*Resin* A list of Upcoming Ship Kit Releases
maxim
Re: *Resin* A list of Upcoming Ship Kit Releases
Announcement by Doggy Industries in 1/700:
Italian supply ship Vulcano
https://www.facebook.com/photo/?fbid=524806370061762&set=pcb.524808360061563
- Hen
This "Zao" is not the B-65 design (the "Mini-Yamato" type, Alaska-counterpart) but another "Super heavy cruiser" - the 4x3x203mm main guns, 6x2x100mm heavy AA and aircraft handling area at the stern are correct in that regard. I have to look up the proposed name, but this ship design is surely included in the Japanese book "Uncompleted fleet plan 1917-1950" (Military Illustraded, anno 2000). Supposedly planned in the Maru 6 building programm to counter the Baltimore class. Aircraft handling and torpedoes are placed aft to minimize explosion risks.Dan K wrote:Some complaints about the design were the americanized way the catapults and crane are foreseen.
Agreed about it resembling the Chuanya/3D WILD 1/350 kit. And, it certainly doesn't look like the original project 65 design.
EDIT: Google Translator says they are the "Unzen" class - named after volcanoes/mountains; "Zao" is indeed one of them, the others are "Rokko" and "Kurama". But those names seem to be fictional.
- - - - Check out my 1/700 Imperial Japanese Navy blog at http://nihonkaigun.wordpress.com/ - - - -
Felix B.
New from Iron Shipwrights, USS Croaker SSK-246, Gato class hunter-killer sub and a Soviet Project 611 Zulu class sub. Both are this month�s special:
http://ironshipwrights.com/ship_specials.html
Felix B.
Felix B.
- PaulC
New from Triumph Model, Oct 20 release at Hobby Easy:
HMS Lion 1/700 - Resin, 3D print & PE. waterline and full hull!!
And what a price!! Unbelievable! Did they leave off a number?
https://www.hobbyeasy.com/en/data/f4w7d ... whwvn.html waterline
https://www.hobbyeasy.com/en/data/z7c2k ... yxw9c.html full hull
Hard a starboard.......Shoot!
- pascalemod
will find out.. very curious with this new breed of ships. Im sure it is not very accurate or whatever and details are exaggerated or smth.PaulC wrote:New from Triumph Model, Oct 20 release at Hobby Easy:
And what a price!! Unbelievable! Did they leave off a number?![]()
- PaulC
- PaulC
- pascalemod
Oversized hull plating and portholes aside, looks nice. those are not hard to shave down a bit - smooth out. I wish they stop it with the rediculous hull plating, it was fun to add them in thin paint build up layers, but this is crazy what they produce. It even makes people replicate them today on Youtube, which is double bad.
maxim
Announcements by Starling Models (partly replacement of older Atlantic Models or Starling Models kits):
1/350:
British minesweeper HMS Brave (Algerine class)
British frigate HMS Nadder (River class)
British sloop HMS Wellington (Grimsby class)
1/700:
British destroyer HMS Scorpion (S class)
British destroyer HMS Venus (V class)
British destroyer HMS Tuscan (T class)
British destroyer HMS Undaunted (U class)
British sloop HMS Grimsby (Grimsby class)
British sloop HMS Yarra (Grimsby class)
British sloop HMS Leith (Grimsby class)
1/350:
1/700:
- Rob
This kit is now out. I received my copy today and I'm very pleased with itmaxim wrote:Announcement by Delphis Models in 1/700:
Italian assault carrier MMI Trieste (L9890)
https://www.delphismodels.it/prodotto/m-m-i-trieste-l9890/
maxim
Announcement by Seals Models in 1/700:
Japanese aviso/torpedo cruiser Tatsuta
https://www.hlj.com/1-700-scale-equipment-parts-for-ijn-rn-vessels-ijn-dispatch-boat-tatsuta-intsml-029
palco
- AJM Models
Hms Amastra and Macoma coming soon from AJMMODELS POLAND
Pieter
...which as MAC ships never operated under the prefix 'HMS'.
