A source of thin brass wire
Foeth
Try looking for transformers and winding wire. I found some wire from Avisor, from 0.1mm and up in steps of 0.1mm. This wire is lacquered, I have yet to find out its soldering characteristics. I bought a few reels 0.1, 0.2, and 0.3mm (I use styrene from 0.3mm up). The 0.1mm reel is supposed to have over 700m. Should be enough!
Foeth
I found them at some company called Okaphone.
http://www.okaphone.com/search.asp?bran ... d=0&deep=1
Rigging? Hmm, sounds fragile!
Akula
Source for wire
Hello- I have found the wire within the security cards used at business's to allow access to the rooms inside the building has .004" wire used in the coil. I have several of these dead cards that have gracefully gave up the wire for my models.
HTH
Bob
HTH
Bob
Foeth
You can find lots of thin wire in electric motors or transformers, or simple coils. But, this is a source of consistent thickness and you don't have to demolish old electronic gear. And you now have first-grade fully-deoxygenated cupper
Now I have to find a source of bending tools... I managed to go without brass wire up to now.
Re: Source for wire
What do these cards look like? Surely not the run-of-the-mill magnetic striped cards?Akula wrote:Hello- I have found the wire within the security cards used at business's to allow access to the rooms inside the building has .004" wire used in the coil. I have several of these dead cards that have gracefully gave up the wire for my models.
HTH
Bob
- Sean Hert
Akula
Key card wire
They look like a credit card but thinker. They have a slot cut in 1 end to hang from a snap clip. There are 2 faces laminated together. The small spool of wire is on the inside. I have peeled apart several old cards and removed the wire. It is NOT the Detail Associates .006 brass ROD wire. This stuff is so fine you can hardley see it. But, in 1/700 scale it works out to 2.8 inches, 1/350th is 1.4", 1/200th is .8", 1/72 is .28", etc.
HTH
HTH
- Laurence Batchelor
- David Griffith
- Location: Waiting for HMS Glatton in resin. Not holding my breath!!
If you strip down co-axial TV aerial cable or high power speaker cable you will find this is a source of copper wire that is approx 0.2mm diameter. I think this is too thick for much rigging, but is very useful for other things nonetheless.
But I'm going to order some of that stuff from Holland.
David Griffith
David Griffith
"For scientific leadership, give me Scott. For swift and efficient travel give me Amundsen. But when you are in a hopeless situation, when you are seeing no way out, get down on your knees and pray for Shackleton."
mike mccabe
- Starling Models
David
Have a look at http://www.little-cars.co.uk, also I believe they will be at Telford. They do 0.1mm wire.
Mike
Mike
Some of my fellow Brits may find this site useful
http://www.wires.co.uk
Copper wire down to 0.05mm
Mart
Mart
