veliko_pile
Post by veliko_pile »
just a question. The inside walls of the bofors gun tube and other inside wall of structural parts were painted deck blue 20B or? I'm talking about the Big Mo in her 32-22D sheme.
Builder 2010
Post by Builder 2010 »
Photos that I'm seeing show decks dark and tubs walls light. So I'm proceding on the assumption that deck blue was for the floors and haze gray for the walls.
Myles
I've used a MS 32 design sheet for a DE I've built and on it it stated that the insides of guntubs/splinter shields should be painted 5-O Ocean Grey.
Russ2146
Post by Russ2146 »
These are probably from her shake down cruise.
veliko_pile
hmm, here I can see that the internal walls are deck blue. hmmm :huh:
Russ2146
Post by Russ2146 »
Wait!!!
That depends on where it was when looked down on. So I'm thinking whatever the pattern indicated
Note the salty sailor working on the 40mm. That tub is not 20b.
http://www.history.navy.mil/photos/imag ... 109729.jpg
veliko_pile
Hi, here I'm again with another question. I see that the Big Mo had the 5'' mount and 40mm bofors marked with numbers.
Here you can the the MOUNT #2
http://www.history.navy.mil/photos/imag ... k04571.jpg
and here the marking done on the 16'' turret referring to the Bofors gun mounted on the main turret
http://www.history.navy.mil/photos/imag ... k04540.jpg
My Q is: was this marking used during all year '44 or ? And someone have or know a diagram how this number works? Let's say for the 5'' Mount #1 is the first from bow portside and the last is #5 and the first from starboard side is #6 and the last #10
Russ2146
Post by Russ2146 »
If you go to the plans of the Wisconsin at http://www.hnsa.org/doc/plans/bb64.pdf
You will find that all of the Mount Numbers for 40mm and 5" actually appear on the plans of the ship.
I have the Vessal Booklet for the Missouri as updated to 1950 as a .pdf file if you need it
veliko_pile
from the blueprints I have for the Missouri, it says that the 40mm bofors in the second main turret from bow is #3 but from the photos is clearly visible that that are #1. Same for the 2 bofors positioned at the bow part, in the blueprints #1 - #2 in the photos visible numbers 17-18 :mad_2:
veliko_pile
:woo_hoo: here's my idea of how it was numbered. I'm 100% sure for the 5'' mounts, as for the 40 Quad bofors the underlined ones are 100% since they are seen in pictures, so that are #1,18,17,15,16,20,12 for the rest I used some logic, even numbers on the portside, odd numbers to strarboard side. Starting of # 1 on the turret going stern on the 1st floor of the superstructure than just adding the numbers to the ones that were missing on the deck floor.
I hope this can be useful to other modelers, now I only need to find someone who can print this decals XD
Builder 2010
I'm attempting to build a super-detailed Missouri, but I am not going to attempt to number all the turrets. That's where I'm drawing my line. It's going to be hard enough to cut those laser-cut decks now that I inadvertantly added one too many levels to the superstructure and now will have to cut and fit the deck pieces.
veliko_pile
well from this point of view, I'm mad .. :big_grin: when I do something I do all the things that are needed to receive a realistic model
ddoyle
Post by ddoyle »
Thought I'd post this here in response to some inquiries -
To all those who helped me with my Iowa-class Battleships On Deck book - Squadron released this book last week (about 10 days early), however I've been traveling and hence won't get my copies until late this week. At that time I will put your complimentary copies in the mail. Please don't think your efforts are unappreciated or that you are being overlooked, it has merely been a matter of logistics.
Thanks again for your help!
Sincerely,
David Doyle
veliko_pile
Hi.
Does anyone have some high resolution of the measure 32/22d of Missouri?
I especially need to see how was the 5'' turret painted, I figured out the portside ones, but numbers 1-3-5-7 on the starboard side are not clear visible.
I have the plans in the Floating Drydock, but the are low res. Thanks!
veliko_pile
I do, but this is for BB61, Iowa, i need for BB63 Big Mo, from my reference pics i see that that are not the same paint sheme
Russ2146
Post by Russ2146 »
These are the design plans for Measure 32 Design 22D as worn by the Missouri
The camouflage Measures/Designs were made up by ship class. You may have heard of the Iowa Class, also known as the BB-61 Class. As it happens ONLY Missouri was painted in this Measure/Design
If you look closely at the Starboard plan, you can just see the 5" mounts.
http://www.history.navy.mil/photos/imag ... 09729c.htm
http://www.history.navy.mil/photos/imag ... 09730c.htm
http://www.history.navy.mil/photos/imag ... 109730.jpg
Note: CB-1 Alaska and Missouri were on sea trials together. So in the color pictures taken on Alaska, you may find views of the Missouri, though I haven't checked them.
Indeed - as a follow up, here are photos for Iowa's own camouflage scheme, pattern 1B. Missouri used pattern 22D, which is the one posted above.
Portside (hard-edged): http://www.navsource.org/archives/01/016138b.jpg
Portside (feather-edged): http://navsource.org/archives/01/061/016138a.jpg and http://www.navsource.org/archives/01/016153.jpg
Starboard side: http://www.navsource.org/archives/01/016151a.jpg
grim reaper
Post by grim reaper »
Iowa wore measure 32a /1B camouflage design. Measure 32, Design 7A was never used.
In war there is no substitute for victory.
USMC-2531 1991-1999
USN ABE2 2013-Present
1/96 Missouri 1944
1/96 Pennsylvania 1941
1/96 Yorktown 1944
1/96 Oscar Austin DDG 79 2013
Ooop! I should've remembered. Edited last post to reflect that.
