WIP: Gallery 1/350 USS Iwo Jima LHD-7
sgtryan13
Re: WIP: Gallery 1/350 USS Iwo Jima LHD-7
Post by sgtryan13 »
Agreed Martin, looking real good! I am chomping at the bitt to start on one of these, though now I am dreading masking and painting a lot of those flight deck markings after hearing about and seeing how delicate they are.
Devin
Post by Devin »
Keep on chugging along! Looking good.
Jon
Post by Jon »
Hi Martin
Did I read that you used Solvaset to move the decal into place? It might be best to just keep the decal wet with water only to position the decal. Then I use a tissue or cloth to dry the decal down into its position. Then use Solvaset on the decal once it is 100% in it's final place and most of the water has been removed. It will actually melt the decal into the paint so moving after Solvaset has been added can cause problems as the decal has become very fragile. For me, best results come when I a brush Solvaset onto the decal with very small amounts (sometimes wiping off excess) with several applications. If you put too much Solvaset on, you could cause the decal to float up on top of the Solvaset causing problems to get it to settle. Even done applications of Solvaset the day after its dried when I found some silvering.
Another problem could be the decal paper. I've seen sometimes it comes off very quickly and other times you have to soak it for several minutes.
http://www.f-16.net
http://www.c-130.net
Building:
1/48 Lancaster (HK)
1/350 Akagi
1/350 IJN Kongo
Jon,
Thanks for that. Decals have never been a strong point (one of the reasons I don't build many aircraft).
I will try with water - I was using "the blue stuff" at first, until I got the decal set, then "the red stuff" to snug it down.
These decals come RIGHT off the paper - you don't need to soak them for more than 5-10 seconds.
Appreciate the tip - I could certainly use the help!
Jon
Post by Jon »
Its hard to judge how long you are leaving a decal soak for, but I generally soak a decal for at minumum 30 seconds. And I make sure the decal slides off bit by bit down the length before making the full transfer. Otherwise with long thin decals they can tear. It sometimes takes a while for the film to release the entire decal from the paper, even though the paper is quite wet.
Decals are my favorite part of building, it's what I miss the most getting into ship building when I got away from aircraft.
Another option if you have flimsy decals is to spay on another layer of decal film. I've not done that but heard it works. Problem is it turns the decal sheet into one big decal, each would need to be cut out tight to the edge.
http://www.f-16.net
Building:
1/48 Lancaster (HK)
1/350 Akagi
1/350 IJN Kongo
Devin
Post by Devin »
Jon has a good point about the decal film possibly being too thin. I hadn't considered that. You might want to try some Micro Liquid Decal Film:
http://www.microscale.com/Merchant2/mer ... t_Count=11
I've used it in the past when making my own decals, and it works great. Brush it on and it'll dry usually with no brush marks at all. Might be worth a shot.
I treat each decal sheet as an experiment... I've seen some that would leave the decal floating if left in the water for more than 20 seconds. So I play with a small one first and see how long it takes to move it (pressing gently with a finger) and counting off. Once I feel it start to slide, that's my time period for how long to leave it in the water.
Jon
Post by Jon »
Tracy White wrote:I treat each decal sheet as an experiment... I've seen some that would leave the decal floating if left in the water for more than 20 seconds. So I play with a small one first and see how long it takes to move it (pressing gently with a finger) and counting off. Once I feel it start to slide, that's my time period for how long to leave it in the water.
Tracy, well worded, treat each sheet like an experiment. That's so true. I usually also do the smallest most hiden decal first. Sometimes if you are really not sure, cut out the branding or a decal you're not going to use to test with first.
http://www.f-16.net
Building:
1/48 Lancaster (HK)
1/350 Akagi
1/350 IJN Kongo
Thanks guys. Appreciate the input. One of the reasons this site is the best.
gtbred
Post by gtbred »
nice flattop Martin! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Christian Bruer
Post by Christian Bruer »
Hi Martin,
I missed that before. Very nice modelmaking on your Iwo Jima and an easy to follow WIP :thumbs_up_1:
Christian
AKA "Painter"
VMF'06 - German Gamblers
For the most part, the PE on the island is now done (took me long enough!). I still may dig around the spares box for 2 bar railing for the platform on the face of the bridge, as I said earlier, I think the 3 bar railing will be too heavy looking.
Maahhhhhhhvelous, dahlink!
Devin
Post by Devin »
Coming right along. Looks great.
jeroen zuiderduin
Post by jeroen zuiderduin »
Very nice, Martin. I am looking forward to the aircraft now!
Jeroen
Beautiful.
jeroen zuiderduin wrote:Very nice, Martin. I am looking forward to the aircraft now!
Jeroen
Thanks guys. Jeroen - those should be painted soon, depending on my ability to fire up the airbrush. I cleaned them up the other night, and puttied and sanded larger seams in the Ospreys.
After my last update, I realized I was NOT done with the island...some of the platforms on the main mast were not railed yet. That problem has now been rectified.
NOW the island is done.
I've started railing the platforms on the port side, working bow to stern. I've gotten about 1/2 way down that side.
While attaching the railings, I noticed the parts that hold the life raft canisters have a small lip that protrudes onto the catwalk where the parts join. This meant the photo-etch railings won't sit flush to the edge of the catwalk. I remedied that by making small cuts in the lowest rail/waterway of the PE railing, so it will fit better.
JIM BAUMANN
Post by JIM BAUMANN »
its a big 'ol lump...!
But you are at the happy stage where there is light at the end of the tunnel!
JIM B :wave_1:
The port side platforms and the aft platforms are done! Working my way up the starboard side from aft to bow...if I didn't run out of steam last night, I might have gotten the whole thing done. Maybe this weekend. Here are some photos, before I run off to my monthly IPMS club meeting tonight.
Return to “Completed Models”
