Coyote-Man
Re: Calling all WWII Essex Class Carrier Fans!
Post by Coyote-Man »
USN_Matt wrote:Hello all, this has probably been discussed before somewhere on this thread. But I have a question about those towers (flight, radio, etc.?) that line the deck forward and aft of the island on the Yorktown CV-10; on some pictures and the trumpeter kit show that there are 5 (3 forward and 2 aft). But I have seen on others where it only has 2 forward of the island. Where more added later in '44 or vise versa?
Initially Yorktown had five masts.
Photos on NavSource (provided they are captioned correctly) indicate that the two after radio masts and one forward mast were removed in 1944. Then in 1944, three whip antennae were installed aft also.
http://www.navsource.org/archives/02/10.htm
Coyote-Man
From researching photos online, I have found that the Steel Navy Essex guide for the Lexington has some incorrect information http://www.steelnavy.com/essex_data.htm#CV-16 USS Lexington
copied from the SN site for conversation convenience:
Quad 40mm Gun Locations
Location/ Date Added (Number of Mounts)
Bow/ March 1943 - July 1952 (1)
Stern/ March 1943 - July 1952 (2)
Island/ March 1943 - May 1945 (4)
Island/ May 1945 - July 1952 (3)
Port Sponson/ March 1943 - July 1952 (2)
Port Flight Deck FWD/ March 1943 - July 1952 (1)
Port Flight Deck MID/ May 1945 - July 1952 (2)
Starboard MID/ May 1945 - July 1952 (3)
Starboard Aft/ March 1943 - July 1952 (2)
The Lexington initially had 1 stern quad 40mm (not 2). The second one was added sometime before 1945 (not sure when). Do you think it was mid-1944 while in re-fit?
I also think that the 2 port and 3 starboard mid-deck quads were added in late 1943 not May 1945.
regards Randy Riley
USN_Matt
Post by USN_Matt »
Awesome! Much appreciated!
Adaks
Post by Adaks »
Coyote-Man wrote:The Lexington initially had 1 stern quad 40mm (not 2). The second one was added sometime before 1945 (not sure when). Do you think it was mid-1944 while in re-fit?
No, second stern 40mm quad was added during her second WW2 refit (March-May 1945).
Coyote-Man wrote:I also think that the 2 port and 3 starboard mid-deck quads were added in late 1943 not May 1945.
Yes, they were added during first WW2 (post-torpedoing) refit (early 1944).
Help it helps.
Coyote-Man
Yes, they were added during first WW2 (post-torpedoing ) refit (early 1944).
Help it helps.
yes - helps alot. Trying to clear up all the little details of her history to build an accurate version.
So I am seeing 16 quad 40mm mounts total in late 1944.
Adaks
Post by Adaks »
Coyote-Man wrote:So I am seeing 16 quad 40mm mounts total in late 1944.
It should be 17 40mm mounts. CV-16 did not have second stern 40mm quad, but still had early island with 4 40mm quads at that time.
Coyote-Man
So this is what it should look like:
Coyote-Man wrote: Quad 40mm Gun Locations - USS Lexington after 1943 re-fit
Location (Number of Mounts)
Bow (1)
Stern (1)
Island (4)
Port Sponson (2)
Port Flight Deck FWD (1)
Port Flight Deck MID (1)
Port Aft (2)
Starboard MID (3)
Starboard Aft (2)
Total 17
Coyote-Man
Researching the Air Group for CV-16 Lexington in October 1944. I used Tracey's source to find this:
http://www.history.navy.mil/a-record/ww ... -10-44.pdf
With this, I am proposing the following marking details for the aircraft:
Group Count Model Colors (my best guess as to how to paint and mark)
VF-19 1 F6F-5 CAG Dark Blue overall, White Insignia & White Lettering, White stripe on rudder
VF-19 14 F6F-3 Two-tone Blue, Gray Underside, Blue/White Insignia & White Lettering
VF-19 2 F6F-3N (w/Radar) Dark Blue overall, White Insignia & Lettering
VF-19 1 F6F-3P (Photo) ?
VF-19 21 F6F-5 Dark Blue, White Insignia & White Lettering
VF-19 1 F6F-5N (w/Radar) Dark Blue overall, White Insignia & White Lettering, 2-20mm cannon
VF-19 1 F6F-5P (Photo) ?
VB-19 30 SB2C-3 ?
VT-19 18 TBM-1C ?
Depict Hellcats with drop tanks. Black props w/yellow tips. Stretched sprue antenna (vertical)
38 Hellcats regular, 2 night-fighters w/no cannon, 1 night-fighter w/cannon: Total 41
On Avenger�s do black wing walk bars. Antennae stretched sprue .50 cal in turret. Black props w/yellow tips. Use triangle decals (in Pontos set) for rudder.
Thanks in advance for your thoughts on this.
Randy Riley
P.S. I have a book resource "Blue Devils" which indicates that some older Hellcats were indeed still in the three-color paint scheme I'm proposing above.
