Actually yes. It's been designed specially for this project. I use my friend's printing service. I don't know what they use but it looks very accurate for me. I can reach the 0.05mm level of details...Aop Aur wrote:! ...Did you print those 3D parts yourself? ... And did you design the parts as well?
USS Washington, Guadalcanal 1942 [Trumpeter]
- blacman
Re: USS Washington, Guadalcanal 1942 [Trumpeter]
Thank you for comments...
- Rob-UK
The is a very fine level of detail for 1:700 scale, quite amazing.
- Brett M
Very nice work you've done. Those searchlights.....wow. That's some detail on something so small!
Brett Matthews
- Cliffy B
I hope this build ends up in a museum when you're done with it man because that's where it'll belong. DARN FINE JOB!!!!
wing_nut
That's impressive PE work. I was getting a little dizzy looking thinking about it as I looked.
- J. Soca
Good to see you back on the saddle !!
love the hull plating
Jose
Jose
- Aop Aur
Could you ask your friend what printer he is using? Those parts are the best 3D print part I've seen! Is he doing the service for friends, or other customers too? Maybe I could get access to his service as well when I need fine parts?blacman wrote:Thank you for comments...
Aop
On the way:
And our artworks!
And our artworks!
- blacman
hello !
let's make cranes ...
Crane for seaplanes:
truss partially equipped:
based of crane:
in progress...
and ready:
midship cranes:
Base with removed "details" form Trumpeter. Those ones have been replaced by 3D printed. Upper level done of paper strengthen by CA glue
It was worth to rebuild
and complete set of cranes for USS Washington ready:
still some small details will be added like railings, handles then cleaning and ready to be painted! .....
based of crane:
in progress...
and ready:
midship cranes:
Joe Simon
Great work as usual!
Thom
That is an impressive amount of work, especially in /700! Keep it coming!
- blacman
I've been working a bit on middle and big guns
127mm units ready to paint:
barrels 406mm after first "shadowing",
got grey and then in masking device got blue....
127mm units painted without any masking - just positioning to aero.
406mm turrets ready to receive barrels...:
preparation for setting 127mm barrels from Master.
I cut 1mm plastic bar into slices with thikcness of 0.4mm
then I will drill them and insert barrels....
aeroplanes crane painted also without masking:
and catapults in progress:
and twins are ready to be painted
- taskforce48
If you were to make a 1/350 set like this, I would be your first customer!
In the yards right now:
USS Utah AG-16
On Hold
1/350 USS Portland CA-33 1942
USS Utah AG-16
On Hold
Truly beautiful work, Greg.
Joe Simon
I second that! Awesome work!
- blacman
thank you mates...
I corrected camo on 127mm units:
and main turrets ready:
Midship cranes ready-
and here I have small doubt. Should the top of crane's lattice be painted on deck blue (as horizontal surface) or should stay grey...?
admiral level and signal level ready
preliminary assembling of navigation and pilot levels...:
catapult ready to get deck blue on top...:
- Strategos Augustus
Exquisite.
- Goodwood
Really nice progress you've got going there, Greg!
As for the crane, in all likelihood the entire thing was painted gray, since there's no real vertical covering, it's all just girders and framework.
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
On the ways:
In the stash:
- blacman
thank you !!Goodwood wrote:As for the crane, in all likelihood the entire thing was painted gray, since there's no real vertical covering, it's all just girders and framework.
- LE BOSCO
HI Greg
as always a great job
I would say a true professional work
well done
cheers
Nicolas
well done
cheers
Nicolas
- zs180
Mind-blowing, amazing job.
I think all these detail parts will sell well if you make them available through Shelf Oddity.
George P�k
George P�k
