How to build fairleads at scale 1/100
Laurent
Post by Laurent »
Hi All ,
here the way I've built the fairleads for my "Zinnia" .
some pictures to begin with :
hereby some explanations .
First of all , I bought a plastic tube ( polystyrol or ABS ) , the diameter being 4/5 mm . I cut a slice being 3 mm thick ( drawing n�1 ) , opened the slice and formed the fairleads with a tweezer , see drawing n�2 :
I built then the fairlead base , from paper ( drawing n�3 & n�4 ):
this base was then drilled with four holes , see drawing under ( n� 5 ) , I then have fit the fairlead there in between and glued the whole with CA glue ( drawing N�6 ) :
the whole assembly was then coated with CA glue , to give strength
what you get can be seen on drawing n�7 , but it still has to be put in shape , like the drawing n�8 .
A little sanding did the job ...
here under the dimensions for the biggest fairleads I have on "Zinnia" :
Regards ,
Laurent
Andy G
Post by Andy G »
Stunning - I'm storing these ideas up with interest, Laurent! Might need a blob o' Milliput on mine, though!
Andy
Jimmy Conway
Post by Jimmy Conway »
Laurent, very nice detailing. The success of parts are the success of all the ship and Zinnia goes very good................. congratulations!!! :thumbs_up_1:
Regards: Jimmy
rokket
Re: How to build fairleads at scale 1/100
Post by rokket »
nice idea, excellent execution! Remembering this one...thanks!
AMP: Accurate Model Parts: http://amp.rokket.biz
"It's about the model" - Fabric Flags, Uboat and Gato Resin and PE
Talk Like HAL day - http://www.talklikehal.com/
