How to remove paint runs?
mikeb162015
I am new to the forum and I am currently building the 1:350 model of the yamato. On the dull red I noticed some paint runs on one side in the front and was curious if anyone knows a good way to fix that.
- JIM BAUMANN
Re: How to remove paint runs?
Did you brush paint or spray..? enamel or Acrylic?
anyhow....
I have had small runs ( sags) in the past when I have applied to much paint ... ( impatiently! )
I allowed it to harden fully--and then pared the run( s) flat with a very sharp blade
one time I simply varnished and al was well
teh other time aftre paring I gently sanded locally around the pared runs and surronding area na d gave the entire area a thin light coat of paint to blend it al
good luck
Jim Baumann
I used tamiya spray. Ill try sanding it carefully and see how it goes.
