Since Kirishima is completed it's a high time to start on USS Washington...
base is Trumpeter kit:
initially I intended to use Lionroar kit but in order to keep accuracy and easy assembling I decided to create my own PE set from scratch.
range of detailing will include new 406mm & 127mm turrets, new deck, all superstructures walls and many others fittings...
drawings started:
and first samples fit quite good
the PE project will be designed parallel with USS North Carolina
[/url]
[/url]
