Hello all,
Update: 8" Main turrets
This step was pretty much strait forward assembly of kit parts with only some slight modifications...first I had to round over the turret face's which was easily done with a sanding stick. Next I added details like PE ladders and detail pcs under the rangefinders which was made with sheet styrene. lastly I filled the notches in the turret faces with sheet stock and sanded the faces smooth, built a 20mm gun tub for turret #3 and then shot the turrets with a coat of primer.
While the turrets cured I started work on the guns...first I started by drilling out the kit blast bags so the brass 8"/55 guns from B&D barrels would just slip into them at final assembly...the brass turnings are very nice and only needed to be trimmed up a bit to get the correct length. Next I coated the blast bags with two coats of full strength white glue and when dry I gave them one last coat of diluted glue useing a small needle to scribe a texture in to simulate folds in the bags.
When everything fully cured...I painted the parts and finally installed the guns.
The turrets ready for primer.
A kit blastbag drilled out.
One of the glue coated blastbags with a gun dry fitted.
Dave
