I�m looking for a way to reduce the low-speed setting on my Dremel to something in the order of hundreds of RPM so that I can use it to work on styrene. The current low-speed stop is 5,000 RPM, which is enough to vaporize the soft plastic that I�d be trying to drill/sand/engrave.
After looking around, I found that Micromark sells a variable-speed foot switch (see link), although I think I would prefer a rheostat knob-type speed adjustment.
Do y�all know if this foot pedal would work on a 115v Dremel? Alternately, do you have any experience with an effective way of slowing down a motor tool?
Micromark variable speed foot-operated rheostat
