WIP: Gallery 1/350 USS Iwo Jima LHD-7
Ok, so now that the in-box review is posted, here we go. This build is going to be strictly out of the box, following the instructions with no variations, except for maybe the color call out for the hull color, which calls for the Model Master equivalent of Ghost Gray. Keith Bender recommends Testors Neutral Gray, but I have some tins of WEM Modern Haze Gray, so I decided to start with that. These photos are actually from earlier this week, this is the first chance I've had to post them.
For the most part, I intend to follow the steps in order, but I made one variation right from the start: I jumped ahead and added the bulbous bow - which is cast separately - and the bilge keels. The parts went on with no difficulty, though there was a little bit of flash on the two part bulbous bow parts, and the fit wasn't perfect...but that's what Bondo is for.
Re: WIP: Gallery 1/350 USS Iwo Jima LHD-7
I spent an afternoon of pre-painting parts with the airbrush and gave them a day to dry. Once they were, and while the bondo on the bow dried, I got started on the well deck. The parts are nicely detailed...shame that, unless you light the hangar, you won't see much detail.
Well deck parts dry fit in the hull
You won't be able to see much of the nice detail that is included in the well deck, especially the back "upper" well deck, which is higher up than the section nearest the gate.
The rubber bands were there to hold the hull walls tight to the decks while I checked the fit.
The lower well deck bulkheads painted
Next step is to gloss coat the lower well deck deck and bulkheads so I can decal them accordingly. Once that's done, I'll add the railing to the platforms that run along the top of the bulkheads, then install said bulkheads to the deck. Hopefully all that will happen this long holiday weekend!
I also sanded off the bow, primed it and then went back over it again with some more bondo, and repeated the sand and prime cycle. This photo was taken before another shot of primer.
Gordon Bjorklund
Post by Gordon Bjorklund »
This build is off to a great start. While I'll probably never buy this kit, it will be good to follow along as you work on it.
Gordon
Nice to see.. must... resist... LHD-1 .... kit.....
Thanks Gordon!
Tracy White wrote:Nice to see.. must... resist... LHD-1 .... kit.....
You know you want it. Don't resist! :big_grin:
I just got one of the Academy Warspites for review, plus I have a 1/400 Mirage USS Ward I need to finish by November 3, so I think the threat of all those coming due will keep me in line. :big_grin:
Added the decals to the well deck:
Well deck dry fit.  The port side bulkhead is not glued in yet - that will happen after the photo etch railings are added.
Hangar deck dry fit only
The decals are very think and a bit translucent - especially the white. Once they are on, they were very hard to move, especially on rough surfaces. I managed to mangle one of the draft marking decals along the way as well.
I was thinking that it was all me, and not the decals, but while the well deck was drying, I decaled this (including the black diamonds on the cowl) with no worries, so maybe the kit decals are just a little too thin.
I also got the hangar bulkheads ready for additional painting, which will be my next step.
Coming together! I got a bad case of the burnouts today, so hopefully this will help get through it!
Devin
Post by Devin »
Looking good, Martin. You bringing her to the meeting on Friday?
Devin wrote:You bringing her to the meeting on Friday?
Yes, she will be there.
Very nice work but, jeez, what happened to no starting new builds until the old ones were done? So much for self control.
Dan K wrote:what happened to no starting new builds until the old ones were done? So much for self control.
Well, I was asked if I knew anyone who could build this pre-release for MRC. I said, "Yeah, I'll do it". So there you go. Oh, and I have to have it finished by JerseyCon in October.
Added the railings to some of the platforms & catwalks in the well deck. To make sure I didn't run out of the PE railings supplied in the kit, I used left over GMM railings from the 1/350 Lexington set. Man...have I gotten some mileage out of the extras in that set! Of course, I neglected to take photos.
Next step was going through the instructions and looking for all the "remove" and "repair" notations. I realized while doing that that "repair" meant just that (I had misconstrued what it meant in my review, which I'll go back and correct). Anyway, after removing some molded on doors, fire hoses and other bits from the hull, it dawned on me that "repair" meant to fill in spots on the hull where openings applicable to the Wasp would be filled and eliminated for Iwo Jima (remember, they share a common hull). :doh_1: So, I went ahead and did that.
