1/350 RICHELIEU Dakar 1940-41
LE BOSCO
Re: 1/350 RICHELIEU Dakar 1940-41
Post by LE BOSCO »
Christian M. wrote: I suppose it was in French Navy the same situation too... :wave_1:
Hello
thanks Peter and Arizona :wave_1:
Christian ,it is not cognize the French! we are able to do complicated,when have can to do simple :lol_3:
Indeed, I understand what I meant Sirmaumau,The highlighted portion of the photo
correspond indeed to the catapult of dunkerque and others cruisers! For my Richelieu ,I am obliged to modified the solid parts,and put a metal trelli,like on this photo
otherwise, aside from that they are almost identical :-D
cheers
Nicolas
JIM BAUMANN
Post by JIM BAUMANN »
sharp sharp work
in fact its a sharp as your razorblade!!!
JB
LE BOSCO
Post by LE BOSCO »
HI folks
thank you Jim :thumbs_up_1:
I Just finished a 96% the assembly of "module" composed the chimney and the roof of the 380 telepointer (so the project advance;)
place Photo
everything is assembled to white, which may cause an aspect "crooked" of some parts :smallsmile:
and to compare the same "module" in 52
Otherwise, I have received of Arsenal, my guns 380 mm in brass turned and I have re-molded 2 turrets that will be my master for the version 41
Indeed, the turrets will not be equipped with blast bags,and will look like this
that'll force me to detail the mantlets of each barrel
see you soon for further progress
Nicolas
I envy your level of skill. Wonderful work, very inspiring stuff!!
Quincy
Post by Quincy »
Superb!!!! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Bob Pink. :wave_1:
Joe Simon
Post by Joe Simon »
Very nice dude!
sirpaul
Post by sirpaul »
This really is great stuff. Just to know all off the corrections made is a massive amount of research. :thumbs_up_1:
On the Bench
1/350 Independence
1/350 Dunkerque
1/350 Shimakaze
1/350 Sharnhorst Dragon
1/350 Belfast
NWarty
Post by NWarty »
Absolutely beautiful work Nicolas! :thumbs_up_1:
~Blake
Completed:
1:350 Trumpeter CVN-68 Nimitz, "Eagle Claw"
Planned: Nimitz fixes and sprucing up
Plastic Habit
Post by Plastic Habit »
Man, LE BOSCO you do great work. Looks really good. After seeing what you and others have done for their builds makes me feel like retiring my X-acto knife. Maybe I should stop trying to be a third rate model builder and work on becoming a first rate bird watcher. Never mind I like building models to much. Enjoy your build, because I am.
Rob 2
Post by Rob 2 »
Stunning as ever Nicolas.
Rob.
LE BOSCO
Post by LE BOSCO »
thanks a lot :thumbs_up_1:
Today, I attack the "chunk" :smallsmile: I work on the basis of "castle",and for match the 41version ,must immediately make cosmetic surgery .I get out the saw
have "recorks" with the plastic card
and we get a good working basis
as you can see in the picture,all molded details are deleted,because it is false :-D
see you soon
Nicolas
Plastic Habit
Looks like she is coming along beautifully. Cant wait to see what you do next with this section. Im sure it will look great seeing how you do great work. The view is good from my seat.
LE BOSCO
Post by LE BOSCO »
thanks Plastic Habit,but :Oops_1: !apparently the ventilation blocks, was present after the overhaul to the U.S. :doh_1:
I try to be sure at 100% and I modify (again :whistle: )
Nicolas
Chlo� Plattner
Post by Chlo� Plattner »
Hi Nicolas,
I admire every step of your lovely model. There is not much taken originaly from the kit :big_grin:
With best regards Peter
A passion for modeling
Channell
Post by Channell »
Amazing work as always Nicolas... Your work is inspirational to me!
-Jason Channell
FlowerPower
Post by FlowerPower »
magnifique! :worship_1:
WIP:
-1/72 Revell flower class corvette,with GLS PE and lots of Evergreen.
-1/350 Dragon Scharnhorst, Artwox wooden decks, CyberHobby PE, Master brass barrels.
LE BOSCO
Post by LE BOSCO »
HI folks :wave_1:
thanks for your kind comments :thumbs_up_1:
As you have seen, I start work on the castle, with finishes, well; there was something that bothered me. And after reviewing my documentation, I noticed that the "trumpet" was again tripped over the carpet.... In fact the castle is composed of two separate parties, namely on the front a kind of tube which forms the bunker, and the rear, another tube forming the nerve center of ship .these two tubes, in the reality are connected by two bulkheads and that is where "Trumpy" is mistaken
At the blue arrow, the part that I stuck thinking does well: no: and the red part or it must be ....... a small difference that does not see on the 43 version, seen that these areas are hidden by the bathtubs of 40 mm quad
So the result after of the "surgery�
The hatched area, corresponds to the space there was between the two "tubes"
By searching I also found that the two blocks behind the castle was a modernization posed to the U.S. in 43, so I removed
but I made a "plan B" if I ever find a photo that proves me the opposite
another challenge waiting for me, I try to redo the bulwarks ..... the workpiece with the bulwark of origin
and now the same with the base of the new platform
otherwise, small views of the chimney "primed"
it looks better like that, right?
Nicolas
FlowerPower
wow! yes it does!
Evergreen rules huh? :cool_1:
Rob
WIP:
LE BOSCO
Post by LE BOSCO »
HI Rob
thanks
Evergreen for all !!!! :smallsmile:
Nicolas
partis
Post by partis »
That is some wonderful work you are doing on her.....Cheers mark
