto the roof of which they later mounted a radar set (censored in this photo)
The shape of the UP shield has been modified from its original form as well - the forward-most third has been raised up higher. This was probably to prevent the oerlikon gunners accidentally firing into the ship's superstructure!