I also drilled holes in the bottom of the hull for the lamp finials the hull will be mounted on.
Since I took these photos earlier this evening, the bondo has been sanded, and the hull is ready for the next step, which is painting. However, two things are playing havoc with my painting plans:
1) The rain in the the Northeastern US (going to last until Friday) and
2) I ran out of WEM Modern Hazy gray. I have an order into WEM, but I don't know if that is one of the colors they are out of stock on. If they are, or if the paint order doesn't show up by the end of the week, I'm going to switch to Model Master Neutral gray, and go from there.
sgtryan13
Post by sgtryan13 »
Looking good, I can't wait to check this out if I make it to JerseyCon! I use the MM Neutral Grey for all of my modern USN builds, you can't go wrong with that color in my opinion.
Well, I guess it's hard to turn down an offer like that. I just think of poor Bismarck, sitting on a shelf, waiting, so close............
Nice work on IJ so far. I look forward to seeing it in person. Maybe a preview at NHARA?
sgtryan13 wrote:Looking good, I can't wait to check this out if I make it to JerseyCon! I use the MM Neutral Grey for all of my modern USN builds, you can't go wrong with that color in my opinion.
You'd BETTER make it to JC! If not, we'll be out looking for you! :heh:
Weather broke today - blue skies and sunshine over the Hudson River right now. I may have to switch if the WEM order isn't in today's mail.
Dan K wrote:Well, I guess it's hard to turn down an offer like that. I just think of poor Bismarck, sitting on a shelf, waiting, so close............
LOL. I may work on Bismarck in a few minutes...she is here at my office. My lunch time fling, as it were....
Yes, she'll be there on the 17th.
Short update, sans photos. Been busy the past week, between work, home, etc., so not much time to build, other than some airbrushing.
My WEM paint order arrived during the lull, so I am going to stick with those paints for the overall hull color. I their absence, I airbrushed a lot of the horizontal surfaces Testors Gunship Gray. I also have the hangar bulkheads painted (just waiting for them to dry) and tonight I airbrushed the hull it's first coat of Modern Haze Grey. Other than a little pebbling at the bow, it came out pretty good.
Pictures to come when I have some concrete progress to show....
LE BOSCO
Post by LE BOSCO »
hello
you made a really beautiful work of update ??Martin !good mastery of the subject!!
your model promises to be superb!
best regards
Nicolas
Nicolas,
Coming from you, that is high praise indeed. Thanks.
So I did some more painting and started assembling the hangar deck. Goes together fairly easily with no fit problems after cleaning up a wee bit of flash.
Partially assembled hangar deck
Still needs a little touch up of the paint
The hangar deck next to the hull with the well deck dry fit inside
Well deck, hangar deck and flight deck dry fit together
Looking into the well deck with the hangar deck dry fit above
As mentioned, I also started painting the hull. The head in the background belongs to Devin Poore, and is not part of the kit. :heh:
The photos were taken at a gathering of ship modelers in Central NJ this past weekend. In the foreground is a bunch of different models in different scales from 1/1200 to 1/700 to a scratchbuilt launch for USS Arizona in 1/48 scale.
Have a few more hangar parts that need to be painted (airbrushed) white, then installed. Also plan on giving the hull another coat of paint. When that is done, I'll mask off the upper portion and begin painting the lower hull and boot stripe. Once the hull is completely painted, I can permanently install the well deck and hangar decks.
I have to say, I am really enjoying this kit. Been a fun build so far.
MartinJQuinn wrote:I have to say, I am really enjoying this kit. Been a fun build so far.
Really, who could ask for anything more?
Hangar deck is just about done. Need to finish painting the hull so I can mount the well deck and hangar decks permanently in the hull. To that end, I started getting the hull ready for further painting...
Upper hull masked
Upper hull masked
Struts and shafts in place.   Need to do a little cleanup around where it blends into the hull
I jumped ahead in the instructions to add the struts & shafts now, since I want to finish painting the hull. Let's hope the weather cooperates and gives me a window for painting. It's been raining more often then not here on the East Coast the last week, supposed to do the same this coming week too.
Return to “Completed Models”
