I get the impression, from an admittedly cursory glance on t'internet, that these EFP rounds are fairly wide in diameter things. They are, therefore, probably not capable of being shrunk to the size of a rifle bullet.
Werner wrote:These weapons, invented primitively in 1942, have the ability to penetrate any armor up to and beyond 1,000 calibers in thickness.
The EFP is relatively unaffected by first-generation reactive armour and can travel up to perhaps 1000 charge diameters (CDs) before its velocity becomes ineffective at penetrating armour due to aerodynamic drag, or successfully hitting the target becomes a problem.
This means that an evolved 5" shell should be able to penetrate up to 416 feet of standard armor.
I suspect, Werner, that you have misread your source quote; I don't think it says that these EFPs can penetrate 1,000 times their diameter in armour thickness, but that the jet of molten metal created by the explosion of the EFP can
travel through air for a distance of up to 1,000 times the round's diameter before atmospheric drag slows it so much as to lose its penetrative effectiveness, or it merely misses the target. You have, I suspect, confused
effective standoff distance with
penetrative capability. Therefore, to use your example of a 5" EFP round, the shell could explode up to 416 feet away from the armoured target and still stand a chance of penetrating it.
On Military.com, we find this table (
http://www.military.com/soldiertech/0,1 ... P,,00.html):
XM303 Kit [a type of standoff demolition charge]
EFP Type...........Standoff...........Target
Small................1ft.-50m...........>1 in.RHA*
Medium.............2ft.-50m...........>2 in. RHA*
Large................10ft.-50ft..........8"-24" Concrete
*Rolled Homogeneous Armour: a sort of baseline standard for armour
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." Seneca, 1st century AD
