Finished the touch up work and started on the rigging. Did a little Tuesday night and a little Thursday night, with a Beach Boys concert on Wednesday precluding any building time. Hoping tonight to trim the lines on the port side and attach the lines on the starboard side. Then I need to look at photos for the aft mast. The rigging will definitely be "minimalist" for this build.
WIP: Gallery 1/350 USS Iwo Jima LHD-7
Re: WIP: Gallery 1/350 USS Iwo Jima LHD-7
Thank you Nicolas. High praise, coming from you.
- Devin
Looks good. What are you using for rigging?
Nylon quilting thread from Michaels, which came in "smoke" color.
Here is some more progress from tonight. I spent a good 45 minutes to an hour going through the Navy News stand website to find photos of the rigging. Finally found one or two good photos. Then I found detail shots of the top of the island that showed some additional railing that is not called out in the instructions...but i think I'm going to leave well enough alone.
After doing the work shown in the photos, I noticed the three lines going to the aft mast on the port side were pulling said mast forward, so I popped them off. That's a trap I continually fall into - tightening my rigging too tight. Gotta remember to stop that.
I will try and reattach later today (already Saturday here on the East Coast) or tomorrow, with a little less tension. I will also try to stop knocking into the freaking model and breaking sh*t off while I rig.
I see the flag is sometimes flown from the foremast and sometimes from the mainmast. Anyone know which is more prevalent?
- LE BOSCO
Hello Martin
all you have succeeded brilliantly on your aerials and rigging ,waiting for me on my Richelieu
I hope to achieve the same result that you
regards
Nicolas
regards
Nicolas
Finished the rigging today. Decided to put the flag on the foremast. From looking at photos, the rigging doesn't look too extensive. I added a line from the back of the mainmast down to the aft part of the superstructure, to try and keep it as upright as possible and counter the tension from the rigging that runs forward. Some photos:
I didn't have any modern US flags, the flag is a 48 star WW2 version from the YMW CV-2 decal set. Hope nobody counts the stars!
The ships itself is done, minus dullcoating, which I'll hopefully begin this week.
Not that the rigging is done and Iwo is ready for flat, its time to get back to the deck vehicles, Marine vehicles and aircraft.
ilovecarriers
Hi Martin could you let me know what colours you used on your LHD as the colours that Revell say to use look to be different to what you have used ie they say to use africa brown on part no f 21 and f4 of the well deck bulk head but you have used a dark grey or similar also the well deck deck they say paint the rear deck german grey but the front deck grey matt .I have not posted anything on here for a long time as i realised that i was in over my head making 1/350 U.S. a/cs so went right back to basics making assorted armor and aircraft.I think i have gained enough skill to attempt the 1/350 Iwo Jima LHD-7[i also have the Wasp LHD-1,CVN-65Enterprise,CV-2Lexington,CV-19 Hancock,CV-10 Yorktown,CV-9 Essex,CV-13 Franklin and CV-8 Hornet]I attempted to make the Hancock and Lexington but abandonded them because of lack of experience but i am now going to revisit both as thank god what i done is fixable.
Thanks in advance Anthony PS cool avatar i am from the north of Ireland
PPS any help will be greatly appreciated
Anthony,
Had an Uncle from Belfast.
The colors in the painting instructions are suspect, at best.
For the hull and island I used White Ensign Colorcoats Modern USN Haze Gray (you can also use Testors Neutral Gray)
For the flight deck I used White Ensign Colorcoats Modern USN Flight Deck Gray
For the other decks I used Testors Gunship gray.
The aircraft will be Light Gull Gray, with a touch of dark gull gray on the upper surface of the Harrier only.
Hope this helps. Good luck with your builds. You'll never get the "experience" if you don't finish them - have at it and have fun!
Started flat coating her yesterday - airbrushed another coat on tonight. Everything is done except the aircraft (which need another coat of Lt Ghost Gray) and the landing craft, which need to be gloss coated and decaled, then flat coated...
ilovecarriers
Many thanks Martin much appreciated.I have plenty of time on my hands at the minute so will be finishing off these ships.
Regards Anthony
PS Dont know if you know it or heard of it but i am from the Falls Road in Belfast[the lower falls best part]
Regards Anthony
- sgtryan13
Great job Martin, sounds like we are at the same place in our respective builds! If she is done in time will she make an appearance at nationals? I am busting my butt, the Bush will be there, but she may have a slightly smaller airwing embarked with her than what is planned for her delivery to her buyer.
Don't rush it for the contest, Ryan...that's when an "oops" moment can occur! Sounds like you got her a ride down to Florida??
Well, I'm not sure that I'll be at the Nationals, but even if I make an appearance, Iwo Jima will not be - unless i can figure a way to slide that big a$$ case under the seat. Boy, that would be a nightmare going through security with it! Actually, if I show up, I don't know if I'll be entering anything this year, unless I finish this bad boy and find time to finish something else.
Managed to airbrush a second coat of flat last night. Will give her at least two more light coats of flat coat to even out the finish before considering her done.
Some updated photos. Model is flat coated, all deck equipment has been glued down. She'll get another final flat coat once the aircraft are completed and secured.
Let's start with the starboard side:
Now the port side:
And this is how she looks as of last night, before I removed the paper towels protecting the base. And before I knocked a bloody rudder off her!
What's left? Funny you should ask...
- Decal LCAC and LCU
- Flat coat LCAC and LCU, add Marine armor/trucks to same
- Finish aircraft, which entails final painting of fuselages, painting of rotors and windows, decals, etc
- Add aircraft to deck
- Final touch up and flat coat
That should take me another month or so, at my pace...
- Bigdaddy Mark
This is AWESOME!
~ Chester W. Nimitz ~
Bigdaddy Mark wrote:This is AWESOME!![]()
So finishing the freakin' aircraft is taking a lot longer than I expected and would have liked. I airbrushed dark ghost gray onto the tops of the Ospreys, Harriers and the Super Stallions. Basically, the color is so close to Light Ghost grey that it wasn't worth it. I also airbrushed the rotors a very dark grey (they need a 2nd coat).
I then airbrushed the aircraft with future, but they'll need another coat. Meanwhile, I decided to start painting the windows on the aircraft. Yeesh, what a PITA. Again, I'm not so good with the paint brush, so it's been painstakingly slow and the results have been less than stellar.
Here are a few update photos. First, some shots of Iwo Jima taken at my recent local IPMS club meeting: Next a few shots from last night. I was trying to figure out where I wanted to put the aircraft (I like this layout), then started painting windows. So, that's where I am at. Going to finish painting all the windows on the aircraft, future them again and then decal them. Should only be another month.
PS - sometimes I hate digital photography, which picks up items to be touched up that I missed with the Mk1 eyeball...
Well, aint' that the truth.sometimes I hate digital photography, which picks up items to be touched up that I missed with the Mk1 eyeball...
So close..............................
And yet so far away...Dan K wrote:So close..............................
- Bigdaddy Mark
I can't wait to get started on this one.
I couldn't; his build pushed me over the edge..
