Model Monkey Sneak Peeks
Re: Model Monkey Sneak Peeks
Post by ModelMonkey »
As they say in Dallachy, Scotland, "Feast yer eyes!"
Lord Dingwall.jpeg (12.31 KiB) Viewed 3145 times
Coming soon, here's the design for a USS Missouri BB-63 bridge at 75% complete. Although intended specifically to help improve the Tamiya and Very Fire 1/350 scale kits, it will also be made available in 1/450 and 1/700 scales. Other scales are possible.
Some of what you see here will change as the design matures. [edit: this model is available for sale at https://www.model-monkey.com/]
Miguel
Post by Miguel »
ModelMonkey wrote:Coming soon, here's the design for a USS Missouri BB-63 bridge at 75% complete. Although intended specifically to help improve the Tamiya and Very Fire 1/350 scale kits, it will also be made available in 1/450 and 1/700 scales. Other scales are possible.
This is brilliant !!!! One of the hiccups of both models
As usual , stealing the show Steve ,good job :thumbs_up_1:
No Whine Policy
1.- Modify it
2.- Ignore it
3.- Don't build it
Thanks, Miguel!
Also coming soon is a World War I-era "Spandau" LMG 08/15 machinegun for Revell's classic 1/28 scale Fokker Dr.I triplane and Fokker D.VII. It can be made available in other popular scales. This weapon was made famous by aces like Manfred von Richthofen and Werner Voss.
Here's the design at about 50% complete. Some of what you see will change.
Seeking help from you Supermarine Spitfire experts. Seeking an authoritative drawing similar to the propeller blade drawing below for a Rotol wide-chord propeller blade fit to Spitfire Mk.V, etc. Any help is hugely appreciated.
Spitfire Rotol propeller 64926388_550653445464285_2979923499541324336_n.jpg (17.17 KiB) Viewed 2697 times
Spitfire Rotol propeller 5-11-Album.jpg (19.96 KiB) Viewed 2697 times
Nearly complete, wheel wells for classic 1/24 scale Airfix P-51D / P-51K / Mustang Mk.IV kits will be released shortly.
The test piece below will be tweaked for best fit and significantly further detailed. The design benefited from scans of original North American Aviation blueprints. The model's aft spar is set at the proper angle to help the modeler correct the Airfix kit's wing dihedral, which is molded too flat.
The 1/24 scale P-51D Mustang (Mustang Mk.IV) wheel wells design for the classic Airfix kit is now about 95% complete.
Here are some renderings of the design so far. Some of what you see here will change.
[edit: design complete and available at Model-Monkey.com]
Model Monkey 1-24 P-51D Mustang Wheel Wells for Airfix at 90 percent complete a.jpg
Model Monkey 1-24 P-51D Mustang Wheel Wells for Airfix at 90 percent complete b.jpg
Model Monkey 1-24 P-51D Mustang Wheel Wells for Airfix at 90 percent complete c.jpg
Model Monkey 1-24 P-51D Mustang Wheel Wells for Airfix at 90 percent complete d.jpg
