Drilling Scuttle Holes
monkey
Post by monkey »
After much research (without actually buying any books :smallsmile: ), I decided to build the kako as furutaka since all the components have to be scratch built.
The hull has terrible molded scuttles and I plan on filling them with putty. Can anyone tell me which way is the best for drilling new ones? Thanks for all your help thus far. :thumbs_up_1:
Victorious
Post by Victorious »
The best way is to drill a pilot hole, just large enough to get a small round needle file in there, then just open the hole out with the file, intil you get a nice tight fit for the scuttle. Depending on what scale you are talking about. If it's one of these 1/700 models, then forget the file method. Just use a fine micro drill
Victorious
All micro drills are measured in thousands of an inch. You will just have to search harder. You need a hobby shop that supplies micro tools.
They are expensive if you compare them to ordinary drills and they are very delicate.
Devin
Post by Devin »
I usually check Micro-Mark for such tools.
I think this drill set might be what you need. Add a pin vise and you're ready to go.
-Devin
Tom Naylor
Post by Tom Naylor »
An inexpensive set of reamers may help too. I use welding tip cleaners, which come in a variety of tiny wire sizes. Great for cleaning up a drilling operation.
Tim
Working smarter, not harder
Post by Tim »
Hi guys,
I got a friend from my model club to machine a knife handle down so that it will fit in the chuck of a cordelss screwdriver. Better control that 5000 rpm, and we'll see how difficult it is at @600 rom to do all the scuttles on a 1/600 Repulse.
Tim
