New Russian Aircraft Carrier Proposal Revealed
- ADebroux
Since the Shtorm (Project 23000E) had a snowball's chance in hell of ever being built, it appears the Russians have scaled back their carrier ambitions to something a bit more reasonable and realistic. The new proposal was recently revealed by the Krylov Research Center here: http://www.navyrecognition.com/index.ph ... esign.html
DougC
Re: New Russian Aircraft Carrier Proposal Revealed
The deck elevators would limit future aircraft development.
- Admiral John Byng
I agree. Based on that model, it looks like a bigger carrier than 40,000 tonnes.
InchHigh
The displacement doesn't match the hull size, and the powerplant doesn't match either. 40,000 tons with 110,000 HP for 28 knots? That's about the same plant as a Burke class DDG. Something's wrong with the numbers here.
DougC
Looks like a great deal of mis-information. Much like the Myoko being a "10,000" ton cruiser.
- PetrOs
- PetrOs Modellbau
Well, powerplant sounds realistic in fact, North Carolina BB had 28knots on same displacement but on a much shorter hull at 121 000 hp. Length is speed so 110000 hp on a long hull for 28knots sounds realistic.
It looks a bit too long for the displacement, but I think technically possible. Petr Velikiy is about 50 meter shorter at about 25000 tons, but it has a much higher armament weight, and in a carrier, more of the displacement can go into the hull.
Admiral Kuznetsov class is actually similar in length but bulkier due to heavy AS armement high up resulting in larger weight, width and draft, also causing a more powerful conventional steam plant installation which is heavier then gas turbines.
Not quite a light carrier however, quite comparable to the new chinese ones. Quite interesting also, which early warning planes are planned. Definitely not A50s
Further kits in preparation.
- Roberto
- Location: Bahamas, on a painful sabbatical from modeling
Also the air wing is not what to expect, the new MiG-29k is going to I completely replace the Flankers.
Victoria Nobis Vita.
- Haijun watcher
From last July: another design...
UK Defence Journal
UK Defence Journal
Russia unveils yet another new aircraft carrier design
By
George Allison
July 12, 2019
Russia has yet again unveiled a new aircraft carrier design.
At an annual Russian defence exhibition, the Krylov State Scientific Center unveiled concept for a new aircraft carrier.
Russia appears to do this every year and as most of you will be aware, the designs never progress further either due to a lack of will or resources on the part of the Russian military.
(...SNIPPED)
- chuck
DougC wrote:Looks like a great deal of mis-information. Much like the Myoko being a "10,000" ton cruiser.
The incentive to understate the displacement is not there. If anything, the Russians would overstate the displacement in order to create the impression of a capability their economy and remaining industrial base can not longer support.
I think there is no real possibility at all of Russia building anything larger than 20,000 tons or so for the foreseeable future. All carrier designs they put out are deception operations to make it look like their weakness is temporary, when in fact there is nothing whatsoever on the horizon that suggest they can change the country's inability to support anything more.
- BB-55
Another prospective alternative to the twin island Shtorm and the catamaran carrier. A more asthetically pleasing design (to me anyway) but I see the Russians still won't/can't get beyond the ski-jump on the bow even with catapults on the angled deck. https://thebarentsobserver.com/en/secur ... ft-carrier
- Haijun watcher
More future Russian carrier designs in the news:
defence blog
defence blog
Nevskoe Design Bureau is crafting new aircraft carrier concepts for Russian Navy
NewsMaritime Security
By Dylan Malyasov
Jan 19, 2021
Modified date: 16 seconds ago
Concept art showing Nevskoe Design Bureau's aircraft carrier proposal.
Nevskoe Design Bureau, a leading planning and design bureau of shipbuilding industry in Russia, is crafting various proposals of new aircraft carriers, including hybrid modular ships, for the Russian Navy.
Russian ocean-going warships maker Nevskoe Design Bureau has revealed what appears to be a modular aircraft carrier concept called the Varan.
The company says that its primary mission would be to create a universal floating airfield for combat aircraft.
(...SNIPPED)
Last edited by Haijun watcher on Mon Mar 01, 2021 5:15 pm, edited 1 time in total.
- Haijun watcher
The future Varan class will reportedly carry the Su57 fighter:
Defence View
Defence View
February 27, 2021 - Latest News, Naval Power, Russia
The new Russian aircraft carrier will carry the Su-57 and Okhotnik
The Russian aircraft carrier Varan is likely to be equipped with the Su-57 stealth fighter and the S-70 Okhotnik attack drone.
The latest development product of JSC �Nevsky Design Bureau� in the form of the universal marine complex �Varan�, is actually a midsize aircraft carrier, can be equipped with the stealth fighter Su-57 Naval version and the S-70 Okhotnik unmanned attack aircraft.
(...SNIPPED)