If it's a -3 Hellcat, do it in tri-color. Ships did not repaint entire aircraft, just touch-ups and insignia changes. the -3Ns might be a little different, but I haven't found anything definitive yet.
The SteelNavy Essex data is an OK start but rife with errors. Offers to Steve Baker to help update have been ignored, but he'll sure as hell contact me when he wants something for one of his books. ::grumbles::
Adaks
Post by Adaks »
Coyote-Man wrote:VB-19 30 SB2C-3 ?
This photo was taken in October 1944:
Helldivers are still in the tri?color camouflage scheme.
Coyote-Man
I have seen this photo before, but have not found a caption for it that was meaningful to know when the photo was taken.
Do you know which carrier this one was?
thanks for the help.
Randy Riley
Adaks
Post by Adaks »
Coyote-Man wrote:Do you know which carrier this one was?
SB2C-3s of Bombing Squadron Nineteen (VB-19) on Lexington's flight deck. :) I think that VT-19's Avengers were also in the same camo at that time.
Coyote-Man
Excellent. Thanks for the information. With a full suite to do, the airwing will take a bit.
I will have to source some of the A/C insignia with the two white bars.
regards
Randy Riley
Coyote-Man
Searching for aircraft marking resources, I found one which has some good photos. Trying to figure out how much truth is there... be careful.
http://www.pmcn.de/English/USN%20Markin ... s%20II.htm
I am not an expert by any stretch, but I hope to be a good resource on a late war CV-16 by the time I begin my build... Cross-checking all the information with multiple sources and going with the majority seems to be the only way to be reasonably sure.
regards Randy Riley
Air Group 94 (June 16)
VF-94
F6F-5 x 30
F6F-5N x 4
F6F-5P x 2
VBF-94
F4U-4 x 36
VB-94
SB2C-4E x 15
VT-94
TBM-3E x 15
The air group largely stays this way for the rest of the war; they lose an aircraft here or there, but never get another variant in replacement (some carriers got replacement F6F-3s when their -5s were lost - Lexington never drops "down" a version). The Corsairs, Hellcats, and Helldivers should all be Glossy Sea Blue. Not clear is the TBMs... I suspect all Glossy Sea Blue as well, but have nothing definite. I'm not sure if you've read through my Lexington Quad .50 report, but it looks like mount 6 has some GSB Avengers... I'll try and look at the high-res copy tonight.
Coyote-Man
Tracy White wrote:Air Group 94 (June 16)
VF-94
F6F-5 x 30
F6F-5N x 4
F6F-5P x 2
VBF-94
F4U-4 x 36
VB-94
SB2C-4E x 15
VT-94
TBM-3E x 15
Hey Tracey
Perhaps you inadvertently confused Lexington's airgroup with another. The source above and everything I've read indicates that AVG-16, then AVG-19 were aboard the Lexington during '43 and '44. Or is this source totally inaccurate???
http://www.history.navy.mil/a-record/ww ... loc-ac.htm
Thanks Randy Riley
Ah... OK, brain fart on my part - I thought you were wanting to do summer/fall of 1945, not 1944.
VF-19 14 F6F-3 - tri-color
VF-19 2 F6F-3N (w/Radar) Not sure
VF-19 1 F6F-3P (Photo) tri-color
VF-19 1 F6F-5 - Glossy Sea Blue
VF-19 1 F6F-5N (w/Radar) Glossy Sea Blue
VF-19 1 F6F-5P (Photo) Glossy Sea Blue
VB-19 30 SB2C-3 - tri-color
VT-19 18 TBM-1C - tri-color
Fighters were orderd into GSB in March of 1944 and "all" carrier aircraft in October. The aircraft weren't repainted on the carriers - it was done at the time of manufacture or depot-level maintenance, if at all. F6F-3 production lasted until April of 1944, so there were *some* painted in Glossy Sea Blue, but the vast majority were in the tri-color scheme. So, for your airgroup, unless it's a -5 varient, paint it in tri-color.
aptivaboy
Post by aptivaboy »
FYI, fellow Essex builders - www.spruebrothers.com has the Pontos Model Yorktown superset on sale for $139. Its under their specials category. I don't know how many they have left (mine came today) but given that the regular price is $200, that's a pretty good discount.
Robert
Coyote-Man
aptivaboy wrote:FYI, fellow Essex builders - http://www.spruebrothers.com has the Pontos Model Yorktown superset on sale for $139. Its under their specials category. I don't know how many they have left (mine came today) but given that the regular price is $200, that's a pretty good discount.
Robert
Wow! Thanks Robert.
I was planning to get one too for my upcoming build - Just ordered...
Randy
aptivaboy
Post by aptivaboy »
You're welcome! Hope to see your's soon. I'm currently waffling between an early Lexington or Yorktown. Decision, decisions...
Return to “Aircraft Carriers”
