No need for that. I�m glad to see there are still people interested in seeing what I�m doing around here...Dave Wooley wrote:...My oppologies for not catching up on your build...
Exactly..that�s the reason. It is intended for static only, so I don�t see the need to add multiple layers of resin and fiber glass. I�, pretty sure that I can get a far better look, using styrene only.Dave Wooley wrote:...I'm intrigued that you have chosen styrene rather than fillers to achive the best results. As a modellers that uses a great deal of styrene I can see the benefits , particularly on a static model...
The hull is now half covered, and I�m very satisfied with the results. I had to quit the use of the "hot-air" gun, though. It helped bending the styrene, but it ended warping some parts, too.
As soon as I�m finished with the hull, I�ll post a picture or two, so that you can see the results for youselves.
