Just saw an amazing home made rivet tool on starship modeller site. This is a MUST for the larger scale modellers (not so appropriate perhaps for 1/350, but just right for 1/72, 1/48, 1/35). Excellent for armour too.
http://www.starshipmodeler.net/cgi-bin/ ... hp?t=43241
fellow named "futch" has turned a nail punch into a flat OR domed rivet tool. beautiful work.
Rivets
- rokket
Rivets
AMP: Accurate Model Parts: http://amp.rokket.biz
"It's about the model" - Fabric Flags, Uboat and Gato Resin and PE
Talk Like HAL day - http://www.talklikehal.com/
Foeth
Thanks for the heads up
When the WEM 1/350 Hood replacement turrets are out, MW will post a small article showing how they are built. This includes a how-to for making large rivets in 1/350. I made them by using very thin Evergreen styrene (0.16mm) and drilling it in from the other side. If you do this carefully, you'll end up with a bumpy rivet. For 1:350, you could do all the heavier rivets
[img]http://www.warshipmodels.com/~users/Foeth\rivets.jpg[/img]
- Devin
Thanks for that link. I visit Starship Modeler every day but somehow missed that one.
That tool will be very helpful when I get around to the 1/96th scale Keokuk kit; she was covered with flush rivets and the kit doesn't seem to have them.
-Devin
-Devin
- Sylvain Auger
A very interesting technique that!!!EJ Foeth wrote:Thanks for the heads up
Thanks for sharing!
Ventis Secundis
- rokket
EJ - very nice work, love the technique, well done
Sylvain - good point - I usually do trickjy things 3 times - 2 bad tries and then success
Devin - checked out the Keokuk site, nice model. You will really intensify the coolness with added rivets!