- pascalemod
I got the kit in full hull in my hands. the lower hull has quite the attachment point... A lot of work to remove. Probably not an issue on the WL model. I measured it - and the ship checks out to correct measurements (it looks narrower but if you factor in the small increase in width over the deck on the hull itself, the beam is correct). This is a relief.PaulC wrote:
The stern is ever so slightly bends to the side which is annoying but probably in hot water can be corrected. I dont think it is a fix for a novice but with work can be sorted out. I think this is an issue you have to check yourself.
The downside are the hull panels, I really wish they stop. All of them 1/700 makers please stop making hull plates. This is so out of scale, and usuall can be done with paint layer build up or even just some pencil marks. It means I have to remove these which will be a hassle. So please, STOP HULL PANELS!
The kit otherwise is cool and I cant wait to build it as I have both - 1/700 Haruna battlecruiser and Derrflinger. Should be a cool trio!
- pascalemod
Triumph model now has Prince Royal, Lion class also out as full hull in two configurations and in FH or WL versions. Price again seems pretty decent on ecomm platforms.
mikasa
These are very tempting. Thanks for calling to our attention.pascalemod wrote:Triumph model now has Prince Royal, Lion class also out as full hull in two configurations and in FH or WL versions. Price again seems pretty decent on ecomm platforms.
- pascalemod
My kit had small issues. So YMMW - the price is very good, so assume you may need to watch for any issues. I did measure Lion, looks correct. Im unsure if stern is a little off, the plating is over exaggerated on the hull, but the rest looks pretty sweet. Lets see how it will build out.mikasa wrote:These are very tempting. Thanks for calling to our attention.pascalemod wrote:Triumph model now has Prince Royal, Lion class also out as full hull in two configurations and in FH or WL versions. Price again seems pretty decent on ecomm platforms.
- PaulC
It is with the waterline as well. Right along the centre line from stem to stern. Will be a chore to remove too. Then of course there's the slight banana effect. And oh yes, the hull plating....looks almost as bad as on the photos of the Ostrich Glorious.pascalemod wrote: I got the kit in full hull in my hands. the lower hull has quite the attachment point... A lot of work to remove. Probably not an issue on the WL model.
So...cast resin hull, 3D printed superstructure & small fittings, 2 PE frets and brass rods. Still a really nice kit for the price...for me anyway.
maxim
Planed USN guided missile destroyer DDG(X)
https://www.facebook.com/photo?fbid=610059961536402&set=pcb.610061274869604
https://www.ebay.com/itm/205200991129
MatthewB
I use paper, Tissue Paper (the kind used as Wrapping paper, that is polished, and not like Kleenex), which is almost perfectly in scale.pascalemod wrote:I got the kit in full hull in my hands. the lower hull has quite the attachment point... A lot of work to remove. Probably not an issue on the WL model. I measured it - and the ship checks out to correct measurements (it looks narrower but if you factor in the small increase in width over the deck on the hull itself, the beam is correct). This is a relief.PaulC wrote:
And yes� You can just mask-off the hull lines for Hull-Plating to get the same effect.
I have thought that PE could be used for Hull Plating in 1/700 IFF you make an inset part of the hull in which the panels would be glued, recessed to give the accurate line of Straking.
Pit-Road/Flyhawk did OK with their Kager?, with the hull plating, but the more recent IJN Y?bari went overboard with it.
MB
But some is just outlandish.
MB
OMG LOOK! A signature
Working on:
1/700 (All Fall 1942):
HIJMS Nagara
HIJMS Aoba & Kinugasa
USS San Francisco
USS Helena
USS St. Louis
USS Laffey & Farenholt
HIJMS Sub-Chasers No. 4 - 7
HIJMS Sub-Chasers No. 13 - 16
Working on:
HIJMS Nagara
USS San Francisco
USS Helena
USS St. Louis
