Calling All IJN Kongo-Class Fans
PetrolGator
Re: Calling All IJN Kongo-Class Fans
Post by PetrolGator »
Hey Dan,
The hell are these?
- Chris
1/700 Murdertorpedoboat Ooi
I've not a clue. Some more images, and close-ups of that tower.
crop 1.jpg (55.32 KiB) Viewed 3797 times
crop 2.jpg (46.53 KiB) Viewed 3797 times
Dick J
Post by Dick J »
Somewhere in the back of my mind I seem to recall reading that it was a water tank temporarily installed to allow trials to be conducted with the proper weight and trim. (Perhaps Warship Profile #12? I am not home with my references at the moment.)
That sounds very probable. I found another photo of Kirishima just after completion with the same structure. However, all these structures were soon deleted from these ships.
PetrolGator
This thread is proving to be very informative. Thank you all!
- Chris
Atma
Post by Atma »
Dick J wrote:Somewhere in the back of my mind I seem to recall reading that it was a water tank temporarily installed to allow trials to be conducted with the proper weight and trim. (Perhaps Warship Profile #12? I am not home with my references at the moment.)
Thats correct, its a water tank temporarily installed and used only on for example on IJN Nagato's trail at 1920:
Kajika's new Hiei as-built kit is being displayed at Shizuoka. It appears they will release all four sisters as built. Kongo PE looks good even from this distance.
able
Post by able »
ijnfleetadmiral
Post by ijnfleetadmiral »
That is one interesting camo scheme! Nicely done!
able
Post by able »
Although the speed fire and protection is difficult to improve, but the bright paint can be done immediately
Nicely done camouflage.
Fivi_1241
Post by Fivi_1241 »
Hello guys,
I've just bought a Tetra PE set for my Haruna, and I wonder what were the top decks just under the radar covered with? Was it linoleum, but without brass braces, or something else? Attached picture is a courtesy of Tetra Modelworks and shows which decks are not supplied with either braces or anti-skid pattern.
It should probably be linoleum and wood gratings, for all the 12cm/AA lookout positions.
Haijun watcher
Re: Calling all IJN Kongo class fans
Post by Haijun watcher »
Dan K wrote:Well, it's really a matter of deleting parts, more than anything else. Mostly radar and AA.
This is one of those cases where it may make more sense to buy the '41 kit. It comes with a new main deck that deletes all the extra ammo boxes, splinter shields, and additional equipment that is molded onto a '44 deck. Of course, if you are going to use a wooden deck, then maybe it won't matter as much, since everything should come off anyway. Fujimi did not mold a new hull, so you'll still have to drill out all the covered portholes. HTH.
Hi Dan,
What if one used Tetra's 1/700 1941 Kongo PE set on a Fujimi 1/700 1944 Kongo kit?
Last edited by Haijun watcher on Fri Jun 09, 2017 12:24 am, edited 1 time in total.
I believe it would work, but I don't have either in hand to do a piece by piece comparison to guarantee it 100%.
Hiob
Post by Hiob »
Hi all :)
Here's my Hiei in 1:200 scale, paper model from GPM. Took 3 years to build :smallsmile:
WOW! That's a stunning build. Hard to believe it's from paper. Well done.
Post by ModelMonkey »
Frank381
Post by Frank381 »
Nice Work,but the Flydeck is in Linoleum not dark Grey :thumbs_up_1:
Hiob
Post by Hiob »
Thanks nice words. Frank flydeck is dark brown not dark grey.
