I messed mine up when trying to fill in the Trumpeter Missouri kit; I decided to just cover it all up by making a massive awning for the entire rear deck: http://www.modelshipgallery.com/gallery ... index.html
proflooney
Post by proflooney »
I am not inyo plastics i like much bigger, that being said for the decking couldnt you get some basswood or balsa say 1/64" tick strip it and hand lay the deck with real wood?
Joe
veliko_pile
Post by veliko_pile »
hey guys, I need some photos, of just the looks of the antislip decks there where in the 40mm bofors gun tub in the Missouri during WWII, I want to do some home made photoetching so I need the sample on the deck. Thanks
Russ2146
Post by Russ2146 »
There wasn't a heck of a lot of room to show anti-skid given tub size and 40mm mount size.
Here's Iowa at commissioning.
veliko_pile
Can I take the anti skid that Lion Roar gives in there set as a reference??
Russ2146
Post by Russ2146 »
I would think that the Lions Roar pattern is accurate enough. I'm thinking that the pattern that would apply the quickest and most efficiently would be the one used.
veliko_pile
any idea how can I get some accurate drawing of the floor of the gun tubes of the bofors , so i can make the PE right away, so I don't have to cut the pieces out of a unique sheet of anti skid deck
Russ2146
Post by Russ2146 »
I have an Adobe pdf file of the Missouri Booklet of General Plans. It is around 7.18 Megabites. I can try to e-mail it to you if you PM your address to me.
LAE519
Post by LAE519 »
Hi Guys,
Quick question. I have a friend who has a Toms' Iowa Converson Set TC3500 - for Tamiya Missouri Kit. This includes mixed media resin & white metal parts along with PE frets 3510 Fast Battleships, a whit metal Kingfisher & Toms 3509 figures set, (don't know if this is part of the set, but its in the box).
Any idea what this might be worth, and is anyone interested in picking it up? I can't find a price for this set anywhere
:thanks:
Larry
ArizonaBB39
Post by ArizonaBB39 »
Well Yankee Modelworks has an Iowa class conversion set too retails for $30 or so. (I believe it doesn't come with any PE) So I'd say for the conversion set at least thats a price to think of. The Tom's set I got a while ago didnt have the PE or figures like yours and if I remember correctly I paid around $25 for it. Hope that helps.
LAE519
Post by LAE519 »
ArizonaBB39 wrote:Well Yankee Modelworks has an Iowa class conversion set too retails for $30 or so. (I believe it doesn't come with any PE) So I'd say for the conversion set at least thats a price to think of. The Tom's set I got a while ago didnt have the PE or figures like yours and if I remember correctly I paid around $25 for it. Hope that helps.
Thanks for the info... :thumbs_up_1:
The "Black Dragon", Battleship New Jersey, somewhere in the Pacific. Photo scanned from the National Archives, RG 80-G
NARA 80G 288299
NARA 80G 288299
Landlocked
Post by Landlocked »
Re USS Missouri at war's end:
When did the 20-B blue paint get removed from the deck?* Was it still there for the surrender ceremony?* Would it still have been blue during the voyage home?* Also, did Missouri ship any twin 20mm mounts during the war?
Also - did it have the all-blue 5-N hull before returning to the States?* The photo leaving Pearl on 29 Sept appears to have no demarcation line common to the usual Ms 22. http://www.history.navy.mil/photos/imag ... h45919.jpg*
* duh, just found the answer only three pages back!
So, how about those twin 20mm??
Thanks in advance,
LL
In shipyard:
Trumpeter 1/350 USS Hopper DDG-70
Russ2146
Post by Russ2146 »
Deck looks 20B to me.
Hull at surrender ceremony:
Enroute, NY, Sept, 1945
NY, Oct, 1945
Landlocked
Tony Bunch wrote:Hi Guys,
In a previous Missouri paint scheme post; Going back to the paint scheme in late 45, Summrall's book on the Iowa's list Missouri as wearing Ms22 through 1946. The hull was re-painted 5N entirely while at a stop-over in Pearl harbor; September 1945. The paint scheme is still referred to as Ms22. Missouri's wood decks were holy-stoned to their natural wood finish while enroute to the states in this same time frame. Numerous images of the surrender ceremony show Missouri's decks to still be painted in 20B. By contrast, there is a great o-head shot, (in Stillwell's book and elsewhere), of Missouri transiting the Panama canal at the end of September 45 showing the majority of her wood decks as then un-painted; but not entirely. The remaining non-wood horizontal surfaces were still 20B at this time.
