God grant me the courage not to give up what I think is right even though I think it is hopeless. ~ Chester W. Nimitz ~
Nice weather is an effectiv show-stopper for modelling, but some progress has been done during the weekend. I have continued to paint vehicles and the CH-53 and MTVRs are close to the dull coat stage. I gave the M1114s a desert coating using Xtracolors Gulf Sand. I also "built" four more AAVs and I think I got about 15 to 20 now... There will not be any more for sure.
I guess the most important step was to get some paint on the hull. I'm not sure about the color of the anti-fouling paint, suspecting it should be more red. I mixed Tamiya Hull Red with Red in a 4:1 ratio and the result is a rather maroon color. I guess I will go for the WEM anti-fouling red for my next project. However. I plan to show my Wasp with quiet a bit of rust and weathering so a brighter red might look awkward then.
Those vehicles sure look great!!
I'm looking forward to getting into mine, but I'm going to stick with OOB.
I call this CH-53 finished. It turned out better than the first one, but she is not perfect. She will be in the hangar for maintenance so I guess I can live with the fact that the no-slip is a bit to short. It was fun converting the little kit, but it will be a while before I try that again...
Are you flipping kidding me!!!
This is utterly fantastic. I knew it was going to look great, but Wow! This is a show piece in itself.
The long, gray boxes you see stacked up on the sides of the hangar bulkheads are for storing blades
That was what I thought. Thank you for confirming it.
Those gray boxes contain RFI blades and are not used for temporary storage of blades during maintance. Blades that are off the A/C due to maintenance would be stored on support equipment. They are waist high metal tripod looking things that have a cradle built into to hold the blade. There are one of these on each end of the blade to suspend them above the deck.
Nice! That will make my maintenance area even more busy. So basically the blades are stored right next to the Heli when they are off?
Erik
If I have the chance I'll try and get a picture of it.
Thank you all for the kind comments. This little model was quiet a challenge, but I think the end result will be worth it. This forum has turned out to be one of the best, and most helpfull, modelling forums I have ever been a member of.
Getting pretty bored of painting vehicles, but I can see the light at the end of the tunnel (unless it is a meeting freight train...) After two hours at the bench I had put the last wash on the MTVRs and AAVs. Most of the time was spent on these little buggers. The Humvees were not easy to paint due to small size. The armored side windows were very difficult since I could not let paint "flow" into the window frame, since there are none... I would guess they still need an hour of paint work.
A Command Post AAV. Antennas are streched sprue.
All mechanized units needs a recovert vehicle.
I like how the MTVRs are turning out. This one and the AAVs still miss a dull coat.
Looking nice! I'm still deciding how I want to populate mine. You can't see with the LCAC in-bay, so I'm thinking of leaving a vehicle visible through the side door and perhaps another one driving down or at the base of the ramp and then having one LCAC and LCU populated with vehicles mounted on the base.