Also, the 3x20mm main deck galleries abeam Turret2 were gone. Nothing there, but wood planking.
So, if a modeler wants to do Missouri in her WW2 fit with unpainted decks, it is most certainly doable. Just remember the 20mm's on the main deck in the aformentioned area were gone; so the Tamiya main deck in this area will need to be filled in or replaced with the Modern New Jersey foredeck piece. This works for one thing, but then creates the need to make other changes. None of these changes needed are too much for an Iowa fan!
I think that covers it!
In shipyard:
HvyCgn9
Post by HvyCgn9 »
Can someone tell me where the port'N'starboard Nav lights are located on an IOWA class my club mate is sorting out his Pre-build research on BB-63 and despite pouring over the side view plans we could not locate a position for them...
Cheers Bruce
building:
1/72 RC USS LONG BEACH CGN9
1/72 RC USS CALIFORNIA CGN36
1/72 RC USS SAIPAN LHA2
1/72 RC USS SHARK SSN591
1/72 RC USS SEAWOLF SSN21
1/72 RC USS ALBANY CG10
Russ2146
Post by Russ2146 »
On 1950 fit, Navigation Bridge level (04 Deck) on splinter shield below Mount 47 (40mm Quad) marked as Side Lights P&S.
Or, 3 levels or so directly below ship's bell
commodore4
1/350 NEW JERSEY-converted to U.S.S. WISCONSIN
Post by commodore4 »
I felt I needed to add this here, as there is a problem. If you have the TAMIYA 1/350 model to start with you will see the problem immediately. In the after decking area from the deckhouse there is an odd pattern to the deck . The wood goes around the aft turret in a very weird pattern .This , because the original wood had been removed because of it,s condition. Now , instead of replacing it they followed this weird pattern around the turret.This is totally wrong for the" WHISKEY" That ship has a full wood deck that goes all the way to the helo area and all the way to the sides next to the turret.You cannot use any ship except a TAMIYA kit of the pre-1988 fit to rectify this .DON,T try to use the deck from TRUMPETERS -ALABAMA or NORTH CAROLINA to fix this .the deck in that area is to wide and too short on these models. I just thought I would give you a heads up as the models don,t come cheap (even if you find one )For those of you who want to do , this goodluck. commodore4
Builder 2010
Post by Builder 2010 »
This whole page has been very helpful. I'm just starting on my second Tamiya Missouri attempt after some 26 years. The first (pictures have already been posted) was just before the age of GMM PE. This one's getting the works. I've received my Eduard full set, plus the 16" brass gun barrels. I've also received Life Scale paints for the proper colors, and am waiting for the Scale Decks Iowa Teak Set, and thanks to you guys, just ordered the 40 MM Ammo Racks from Alliance Model Works. I was looking for this last piece that was missing from Eduard, but didn't want to invest in the GMM super set for another $45 just for this one item.
I, like the fellow above, want to model the Mo right after surrender, but before the measure 22 was removed. I want the nice SD teak to show so the holy stoned Mo would be perfect. I have no problem removing those 20 MM tubs on the bow flanks.
My 1980s Mo had the correct hull for the WW II version. The current Tamiya version is actually the late model Big J hull (they must not have the original hull dies left) and has those added bumpers (or whatever they are) on the sides. I have chiseled them off and just put a little filler on the resultant scratches. Tomorrow I'll wet sand that and bring the hull back to luster. I protected the water line markings with masking tape so they wouldn't be damaged when sanding the hull.
Question: what material were the Iowa prop shafts? I found some steel rod that's the exact size of the plastic shafts. If the shafts were bronze like the props, then natural steel wouldn't work, but if they were steel than it could be a nice replacement and stronger than the plastic shafts.
Another question: what do you do with the brass gun barrels to show the polished slide area at the rear of the exposed portion? I wish they were steel so you could mask that area and paint the rest just like the big ones.
Edward Migley
Post by Edward Migley »
Does anyone know if anyone is producing any of the 5" guns that Steve Larsen was providing? The scale is 1/192.
Thanks, edmigley51146@aol.com
